Voltage Divider with the MAX186
I am trying to use a voltage divider with the MAX186 ADC to read a 9 volt
source. I know I have to factor in the load of the MAX186 so I can get the
proper resistors for the voltage divider but I can not find what this load is.
Does anyone know where I can find this so I can figure out what resistors to
use?
Thanks!
Hank
use?
Thanks!
Hank
volt source. I know I have to factor in the load of the MAX186 so I
can get the proper resistors for the voltage divider but I can not
find what this load is. Does anyone know where I can find this so I
can figure out what resistors to use?
Thanks!
Hank
I would think the load for the chip would be negligible. Since it has a
4.096 volt internal reverence, your voltage divider needs to drop about 3
volts. Best thing to do is calculate using standard resistor values -- you
can get pretty close that way and not have to tweak anything.
> I am trying to use a voltage divider with the MAX186 ADC to read a 7
trying to measure is putting out 7.93 volts. The voltage at the junction of the
voltage divider reads 3.96 volts. I measured the resistors and they are within
1% of each other. Ideas?
Hank
Sent: Wednesday, February 26, 2003 8:47 PM
Subject: Re: [noparse][[/noparse]basicstamps] Voltage Divider with the MAX186
> http://pdfserv.maxim-ic.com/arpdf/MAX186-MAX188.pdf
worked through a similar deal to make a battery gauge with a small Atmel
processor with onboard ADC. If you haven't worked with ADC's before, the
trick may be to start with a less complicated part. Here is some stuff from
Parallax on one of their student lessons:
http://www.parallax.com/Downloads/Documentation/edu/Basic_Analog_and_Digital
_V_1.0.pdf
> I am using 2 10K ohm resistors for the voltage divider. The battery
voltage I am trying to measure is putting out 7.93 volts. The voltage at the
junction of the voltage divider reads 3.96 volts. I measured the resistors
and they are within 1% of each other. Ideas?
3
you
at the junction of the voltage divider reads 3.96 volts. I measured
the resistors and they are within 1% of each other. Ideas?
Sounds perfectly ok, what is your problem? May be 3.96V is yet to
close to 4.096V, so change one of your 10k resistrs to something
close to 5k to get 9V*5k/(5k+10k) = 3V. or use 20k/10k to reduce
the load even more.
Regards
Adrian
right but my math was wrong on the programming and the numbers were not coming
out correct... argggg!
Sorry for the dumb question.
Hank
Sent: Thursday, February 27, 2003 3:01 AM
Subject: [noparse][[/noparse]basicstamps] Re: Voltage Divider with the MAX186
> --- In basicstamps@yahoogroups.com, "Hank Hagquist" <hankster@h...>
> the load even more.
> Regards
> Adrian
I does work, the problem is the voltage regulator is
heating up and get damaged after sometime.
I am wondering what is causing it to draw high current
when using 12 inputs and one output.
Napoleon
--- Rodent <daweasel@s...> wrote:
> It should work, assuming you are talking to the chip
> correctly. I just
> _V_1.0.pdf
> 3
> you
> tweak anything.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do you Yahoo!?
Yahoo! Tax Center - forms, calculators, tips, more
http://taxes.yahoo.com/
voltage regulator is rated 1 amp at
5VDC. That is 5 watts max.
The problem probably isn't the one output as that would damage the stamp too.
So maybe the problem is related to the wiring related to the inputs. What size
(ohmic value) resistors are you
using as pull ups for the inputs? 10k or larger would work.
12 10k resistors all drawing current at the same time from a 5V source is only
.03 watts if all is normal.
Are you sure they are all the correct value? A 1k or 100 ohm didn't sneak in
there by mistake?
To trouble shoot:
1. Disconnect the inputs and the outputs.
2. Put a 1 ohm 10 watt resistor in series with the output of the voltage
regulator. Use a voltmeter to monitor
the voltage across this series resistor. Each volt across it means 1 amp of
current. I=V/R I= 1V/1 ohm = 1amp
3. Connect inputs one at a time and observe the voltmeter. Each input in the on
(current drawing) position show
only increase the voltage by .0005V.
4. Keep hooking things up until you find the problem.
Good luck
Fred
napoleon shlimon wrote:
> Thanks for your reply.
> Regards,
> Napoleon
> > correctly. I just
> > _V_1.0.pdf
> > 3
> > you
> > tweak anything.
> > ignored.
> Do you Yahoo!?
