Power Fail pin of DS1305
I am interfaceing the DS1305 Real-Time-Clock with my bs2 and I am
curious to know if I can leave the power fail pin floating or if I
should provide it a load. The pin is active low and is only driven
low if the supply voltage falls 0.2 volts below the backup supply. I
haven't decided if I will be using this feature, although, if I
choose not to, I would appreciate anyone's input on what to do with
the pin.
Kevin
the pin.
Kevin
floating or normal supply (5V)
Best Regards
Atentamente.
Ing. Damian Trujillo G.
RIESE & CIA, S.A.
Caracas - Venezuela
Phone: 58-212-7934266/4377
Fax: 58-212-7940791/0908
Email: dtrujillo_riese@c...
Date: Martes 25 de Febrero de 2003 01:57:37 PM
Subject: [noparse][[/noparse]basicstamps] Power Fail pin of DS1305
the pin.
Kevin
