Help reading/writing EEPROM
I need some help reading from and writing to the 24LC256. I've been
able to write to it (i think) using this program:
'I/O pins
sda CON 8
scl CON 9
'I2C Definitions
i2c_read CON 1
i2c_write CON 0
i2c_out VAR Byte
i2c_in VAR Byte
i2c_ack VAR Bit
'EEPROM
device CON %1010000
EEdata VAR Byte
EEaddress VAR word
'General Variables
x var byte
degC var byte
degF var byte
counter VAR Byte
'MAIN PROGRAM
loop:
freqout 0,20,3800
high 13
shiftout 15,14,lsbfirst,[noparse][[/noparse]238]
low 13
high 13
shiftout 15,14,lsbfirst,[noparse][[/noparse]170]
shiftin 15,14,lsbpre,[noparse][[/noparse]x]
low 13
degC=x/2
degF= degC * 9 / 5 + 32
pause 1000
FOR eeAddress = 0 TO 10
EEdata = degF
gosub ByteWrite
Debug "Wrote ", dec EEdata, " to memory location ", dec EEaddress,
cr, cr
pause 1000
debug "next", cr, cr
next
Debug "Finshed!!"
END
'subroutines
ByteWrite:
gosub I2C_START
for counter = 0 to 2
lookup counter, [noparse][[/noparse] (device<<1 | i2c_write), EEaddress.highbyte,
EEaddress.lowbyte], i2c_out
gosub I2C_TX
next
i2c_out = EEdata
gosub I2C_TX
gosub I2C_STOP
return
CurrentRead:
gosub I2C_START
i2c_out = device << 1 | i2c_read
gosub I2C_TX
gosub I2C_RX_NO_ACK
return
'sub-subroutines
I2C_TX:
shiftout sda, scl, 1, [noparse][[/noparse]i2c_out]
shiftin sda, scl, 0, [noparse][[/noparse]i2c_ack\1]
if i2c_ack = 0 then I2C_RETURN
return
I2C_RX:
shiftin sda, scl, 0, [noparse][[/noparse]i2c_in]
shiftout sda, scl, 1, [noparse][[/noparse]%0\1]
return
I2C_RX_NO_ACK:
gosub I2C_STOP
I2C_RETURN:
return
I2C_START
high sda
high scl
low sda
low scl
return
I2C_STOP
low sda
high scl
high sda
pause 1
return
I think that it writes, as I have a debug statment reading back what
was just written, and it reads correctly.
the thing I need help most with is reading. I have no clue whatsoever
as to how to read this EEPROM. So any help you can give me for
reading EEPROM would be greatly appreciated.
I know from reading the list posts that everyone on this list is very
helpful to begining "stampers" like myself.
thanks in advance,
BGrobotics
'I/O pins
sda CON 8
scl CON 9
'I2C Definitions
i2c_read CON 1
i2c_write CON 0
i2c_out VAR Byte
i2c_in VAR Byte
i2c_ack VAR Bit
'EEPROM
device CON %1010000
EEdata VAR Byte
EEaddress VAR word
'General Variables
x var byte
degC var byte
degF var byte
counter VAR Byte
'MAIN PROGRAM
loop:
freqout 0,20,3800
high 13
low 13
high 13
low 13
degC=x/2
pause 1000
EEdata = degF
gosub ByteWrite
cr, cr
pause 1000
next
Debug "Finshed!!"
END
'subroutines
ByteWrite:
gosub I2C_START
gosub I2C_TX
next
i2c_out = EEdata
gosub I2C_TX
gosub I2C_STOP
return
CurrentRead:
gosub I2C_START
gosub I2C_TX
gosub I2C_RX_NO_ACK
return
'sub-subroutines
I2C_TX:
return
I2C_RX:
return
I2C_RX_NO_ACK:
gosub I2C_STOP
I2C_RETURN:
return
I2C_START
high sda
high scl
low sda
low scl
return
I2C_STOP
low sda
high scl
high sda
pause 1
return
thanks in advance,
BGrobotics
'I/O pins
sda CON 8
scl CON 9
'I2C Definitions
i2c_read CON 1
i2c_write CON 0
i2c_out VAR Byte
i2c_in VAR Byte
i2c_ack VAR Bit
'EEPROM
device CON %1010000
EEdata VAR Byte
EEaddress VAR word
'General Variables
x var byte
degC var byte
degF var byte
counter VAR Byte
'MAIN PROGRAM
loop:
freqout 0,20,3800
high 13
low 13
high 13
low 13
degC=x/2
pause 1000
EEdata = degF
gosub ByteWrite
cr, cr
pause 1000
next
Debug "Finshed!!"
END
'subroutines
ByteWrite:
gosub I2C_START
gosub I2C_TX
next
i2c_out = EEdata
gosub I2C_TX
gosub I2C_STOP
return
CurrentRead:
gosub I2C_START
gosub I2C_TX
gosub I2C_RX_NO_ACK
return
'sub-subroutines
I2C_TX:
return
I2C_RX:
return
I2C_RX_NO_ACK:
gosub I2C_STOP
I2C_RETURN:
return
I2C_START
high sda
high scl
low sda
low scl
return
I2C_STOP
low sda
high scl
high sda
pause 1
return
thanks in advance,
BGrobotics
These notes relate to the 24C02, but should be similar:
http://www.lennard.net.nz/electronics/i2c.html#eepromexample
> From: "bgrobotics <Air_force@w...>" <Air_force@w...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Mon, 24 Feb 2003 01:06:21 -0000
> Subject: [noparse][[/noparse]basicstamps] Help reading/writing EEPROM
> 'I/O pins
> sda CON 8
> scl CON 9
> 'I2C Definitions
> i2c_read CON 1
> i2c_write CON 0
> i2c_out VAR Byte
> i2c_in VAR Byte
> i2c_ack VAR Bit
> 'EEPROM
> device CON %1010000
> EEdata VAR Byte
> EEaddress VAR word
> 'General Variables
> x var byte
> degC var byte
> degF var byte
> counter VAR Byte
> 'MAIN PROGRAM
> loop:
> freqout 0,20,3800
> high 13
> low 13
> high 13
> low 13
> degC=x/2
> pause 1000
> EEdata = degF
> gosub ByteWrite
> cr, cr
> pause 1000
> next
> Debug "Finshed!!"
> END
> 'subroutines
> ByteWrite:
> gosub I2C_START
> gosub I2C_TX
> next
> i2c_out = EEdata
> gosub I2C_TX
> gosub I2C_STOP
> return
> CurrentRead:
> gosub I2C_START
> gosub I2C_TX
> gosub I2C_RX_NO_ACK
> return
> 'sub-subroutines
> I2C_TX:
> return
> I2C_RX:
> return
> I2C_RX_NO_ACK:
> gosub I2C_STOP
> I2C_RETURN:
> return
> I2C_START
> high sda
> high scl
> low sda
> low scl
> return
> I2C_STOP
> low sda
> high scl
> high sda
> pause 1
> return
> thanks in advance,
> BGrobotics
> of the message will be ignored.
pseudocode write and read (for easy reading)
writes:
starti2c
write devicewriteaddress
write memoryaddress
write firstvalue
write secondvalue
write thirdvalue
stopi2c
reads:
starti2c
write devicewriteaddress (10100000)
write memoryaddress
starti2c <- Second start command, NO stop.
write devicereadaddress (10100001)
read firstvalue
read secondvalue
read thirdvalue
stopi2c
I2C device addresses are not just the address, their also the command to
tell it you want to read or write. The LSB is the read (0) or write (1)
command and the other 7 bits are the device address. The four highest bits
are the device's base address. For the 24LC256 the base address is 1010. The
next three bits are A2, A1 and A0, then you tack on a zero or 1 for write or
read.
A0, A1 and A2 set the 2nd, 3rd, and fourth LSBs of the address like this:
1 0 1 0 A2 A1 A0 R/W
So if you left all three grounded the write address would be
10100000
If you pulled A1 high, write would be
10100100
and read would be
10100101
To do a read you first have to do a write, send the eeprom memory address
you want to read, issue another start conversation command, send the read
command, then finally read from the eeprom.
You'll notice there are two starts without a stop in the read routine. The
second start is required to sort of reset the chip so it'll listen to the
new read address. Do NOT issue a stopi2c before the second start this point.
Once you send a stop, you give up control of the I2C bus and another I2C
device could take control between the two commands. Obviously not a danger
if its just the stamp and eeprom but its the standard way to talk I2C.
Different I2C devices have different base addresses. For the DS1307 real
time clock its D (1101) so its write address is 11010000 and read would be
11010001.
Hope that helps.
My 'lectronic Newb site http://members.shaw.ca/pmeloy/
Sent: Sunday, February 23, 2003 5:06 PM
> 'I/O pins
> sda CON 8
> scl CON 9
> 'I2C Definitions
> i2c_read CON 1
> i2c_write CON 0
> i2c_out VAR Byte
> i2c_in VAR Byte
> i2c_ack VAR Bit
> 'EEPROM
> device CON %1010000
> EEdata VAR Byte
> EEaddress VAR word
> 'General Variables
> x var byte
> degC var byte
> degF var byte
> counter VAR Byte
> 'MAIN PROGRAM
> loop:
> freqout 0,20,3800
> high 13
> low 13
> high 13
> low 13
> degC=x/2
> pause 1000
> EEdata = degF
> gosub ByteWrite
> cr, cr
> pause 1000
> next
> Debug "Finshed!!"
> END
> 'subroutines
> ByteWrite:
> gosub I2C_START
> gosub I2C_TX
> next
> i2c_out = EEdata
> gosub I2C_TX
> gosub I2C_STOP
> return
> CurrentRead:
> gosub I2C_START
> gosub I2C_TX
> gosub I2C_RX_NO_ACK
> return
> 'sub-subroutines
> I2C_TX:
> return
> I2C_RX:
> return
> I2C_RX_NO_ACK:
> gosub I2C_STOP
> I2C_RETURN:
> return
> I2C_START
> high sda
> high scl
> low sda
> low scl
> return
> I2C_STOP
> low sda
> high scl
> high sda
> pause 1
> return
> thanks in advance,
> BGrobotics
