Rv: Problem to Use MAX6955 with 16 7-Segment with four (4) led per segment
Mensaje Original
De: dtrujillo_riese@c... [noparse]/noparse][url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GGyzIx14ekbsF1ptLKB2uXkzOWhFg38Vg3ssEyumtJ6gCUqoncDG4wlIGaT1DqRAASEOJt71DG67-R5OGX1Y4w]dtrujillo_riese@c...[/url
Para: basicstamps@yahoogroups.com [noparse]/noparse][url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dsUOawhyYk4P0syDZDvuIvKZJYgUc2CMz50c5O9syO43uom27vAmcwaOR5kyf7W9ANkKZl0z-dFhOiJYb5XaFxa5HAs]basicstamps@yahoogroups.com[/url
Cc:
Asunto: Problem to Use MAX6955 with 16 7-Segment with four (4) led per
segment
Fecha: 22/02/2003 17:03:09
Mensaje:
Request/Problem:
i am trying to use this chip with Bs2p40 of PARALLAX, I don't have problem
to comunicate and configurate this chip by I2C, But I have a problem with
Display... Because, I am trying to use this chip with sixteen (16)
7-segment and each of segment is construcction by me by four (4) led
(Vd=0,8Vdc)... When a put in the MAX6955 this display.. I don't see
anywere, but If i put only two (2) led per segment I can see the
numbers..... I don't understand this because I can see in your datasheet
that if possible to put segment od (Vd max =V+ - 0,8)... Can you help me
about this requierement, I need to put this plataform in funtion with four
(4) led per segment...
I appreciate your prompt response
Best Regards
Eng. Damian Trujillo G.
Venezuela, Caracas
