servo resetting LCD?
I have a continuous rotation servo from parallax, a motion sensor and a 4
lines serial LCD connected to a BS2. My program continuously sends some data
to the LCD and the sensor takes care of triggering the motor. My problem is
that the stamp seems to reset every time that I send a pulsout to the servo.
Any ideas on why that's happening and how I can solve it? I tried using a
second power supply to power the LCD, but that didn't work at all...
Marcelo.
Marcelo.
The separate supply will probably work too -- be sure to connect the
grounds together.
Al Williams
AWC
* Limit monitor 8 channels at once
http://www.al-williams.com/awce/pak10.htm
> From: Marcelo Coelho [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vhAmbbBbrOyGYp3SaSZyZy5mstk7X6l5wpfTBxCRrvX7ptTSi6ZRnqCBrWpDmf1K0RObeh7f6oKyVpIGKsm4eyzH2G54Gw]mh_coelh@a...[/url
> Sent: Saturday, February 22, 2003 4:49 PM
> Subject: [noparse][[/noparse]basicstamps] servo resetting LCD?
> Hi,
> sensor and a 4 lines serial LCD connected to a BS2. My
> program continuously sends some data to the LCD and the
> sensor takes care of triggering the motor. My problem is that
> the servo. Any ideas on why that's happening and how I can
> solve it? I tried using a second power supply to power the
> Thanks,
> Marcelo.
> from the same email address that you subscribed. Text in the
Sent: Saturday, February 22, 2003 6:36 PM
Subject: RE: [noparse][[/noparse]basicstamps] servo resetting LCD?
> Put a largish (3300uF) cap across the +5V supply.
> grounds together.
> Al Williams
> AWC
> > From: Marcelo Coelho [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tF4sZhRfvv2vnmQ7ceTyJFzkU8MzuGKw3669SEmi8-V8waX5tQlhEoTzcs8EQIkEy1lla6vL_9tbi0UIZOQv8D4]mh_coelh@a...[/url
> > Hi,
> > Thanks,
> > Marcelo.
