Darlington Transistor — Parallax Forums
edited 2003-02-22 20:08 in General Discussion
Hi, thanks to Al Williams for the help ob the debug command.
Now another question:
I'm using a Darlington Transistor to close a relay (2 amps at 12 volts).
How do I calulate the size resistor to put in series with the base to fire
the transistor ??
I'm using a 1k now and it works but I'm not sure if this is right. The
transistor is a TIP120 from Radio Shack.
Bob
    edited 2003-02-21 13:34
    In a message dated 02/21/2003 07:44:24 Eastern Standard Time, robertp@v...
    writes:
    You probably don't need one. Most Darlingtons have a built-in series base
    resistor.
    Sid Weaver
    W4EKQ
    Port Richey, FL
    edited 2003-02-21 13:36
    In a message dated 2/21/2003 4:44:18 AM Pacific Standard Time,
    robertp@v... writes:
    > the transistor ??
    > Bob
    1k is fine. However you can use a much larger value resistor. The way to
    calcluate it is as follows.
    1. Know what current the relay coil uses. Say 100 ma for example
    2. Find out what the hfe rating of the darlington is. At 100 ma its hfe is
    about 400.
    3. Divide the coil current by hfe rating and that will give you the value of
    base current needed. 0.1 / 400 = 250 uA
    4. Now determine what size resistor is needed to give you 250 uA. 5volts
    (from stamp) - 1.2 volts (two base emitters of the TIP120) / base current.
    3.8 / 250 uA = 15.2k ohms
    Normaly to give some saftey margin, the value of the base resistor is lowered
    a little to make sure you drive your transistor into saturation (make it act
    like a closed switch).
    Hope this helps.
    Ken
    edited 2003-02-21 13:39
    In a message dated 2/21/2003 5:36:06 AM Pacific Standard Time, Newzed@a...
    writes:
    > robertp@v...
    > writes:
    > resistor.
    > Sid Weaver
    > W4EKQ
    > Port Richey, FL
    The TIP120 does not have a series base resistor. You MUST use a base resistor
    or risk damage to your stamp.
    Jon W, agree?
    edited 2003-02-21 17:20
    Thanks Sid for the info on the Darlington
    2nd question, I beed to switch on the relay several time very quickly .25
    second on, .25 second off, etc for about 4 cycles, my problem is that the
    relay doesn't bleed off quick enough I think ?
    I have tried a pulsout command with little success.
    Bob
    edited 2003-02-21 17:38
    In a message dated 02/21/2003 12:24:43 Eastern Standard Time, robertp@v...
    writes:
    That is only 4 cycles/sec. I am operating the 13 relays for my model train
    setup much much faster than that - over 200 cycles/sec. I am using TQ-2
    miniature PCB relays from Digikey. Did you look at the data sheet for your
    relay to see what the closure and release times are?
    Sid
    edited 2003-02-21 17:51
    Bob
    Relay contacts have a lot of bounce. In other words, when the contacts
    close, the bounce open and then closed several times before stabilizing.
    Typically, relays are slower to release than to activate also. If you need
    precise control without bounce, you should instead just switch your device
    by using a transistor. The transistor will operate fine using the pulsout
    command. Don't forget to consider the actual times needed to run the
    program and switch on/off the transistor for best accuracy. Turn on/off
    times using a transistor is much less than activating a power relay and vary
    on the type number.
    Jim
    From: Bob Phillips [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=707DbWLc9-iYaKfhhAtCnosjsGqBTRgzf5YQ3booxFettlvg7IKZMAlMQlFxzXg5wg_rTPwbSg]robertp@v...[/url
    Sent: Friday, February 21, 2003 12:20 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Darlington Transistor
    Bob
    >resistor.
    Most darlington transistors do NOT have a built-in series base
    resistor! The TIP120 is one of these: if you drive it directly from a
    Stamp pin, you WILL damage the Stamp.
    You are using 1K - this is about (5-1.2)/1000 ~= 3.8 mA. The TIP120 has a
    minimum Hfe of about 500..1000 at low (2A) currents, depending upon
    manufacturer. I'd say you are in the ballpark - I'd be more comfortable
    with 470R myself.
    dwayne
    Dwayne Reid <dwayner@p...>
    Trinity Electronics Systems Ltd Edmonton, AB, CANADA
    (780) 489-3199 voice (780) 487-6397 fax
    Celebrating 19 years of Engineering Innovation (1984 - 2003)
    Do NOT send unsolicited commercial email to this email address.
    This message neither grants consent to receive unsolicited
    commercial email nor is intended to solicit commercial email.
