Multiple inputs
I need to monitor some 32 switches. I know how to increase the
capability of the BS2 using serial latch chips such as the ucn6818.
Using the shiftout, I can control up to 32 led's or other low
current devices using only 3 pins of the BS2. Is there anything
similar but for input uses?
Al
Al
Stamp lines and SHIFTIN. Just remember that you'll need to dedicate a bit of
memory for every one of your extra inputs, so you need to have four bytes
available.
-- Jon Williams
-- Parallax
In a message dated 2/20/2003 8:14:45 PM Central Standard Time,
brownstamp@y... writes:
two pins for up to 64 inputs.
My 'lectronic Newb site http://members.shaw.ca/pmeloy/
Sent: Thursday, February 20, 2003 6:35 PM
Subject: Re: [noparse][[/noparse]basicstamps] Multiple inputs
> You can cascade four 74HC165s together to get 32 inputs using just three
of
> available.
> -- Jon Williams
> -- Parallax
solution, see http://www.emesystems.com/BS2rct.htm#switches
BTW I recommend a closer look to the other chapters at emesystems.
Regards
Adrian
