Need BS2 to talk to QBASIC via serial port
Hello
I need a data gathering BS2 to send a byte of data via serial to a PC
(Win 95 with QBASIC - yes its old but it works, or use to. ;-).
BS2 Port 4 goes direct to pin 2 on the D-9 of the serial port. Ground
is common, and on the D-9 pins 6 and 7 (DSR and RTS) are bridged
together.
BS2 code:
SEROUT 4,16468,[noparse][[/noparse]databyte]
QBASIC code:
OPEN "COM2:9600,N,8,1,CD0,CS0,DS0,OP0" FOR INPUT AS #1
INPUT #1, DBYTE
but this does not work... it just sits there.
Any help appreciated.
Roger
together.
BS2 code:
QBASIC code:
INPUT #1, DBYTE
Roger
returned. Your option would be to make sure the stamp appends a CR on the
end or use the INPUT$(x,y) command:
e.g.
DBYTE = INPUT$(2,1) tells qbasic to input 2 bytes from file/com #1
Hope this helps.
Sent: Wednesday, February 19, 2003 11:33 AM
Subject: [noparse][[/noparse]basicstamps] Need BS2 to talk to QBASIC via serial port
> Hello
> together.
> BS2 code:
> QBASIC code:
> INPUT #1, DBYTE
> Roger
