FOR JON Re: [basicstamps] Interesting Problem
Thanks for the reply. Then why does the stamp continue
to PWM pin 1, even though that command is over.
--- jonwms@a... wrote:
> The BASIC Stamp PWM command does not work well for
> motor control; it is setup
> for digital-to-analog conversion by charging an RC
> network.
> The other problem you're having is the the PWM
> command doesn't care what you
> do with the Outs or Dirs register. It will take the
> pin you give it, make it
> an output, then run the PWM function.
> -- Jon Williams
> -- Parallax
> In a message dated 2/17/2003 6:32:54 PM Central
> Standard Time,
> suri_list@y... writes:
> > Hi
> > I am trying to control (Variable Speed) of a motor
> > using an Hbridge .The 2 terminal(Logic inputs) of
> the
> > hbridge are being driven form the stamp IOs out0
> and
> > out1.Please refer to the code shown below.
> > '{$STAMP BS2}
> > output 0
> > output 1
> > output 2
> > output 3
> > temp var word
> > 'RUN MOTOR FORWARD AT A CERTAIN SPEED
> > for temp = 1 to 100
> > out0= %0
> > pwm 1,150, 10
> > NEXT
> > 'RUN THE MOTOR BACKWARD AT A CERTAIN SPEED
> > for temp = 1 to 100
> > out1= %0
> > pwm 0,150, 10
> > NEXT
> > The problem is that in the first part the program
> > works fine and the motor runs forward at a certain
> > speed . But when the part to reverse direction
> comes
> > the motor just stops. I saw teh output pine on the
> > scope and interestingly. Even though the first
> part
> > works fine . In the second loop. IO 1 still keeps
> on
> > giving PWM inspite of the command OUT1 = %0. the
> > magnitude of the PWm is lesser. But its enough to
> keep
> > the fan off. Why isnt IO1 staying at 0.
> > Kindly Advise
> > Thanks
> [noparse][[/noparse]Non-text portions of this message have been
> removed]
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do you Yahoo!?
Yahoo! Shopping - Send Flowers for Valentine's Day
http://shopping.yahoo.com
> network.
> -- Jon Williams
> -- Parallax
> Standard Time,
> > Hi
> the
> and
> > '{$STAMP BS2}
> > output 0
> > output 1
> > output 2
> > output 3
> > temp var word
> > for temp = 1 to 100
> > out0= %0
> > pwm 1,150, 10
> > NEXT
> > for temp = 1 to 100
> > out1= %0
> > pwm 0,150, 10
> > NEXT
> comes
> part
> on
> keep
> > Kindly Advise
> > Thanks
> removed]
> ignored.
Do you Yahoo!?
command will be over.
-- Jon Williams
-- Parallax
In a message dated 2/17/2003 7:01:24 PM Central Standard Time,
