Getting error
Archiver
Alright, I did the stty -F /dev/ttyS0 9600 raw -echo -hupcl but now
plugging in the cable just freezes it up. I assume this is because it
is keeping one pin high now which confuses the stamp. So then I just
did the 9600 raw -echo without the -hupcl and there is the same
problem still, I didn't get this before and I used the exact same
settings.
And it all gives me ** no stamp or unable to identify.
How do I get my cord back to not freezing it?
settings.
a)?
2.) Can you tell me the type of UART of your Computer?
3.) Keeping a certain line high/low could confuse the stamp only if
it is the DTR pin. I usually connect it to the stamp through a
capacitor (helps to avoid some noise problems too).
PC 100n stamp
DTR
RST
+--||---GND
100n
Once I had a problem where the stamp reset when I just touched it
with the serial plug (was a grounding problem).
Can you please show me the layout of your serial cable?
speed 9600 baud; rows 0; columns 0; lines = 0;
intr = ^C; quit = ^\; erase = ^?; kill = ^U; eof = ^D; eol = <undef>;
eol2 = <undef>; start = ^Q; stop = ^S; susp = ^Z; rprnt = ^R; werase =
^W; lnext = ^V; flush = ^0; min = 1; time = 0;
-parenb -parodd cs8 -hupcl -cstopb cread clocal -crtscts
-ignbrk -brkint -ignpar -parmrk -inpck -istrip -inclr -igncr -icrnl
-ixon -ixoff -iucle -ixany -imaxbel
-opost -olcuc -ocrnl onlcr -onocr -onlret -ofill -ofdel nl0 cr0 tab0
bs0 vt0 ff0
-isig -icanon iexten -echo echoe echok -echonl -noflsh -xcase -tostop
-echoprt echoctl echoke
When I just touch the plug in the cord it locks up and restarts when I
take it out.
I was suspecting that the locking up for the stamp was caused by a pin
being kept high as a result of mucking around with the settings
because when I plug it into /dev/ttyS1 or another computer it works
just fine.
How can I detect the UART. This computer is quite new, so I suppose it
would be *665*A or whatever it usually is.
Thank you!
bs0 vt0 ff0
take it out.
just fine.
Thank you!
bs0 vt0 ff0
take it out.
just fine.
Thank you!
bs0 vt0 ff0
take it out.
just fine.
Thank you!
Seems your tty settings are ok - the same as mine.
To display the type of UART (I assume you have kinda 16550A) use
setserial -a /dev/ttyS0
You say the stamp resets when you just plug the cable in. So try
the following:
edit the file SBLoader.cc and locate the function 'resetDev', then
add two lines of code as shown below.
When forming the reset pulse I cleared and set DTR but did not clear
it again. Thats what the two added lines of code do.
I think this little bug did not catch me because I allways use a
capacitor between ATN (not RST as I errnoeously mentioned earlier)
and DTR.
SBLoader::resetDev
// form the reset pulse on DTR
ioctl(m_fp, TIOCMBIC, &dtr_bit);
usleep(RESET_DTRPULSE_US);
ioctl(m_fp, TIOCMBIS, &dtr_bit);
// add the following two lines
Regards
Adrian
even running when it does.
Yeah, that's my UART.
program. It works now, thank you SO MUCH. You have saved me the
frustration and pain of finding and using a windows computer to do this.
you rock!
~jeff
