Time Conversions
Hi All,
I have a device that is giving me GMT in 24 hour format. I want to be able
to convert this to PST and display it in both 24 and 12 hr formats.
Unfortunately, my Stamp math skills aren't up to it. Anyone know how? Tracy,
are you lurking ;-)
Jonathan
www.madlabs.info
are you lurking ;-)
Jonathan
www.madlabs.info
result is 0, its AM, if the result is 1, its PM. If its PM, subtract 12 from
the hours and you are done.
Tracy,
> are you lurking ;-)
You can do it without worrying about negatives by using the modulus operator.
Like this:
hours = hours + (24 - TzOffset) // 24
... where TzOffset (time zone offset) is the difference between your location
and GMT. I know the math looks a little funky, but it keeps you from doing a
comparison.
After you have the time, you can convert to AM/PM with just a few lines of
code:
ampm = hours / 12
hours = hours // 24
IF (hours = 0) THEN hours = 12
This assumes that ampm is a bit flag (0 = am, 1 = pm) and that you're using
the $PBASIC 2.5 compiler switch.
-- Jon Williams
-- Parallax
In a message dated 2/16/2003 4:10:27 PM Central Standard Time,
jpeakall@m... writes:
> Hi All,
> Tracy,
> are you lurking ;-)
> Jonathan
> www.madlabs.info
Foolishly, I forgot to tell you the time is in HEX format. I am SO sorry to
be SO thick, but me and math just don't get along, and Stamp math makes my
head hurt. So, since I am in HEX, can I either convert it, or change the
formula you wrote?
Jon, thanks a lot for all the help on this project. Talk about product
support!
Jonathan
www.madlabs.info
Sent: Sunday, February 16, 2003 8:24 PM
Subject: Re: [noparse][[/noparse]basicstamps] Time Conversions
> I believe you need to subtract eight hours to convert GMT to Pacific time.
operator.
> Like this:
location
doing a
> comparison.
> code:
> ampm = hours / 12
> hours = hours // 24
using
> -- Jon Williams
> -- Parallax
> > Hi All,
able
> > Tracy,
> > are you lurking ;-)
> > Jonathan
> > www.madlabs.info
know the format so we can help you decode it.
to
> formula you wrote?
list] may have an easy way to do it via hex, I would probably just convert
the hex values to decimal. Something like this:
hours = hours.HighNib * 10 + hours.LowNib
-- Jon Williams
-- Parallax
In a message dated 2/17/2003 11:05:37 AM Central Standard Time,
> Jon,
> formula you wrote?
> support!
> Jonathan
> www.madlabs.info
> From: <jonwms@a...>
> operator.
> > Like this:
> location
> doing a
> >comparison.
> >code:
> > ampm = hours / 12
> > hours = hours // 24
> using
> >-- Jon Williams
> >-- Parallax
> >>Hi All,
> able
> >>Tracy,
> >>are you lurking ;-)
> >>Jonathan
> >>www.madlabs.info
I agree with Jon about the calculation--covert it to decimal first.
If you also need to do the date, you will have to do a "borrow" that
might extend to the month and year. E.g., there will be 8 hours in
GMT on Jan 1 2004 when you will still be in Dec 31 2003!
I have some Julian date calcs at this URL:
http://www.emesys.com/BS2math4.htm#JulianDate
-- Tracy
>comparison.
>code:
> ampm = hours / 12
> hours = hours // 24
>Jon,
>formula you wrote?
>support!
>Jonathan
>www.madlabs.info
>From: <jonwms@a...>
>operator.
>> Like this:
>location
>doing a
>> comparison.
>> code:
>> ampm = hours / 12
>> hours = hours // 24
>using
>> -- Jon Williams
>> -- Parallax
>> > Hi All,
>able
>> > Tracy,
>> > are you lurking ;-)
>> > Jonathan
>> > www.madlabs.info
>Subject and Body of the message will be ignored.
