Data storage
Archiver
Does anyone know how to use the Read and Write commands? Or is there
any other way to store data with the BS2 even after power is removed
from the chip?
from the chip?
documented in the manual that you can download from our web site at NO
CHARGE.
What ISN'T in the manual [noparse][[/noparse]but is in the Beta docs] is how READ and WRITE work
in PBASIC 2.5:
* Both work with word variables
WRITE location, Word wordVar
READ location, Word wordVar
* You can use multiple variables in one statement:
WRITE location, var1, var2, var3....
READ location, var1, var2, var3....
And, of course, you can throw the Word modifier into the multi-variable
version.
If you don't have enough onboard EEPROM for your needs, you can always attach
an I2C or other EEPROM with the Stamp. It's easy to do and only takes a
couple pins.
-- Jon Williams
In a message dated 2/12/2003 10:44:21 PM Central Standard Time,
ghetto@t... writes:
> from the chip?
Has anyone any information on interfacing a standard 31/2'"
floppy drive to a stamp for
Data Logging? The application requires physically moving
data from the unit to a pc.
Anyone?
James Myles.....jmyles@r...
Here is a link to a datalogger designed to work with a CompactFlash card
and a PC compatible file system.
http://www.tern.com/fc_b.htm
I think a complete starter kit runs about $299.
amg
On Thu, 05 Jun 2003 17:37:58 -0400 James Myles <jmyles@r...>
writes:
> floppy drive to a stamp for Data Logging? The application requires
physically
> moving data from the unit to a pc.
Did you know that if you open your data logging program in Hyperterminal and
capture the data to an Excel file, you can generate a file with 65535
rows - that's 65535 data readings - and 231 columns - that's 231 channels.
That adds up to 15MB of data storage.
Data coming from a remote location? Use an RF link.
Just a thought.
Sid Weaver
W4EKQ
Port Richey, FL
