low ohm resistors — Parallax Forums
low ohm resistors
edited 2003-02-12 21:29 in General Discussion
Does anyone know where to find low ohm resistors - - I need a .02 ohm 10
watt tolerance doesn't matter 3 or 5 % is fine. I only need 1 so I don't
want to buy in bulk. Any help greatly appreciated.
Jason
    edited 2003-02-12 11:21
    I believe you can get them from Allied Electronics(www.alliedelec.com) or
    Digikey(www.digikey.com)
    I don't have my catalogs with me so I cant look them up for you.
    Another method would be to wind some wire on a core. I don't know what your
    current requirements are. Try <A HREF="www.alphawire.com">www.alphawire.com</A>
    They have a good technical
    section that should give the resistance of wire.
    Good Luck,
    Alan Bradford
    Plasma Technologies
    edited 2003-02-12 13:56
    A little tip about winding low value resistors. If you wind some wire into
    a coil you are creating an inductor which may cause other problems. To make
    a low value resistor without creating inductance, determine a length of wire
    needed for the resistance required, fold it in half, then wind both strands
    at the same time. This cancels the inductance to a great extent and keeps
    the device a resistor. This esentially is the method used to produce low
    value non-inductive wire wound resistors. Be sure to consider the
    temperature of the insulation on the wire when doing this.
    Jim
    From: plasmastamp@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZlR2eIpIt0osS-9D_Lwijr-AWabdS4gCjUwQHyPHmHAqUg1ztw4xMGFWePXIHJxgcZC_z1BxVHyWZL8]plasmastamp@a...[/url
    Sent: Wednesday, February 12, 2003 6:22 AM
    Subject: Re: [noparse][[/noparse]basicstamps] low ohm resistors
    HREF="www.alphawire.com">www.alphawire.com</A> They have a good technical
    Good Luck,
    Alan Bradford
    Plasma Technologies
    edited 2003-02-12 14:09
    is this a low ohm resistor or a current shunt?
    shunts are readily available from the major suppliers.
    norm
    >From: miller <miller12@r...>
    >Reply-To: basicstamps@yahoogroups.com
    >Subject: [noparse][[/noparse]basicstamps] low ohm resistors
    >Date: Wed, 12 Feb 2003 00:01:11 -0800 (PST)
    >Jason
    esistor
    _________________________________________________________________
    Tired of spam? Get advanced junk mail protection with MSN 8.
    http://join.msn.com/?page=features/junkmail
    edited 2003-02-12 14:50
    In a message dated 2/12/2003 12:02:52 AM Pacific Standard Time,
    miller12@r... writes:
    > Jason
    <A HREF="www.caddock.com">www.caddock.com</A>
    edited 2003-02-12 15:28
    If you plan to make a resistor from winding wire on a form, there is a real
    nice wire table that tells Ohms per foot at:
    http://www.pupman.com/listarchives/1998/April/msg00189.html
    Leroy Hall
    Sent: Wednesday, February 12, 2003 9:50 AM
    : In a message dated 2/12/2003 12:02:52 AM Pacific Standard Time,
    : miller12@r... writes:
    : > Does anyone know where to find low ohm resistors - - I need a .02 ohm 10
    : > watt tolerance doesn't matter 3 or 5 % is fine. I only need 1 so I don't
    : > want to buy in bulk. Any help greatly appreciated.
    : > Jason
    : <A HREF="www.caddock.com">www.caddock.com</A>
    : [noparse][[/noparse]Non-text portions of this message have been removed]
    : To UNSUBSCRIBE, just send mail to:
    : basicstamps-unsubscribe@yahoogroups.com
    : from the same email address that you subscribed. Text in the Subject and
    : Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    http://www.digikey.com/scripts/us/dksus.dll?Detail?
    Ref=60406&Row=123310
    sorry, yahoo is being stupid and makes this address wrap onto two
    lines
    ohm 10
    don't
    > Jason
