AppMod header
                    I'm working with the Super Carrier board and I'm driving myself nuts
trying to find a ribbon cable connector to plug into the 20 pin
AppMod header. The female connectors are easy to find but the males
are something else. I have run accross a couple of products that I
think will work but I'm under time constraints where I can't afford
the turn around time of ordering the wrong part. If anyone has any
suggestions of something from digikey, mouser, or anywhere else
online I would appreciate it.
rather than plugged into a socket. What alot of people do is use a female
ribbon cable connector and a 20-pin header with long pins on both sides.
this allows you to connect the cable to a 20-pin female socket.
find it on the Parallax site.
-- Jon Williams
-- Dallas Office
From: craiggregory1958 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VVsok8xvXuXYoQwCQqWxM73BhoAOMVApHt4y3BDtKVIgm49lzJnbuH8dnNvaTKP14DkeY-6I-Gd69kz6mn0Ti2OQV5SP]craig.gregory@e...[/url
Sent: Sunday, July 04, 2004 1:14 PM
Subject: [noparse][[/noparse]basicstamps] AppMod Header
Where can I get the "standard" 2x10 AppMod header ? I can't seem to
Check with http://www.commcon.com/main/
-Bruce
tech@r...
http://www.rentron.com
>> I can't seem to find it on the Parallax site.
http://www.parallax.com/detail.asp?product_id=450-02003
http://www.parallax.com/detail.asp?product_id=450-02002
If you are just looking for a regular 2x10 female header, then you
can get those at Jameco. Part # 70826.
Kenny
to
It can be found here:
Knight Designs
