Stuck...Store command BS2P
Sent: Tuesday, February 11, 2003 2:24 PM
Subject: Stuck...Store command BS2P
I am stuck and must be missing something. Let me explain.
I have a BS2P. I was using bank 0 and 1 for my program & data statements.
Bank 1 was only run at reset to initialize the connected PC's screen. Once It
was run the bit 1 of scratch pad ram was set to a 1 to prevent any additional
runs. The program worked fine but as any program feature creap entered I needed
more program room. I deceided to free up some 800 bytes of EEprom Data in both
banks 0 and 1 and move all the Data to bank 2. This would give me more room for
program space. I have moved the combined EEprom data from bank 0 and 1 into
bank 2. I have updated the indexes to the tables used in bank 0 & 1 to
correspond to the combined data (Now in Bank 2) and issued a STORE 2 command in
both bank 0 & 1 programs.
However now I am unable to access any of the data correctly. What am I
missing??? Any help or hints greatly appreciated
> From: Eric Adams
>statements. Bank 1 was only run at reset to initialize the
>connected PC's screen. Once It was run the bit 1 of scratch pad ram
>was set to a 1 to prevent any additional runs. The program worked
>fine but as any program feature creap entered I needed more program
>more room for program space. I have moved the combined EEprom data
>from bank 0 and 1 into bank 2. I have updated the indexes to the
>tables used in bank 0 & 1 to correspond to the combined data (Now in
>Bank 2) and issued a STORE 2 command in both bank 0 & 1 programs.
>am I missing??? Any help or hints greatly appreciated
Write yourself a short program to verify operation. You know, you
have execute the STORE 2 command every time you change banks, not
just once?
'bank 0
ix var byte
store 2
write 0,ix
run 1
'bank 1
ix var byte
store 2
read 0,ix
debug ?ix
ix=ix+1
pause 1000
run 0
-- Tracy
Tracy your little program works as did the Parallax examples which I tried
earlier before I went into this data rearrangement. I thought I understood
the STORE when reading the manual. However my rearrangement of all of the
DATA statements from modules 0 & 1 and putting them into module 2 all by
themself still does not work. The store command says it affects Read &
Write statements. Question does the data have to be previously written by
the program in slot 0 or 1 for the store2 to work. What I am trying to say
is my data is just DATA statements not written by write instructions in
modules 0 and 1 Is there some pointer that gets updated when a write is done
verses just plopping the data into a module?
As I mentioned before I am using the exact data statements as I used in
modules 0 & 1 just relocating them to module 2 and adding the Store 2
command so the reads can go to module 2. Any ideas ??
Sent: Tuesday, February 11, 2003 3:10 PM
Subject: Re: [noparse][[/noparse]basicstamps] Stuck...Store command BS2P
> > From: Eric Adams
> just once?
> 'bank 0
> ix var byte
> store 2
> write 0,ix
> run 1
> 'bank 1
> ix var byte
> store 2
> read 0,ix
> debug ?ix
> ix=ix+1
> pause 1000
> run 0
> -- Tracy
I gave the program a few write commands using the existing data in
locations 0-3 after the STORE 2 and then I was able to read the rest of the
data in module 2. Can't figure it out but it worked.
Thanks all
Sent: Tuesday, February 11, 2003 8:37 PM
> Hi Tracy & fellow stampers
understood
say
done
> From: "Tracy Allen" <tracy@e...>
> > > From: Eric Adams
> > just once?
> > 'bank 0
> > ix var byte
> > store 2
> > write 0,ix
> > run 1
> > 'bank 1
> > ix var byte
> > store 2
> > read 0,ix
> > debug ?ix
> > ix=ix+1
> > pause 1000
> > run 0
> > -- Tracy
and
Can you show us a short example program, that does not work the way you expect?
If you install DATA in bank 2, you should be able to READ it from
banks 0 or 1. Are you sure your bank 2 is declared as part of your
project?!
Example:
'{$stamp BS2p, eek1.bsp, eek2.bsp} <--- declare?
'bank 0, eek0.bsp
ix var nib ' 16 byte pointer
char var byte
store 2
read ix,char
debug char
ix=ix+1
run 1
'bank 1, eek1.bsp
ix var byte
char var byte
store 2
read ix,char
debug char
ix=ix+1
run 0
'bank 2, eek2.bsp
data "testing 1, 2, 3",cr ' 16 chars
-- Tracy
I have tried to duplicate the problem several ways with no luck. I think it
may have been a typo in the Declare statement which probably caused this.
It however looked like the Write statements cleared it but it probably was
me inputting your little program forcing me to reload my original program.
In either case it is fixed and I am indebted to you (again)
Eric
Sent: Tuesday, February 11, 2003 9:33 PM
tried
understood
the
by
say
done
expect?
> project?!
> Example:
> 'bank 0, eek0.bsp
> char var byte
> store 2
> read ix,char
> debug char
> ix=ix+1
> run 1
> 'bank 1, eek1.bsp
> ix var byte
> char var byte
> store 2
> read ix,char
> debug char
> ix=ix+1
> run 0
> 'bank 2, eek2.bsp
> -- Tracy
Who on this list isn't
Larry Gaminde
Sent: February 13, 2003 12:06 PM
: Hi Tracy:
: I have tried to duplicate the problem several ways with no luck. I
think it
: may have been a typo in the Declare statement which probably caused
this.
: It however looked like the Write statements cleared it but it
probably was
: me inputting your little program forcing me to reload my original
program.
: In either case it is fixed and I am indebted to you (again)
: Thanks
: Eric
: From: "Tracy Allen" <tracy@e...>
: To: <basicstamps@yahoogroups.com>
: Sent: Tuesday, February 11, 2003 9:33 PM
: Subject: Re: [noparse][[/noparse]basicstamps] Stuck...Store command BS2P
: > >Hi Tracy & fellow stampers
: > >Tracy your little program works as did the Parallax examples
which I
: tried
: > >earlier before I went into this data rearrangement. I thought I
: understood
: > >the STORE when reading the manual. However my rearrangement of
all of
: the
: > >DATA statements from modules 0 & 1 and putting them into module 2
all by
: > >themself still does not work. The store command says it affects
Read &
: > >Write statements. Question does the data have to be previously
written
: by
: > >the program in slot 0 or 1 for the store2 to work. What I am
trying to
: say
: > >is my data is just DATA statements not written by write
instructions in
: > >modules 0 and 1 Is there some pointer that gets updated when a
write is
: done
: > >verses just plopping the data into a module?
: > >As I mentioned before I am using the exact data statements as I
used in
: > >modules 0 & 1 just relocating them to module 2 and adding the
Store 2
: > >command so the reads can go to module 2. Any ideas ??
: > Can you show us a short example program, that does not work the
way you
: expect?
: > If you install DATA in bank 2, you should be able to READ it from
: > banks 0 or 1. Are you sure your bank 2 is declared as part of
your
: > project?!
: > Example:
: > '{$stamp BS2p, eek1.bsp, eek2.bsp} <--- declare?
: > 'bank 0, eek0.bsp
: > ix var nib ' 16 byte pointer
: > char var byte
: > store 2
: > read ix,char
: > debug char
: > ix=ix+1
: > run 1
: > 'bank 1, eek1.bsp
: > ix var byte
: > char var byte
: > store 2
: > read ix,char
: > debug char
: > ix=ix+1
: > run 0
: > 'bank 2, eek2.bsp
: > data "testing 1, 2, 3",cr ' 16 chars
: > -- Tracy
: > To UNSUBSCRIBE, just send mail to:
: > basicstamps-unsubscribe@yahoogroups.com
: > from the same email address that you subscribed. Text in the
Subject and
: Body of the message will be ignored.
: > Your use of Yahoo! Groups is subject to
: To UNSUBSCRIBE, just send mail to:
: basicstamps-unsubscribe@yahoogroups.com
: from the same email address that you subscribed. Text in the
Subject and Body of the message will be ignored.
: Your use of Yahoo! Groups is subject to
