Case statement limits
Hi all,
Is there a maximum number of case statements in a row? I have 10 cases, and
after number 7 it says "too complex".
Jonathan
www.madlabs.info
Jonathan
www.madlabs.info
>Thanks,
>Jonathan
>www.madlabs.info
The Stamp has an 8-level expression stack. The error message,
"expression too complex" occurs when you use up all 8 levels and
more. (Is that the error message you got?
For example,
y var word
y=1+2+3+4+5+6+7+8+9 ' that only uses 2 levels, no problem
y=1+(2+(3+(4+(5+(6+(7+(8+9))))))) ' needs 9 levels in PBASIC
' TOO COMPLEX
(The example is from Brian Forbes' excellent book on Stamp internals.
<http://members.aol.com/stamp2book/>)
The plain IF-THEN command in the old PBASIC puts at least 2 arguments
onto the expression stack, and more if you use a complicated
expression for the condition. BRANCH, I think used only one
location, but you could use complex expressions for the Branch
arguments.
I'm not sure how the CASE statement is implemented in the new PBASIC,
but it would probably parse out to a bunch of IF-THEN's or BRANCH's.
Look at your expressions to see how they could be simplified.
-- Tracy
