car lights
Archiver
I want to use my BS2 so that it controls alot of the things in my
car (94 eclipse). I want the headlights to flash back and forth
(like a police cars headlights) when I dim or brighten them. So if
they are dim, I pull the dimmer switch, the lights cycle back and
forth really fast for a few seconds, and then go bright. it should
do the same thing when I dim them. I know how to write basic things
for the stamp, but don't know how to get this program wrote so that
it picks up the change in the dimmer switch, and then only flashes
them for a second before going to the right stage.. please help me
with the program.. this is driving my crazy. thank you.
vehicles to have this capability. With that said here is one technique:
You need to isolate, individually, each high and low beam light with a
relay, each relay controlled by a stamp output thru a transistor switch
so you will use four stamp outputs. It is the same as turning an LED on
or off but you'll be turning a relay on or off thru a transistor. This
technique is well documented in the Stamp documentation and examples.
You need to use one stamp input to sense whether the voltage to the high
beam lamp is high or low. This is also well documented in the Stamp
documentation.
Your program needs to continuously test the high beam voltage sense
input and when it senses a change in the state of the high beam voltage,
it will go into a loop that toggles the stamp outputs controlling the
left low beam and right high beam light for your desired length of time,
then switches them off while turning on the opposite lights for the same
amount of time. Once this loop has executed however many times you want,
you turn on (or off depending on the state of the high beam sense) the
two stamp outputs that either turn your low beams on/high beams off, or
low beams off/high beams on.
The programming is simple, the electrical interface will be the
difficult part to ensure you have weatherproof relays/connections for
reliability. Plus if you make a change to the factory wiring and have an
accident due to loss of lighting and it is determined that your wiring
caused the loss of lighting, you can probably kiss your insurance
coverage good-bye.
Otherwise, Have fun.
vormulac35@h... writes:
First of all, I stronly emphasize that whatever you do, the system has a
default mode that leaves the headlights on. This is in case, if you are on a
dark road, in the middle of a turn and for some unknown reason the stamp or
circuitry fails you will still be able to see......
Also, many vehicles these days split the left and right headlight circuits,
so that if there is a failure in one side you still have one headlight....
With all the legal mumbo jumbo out of the way, at your OWN RISK consider the
following...
My fisrt question is: Do you know how to interface a relay to the Stamp?
And you have a solid foundation on how a relay works, that is to turn it off
and on.
Some systems headlamp switches supply a ground to a relay where the relay
contacts then send power to your dimmer switch. With the dimmer switch at
"rest" power is routed to the headlamp low beams, and then when you switch to
brights, power is routed to the high beams.
Therefore, the dimmer switch will be similar to the contacts of a single pole
double throw relay, that is one power wire in, and two outputs. Your manual
activation of the switch simulates the relay coil energized or not.
You will install a single pole double throw relay in place of the dimmer
switch.
With the relay off, power is routed to the low beams (just at the dimmer
switch in one position) and then when the relay is turned on, power is routed
to the high beams, ( just as the dimmer switch does in the high beam
position)
Next, you will wire +5 volts to the "single pole" side of the dimmer switch,
and the low beam output of the dimmer switch into an input pin of the stamp (
and there are some resistors needed to protect the stamp).
You will monitor the output of the dimmer switch and write your program to do
the following....
When the stamp senses 5 volts on the lowbeam output of the dimmer switch,
keep the relay (the newly installed stamp controlled relay) turned off so the
low beams are on.
When the stamp senses no 5 volts on the lowbeam output of the dimmer switch,
turn the relay on and off several times (with appropriate delays to get the
flashing you want) then leave the realy energized, and the high beams are on.
When the stamp again senses 5 volts on the lowbeam output of the dimmer
switch, turn the relay on and off several times (with appropriate delays to
get the flashing you want) then leave the realy DE-energized, and the LOW
beams are on.
Progam example- IDEA ONLY, not actual code.......
Loop
5v on lowbeam output?
if yes jump to loop ;do nothing, stay in low beam state
if not jump to High_Beam
High_Beam
cycle relay on and off
leave relay on ;high beams now on after being cycled
Remain_High
if not jump to Remain_High ;do nothing stay in high beam mode
if yes cycle relay on and off
leave relay off
jump to Loop
The wiring is a bit much to explain in words, If you give a FAX number, I can
"whip up" a simple diagram that will get you started...
Ken
Richey
wrote:
> just wondering why in the wourld do you want to do this.
> Richey
Doing it for looks, it's getting turned in to an all out show car.
As to the other two responces, I know everything about the car's
wiring and how to hook it up and what to do, my question was with
the code... I don't know how to write it to make it do what I
want. "Dim, hit the dimmer switch, flash like a cops, then go
bright." and vice versa.. But like I said up top, SHOW CAR, I
already have the stamp running a series of different things like the
power windows, climate control, stereo, etc.... and it's all run
through a remote control. The receiver is wired to the stamp, and
different buttons give it the different inputs to react from (I geek
out on this stuff cuz I'm an electronics major, but programming
isn't my strong point). I just need code.... code, code, code...
thanks
left, right, left, right) I should have mentioned that... rs4_3_ss
--- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> In a message dated 2/9/2003 12:15:48 PM Pacific Standard Time,
my
if
and
should
things
that
flashes
me
has a
you are on a
stamp or
circuits,
headlight....
consider the
> following...
Stamp?
turn it off
> and on.
the relay
switch at
you switch to
single pole
Your manual
dimmer
> switch.
dimmer
power is routed
beam
> position)
dimmer switch,
the stamp (
program to do
> the following....
switch,
off so the
> low beams are on.
dimmer switch,
to get the
beams are on.
dimmer
delays to
the LOW
> beams are on.
> Loop
> High_Beam
cycled
> Remain_High
beam mode
> leave relay off
> jump to Loop
number, I can
> Ken
> I forgot to add that I wanted the lights to flash side by side (i.e.
> my
> if
> and
> should
> things
> that
> flashes
> me
using the same sensing technique posted earlier, except you will then control
two seperate relays,
I don't use the stamp anymore these days (using the SX) but from what I
remember some code is posted below....
I am almost sure there are some syntax errors and there probably a logic
error, but you should get the jist of what to do......
Assuming you are monitoring the output of the dimmer switch on pin 0, left
relay control is pin 1, and right relay control is pin 2...
Program is shown below
Low_Beam
if pin 0 = 1 then Low_Beam
else Go_High
Go_High
gosub Flash_Low_To_High ;jump to subroutine to flash the lights
pin 1 = 1 ;now left side high beams on
pin 2 = 1 ;now right side high beams on
Wait_For_Low
if pin 0 = 0 then Wait_For_Low
else gosub Flash_High_To_Low
pin 1 = 0 ;low beam on
pin 2 = 0 ;low beam on
goto Low_Beam
Flash_Low_To_High
pin 2 = 1 ;turn on high beam right side
pause 500 ;pause 1/2 second
pin 1 = 1 ;turn on high beam left side
pin 2 = 0 ;turn off high beam right side
pin 1 = 0 ;turn off high beam left side
REPEAT THIS SUBROUTINE A FEW TIMES (you stampers, I know this is ineffecient
but this is just a QUICK AND DIRTY CODE)
return
Flash_High_To_Low
Repeat the above as many times as you want it to flash
return
programming challenge. Would you say to a Professor give me the answers to a
question that I am too lazy to learn how to solve?
In the real world, THINK IT MAY BE A NEW EXPERIENCE.
<chapman@t...> wrote:
> Learn to think logically. Don't expect someone else to solve your
total
answers to a
Think, it may be a new experience... buddy, after three years of
electronics, with one more to go, I think that it should be you
thinking before you run your mouth about something that is none of
your business. The time I have after everything I do for college
leaves me no time to be working on the "the bugs" of a program. and
for your info, if you want to see how lazy I am, we can set up a
meeting between the two of us over email, and I'll show you. Now,
Smile off.
College is alot easier now than when most of us were doing it. Programming
on punch cards and paper tape, typing papers on a typewriter, using a
physical card catalog to do research. I'll bet the classes focus more on the
degree and less on liberal arts too... Sounds like you have it so rough.
Notice the sig line below -- this should apply to life every day
To be conscious that you are ignorant is a great step to knowledge.
-- Benjamin Disraeli
> total
> answers to a
> Smile off.
of the people that frequent this board get paid big $$ to do exactly what
you are asking them to do for free. They spend their time that they could
use to make money helping others like yourself and I for free. Everyone
I've seen on here is more than willing to unlock the door for you, even hold
it open for you. Its up to you to walk through [noparse]:)[/noparse]
Now I've done something along those lines for a haunted house, beam-break
triggered events with alternating flashing lights that returned to a dimmed
state. Not directly related, but basically similar.
I can't speak for everyone on this point though, but I know why some won't
help. Its illegal in most states. Plus they probably have had the same
kind of experience I have had around my home town. The few kids here that
have this kind of thing done to their "show cars" are using them during
burn-out shows in parking lots after 11pm and generally don't behave like
adults with them.
Besides from your last post I can tell the maturity level just isn't there
on your end to make me want to help you.
Rob
Sent: Monday, February 10, 2003 2:29 AM
Subject: [noparse][[/noparse]basicstamps] Re: car lights
> --- In basicstamps@yahoogroups.com, "Stephen H Chapman"
> total
> answers to a
> Smile off.
Sigh... you seem to be expecting someone here to provide you
with debugged code for your project... because you're too busy
to do it?? That's a lot to ask for two reasons. First most of
us are pretty busy too and while we love to provide hints and
ideas and realate personal experience, expecting a turn-key
solution is a bit much to ask. Second, and MOST important IMHO
is the fact that your application has SERIOUS liablilty issues.
Why should any of us assume a major part of this liablity
(for free no less) by writing the code? It really is asking a
lot, don't you agree? I am not interested in being named a
party in a personal injury suit because I supplied code for this
project - sorry but that's life in the USA...
Michael Burr
