Zener diode to control back EMF on Fuel Injector
Hi all, I have a quick question, I was discussing driving electronic
fuel injectors with some of you guys. My stamp is currently being
shipped back to Parallax for repair. I'm building some circuits to
try when it gets back.
Assuming that the injector did fry it back through my NPN driver
transistor, might a 12V zener diode across the injector protect the
stamp from the bigger spikes without affecting turn off time
normally like a straight diode would? Or am I going in the wrong
direction?
Thank you,
Bill
direction?
Thank you,
Bill
the stamp totaly isolated from the driver transitor
there are high speed versions that should work
--- "billakay <billak@f...>" <billak@f...>
> driving electronic
> currently being
> some circuits to
> my NPN driver
> off time
> in the wrong
> direction?
> Thank you,
> Bill
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
kenneth_m_73149@y... writes:
> i would highly recomend using a optoisolator and keep
The opto-isolator is definately the hot ticket....but all of it's gains can
be lost if your stamp and the injector circuit share the same ground.
To get true isolation with the opto-isolator, you will need to power the
stamp from the output of a DC to DC converter. The input power and ground of
the DC to DC converter is isolated from it's output. In this way, you are
completely isolated.....
infinite impedance in the forward direction so all the current flows through
the injector coil and zero impedance in the reverse current flow direction
so the collapsing current shorts to ground rather than back into your stamp.
The zener's variable impedance in the forward direction just complicates
things and I'm pretty sure they generally have a higher reverse impedance
which could leak more current back to the stamp.
I wasn't paying that much attention to the start of this discussion. But
you may want to look at the ULN2003 or similar as a driver. If nothing
else, look at the circuit equivalency diagram in their datasheet and you
will see a conventional diode.
-- Al Margolis, founder
www.hobbyengineering.com
The WEB's newest source for robotics supplies and information
From: billakay <billak@f...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iUA75sxTaGyj1BH42vYGDyl7BVWKD_yVrmVqZvjVIa7Vu6DsOZF2hgqdR0j-IGyERk-WiyQg7A]billak@f...[/url
Sent: Thursday, February 06, 2003 9:59 AM
Subject: [noparse][[/noparse]basicstamps] Zener diode to control back EMF on Fuel Injector
direction?
Thank you,
Bill
