Newbie Programming question
Hello All,
Newbie Bob here with a couple questions, I have a little elect
knowledge and have some plc ladder programming experience.
I would like to design a project that given a certain input will
turn on/off about 20 relays (12 volt very low micro amps ) in a
timed programmed pattern or sequence. It would need several inputs
that would run different programmed patterns.
My question is is this some thing I can do with a stamp ?? and if so
please point me in the right direction, book, examples page, example
program code.
Please keep in mind that I'm a retired Mechanical Engineer and not
to smart with electrons :-). Please keep it simple !!
Bob
program code.
Bob
suggest that you download our StampWorks book and work through the
experiments [noparse][[/noparse]even if just by reading]. StampWorks will help you learn PBASIC
and various methods for handing inputs and outputs that will be appropriate
for your project.
You can download the StampWorks manual from this link:
<A
HREF="http://www.parallax.com/detail.asp?product_id=27297">http://www.parallax.c\
om/detail.asp?product_id=27297</A>
-- Jon Williams
-- Parallax
In a message dated 2/6/2003 8:16:40 AM Central Standard Time, robertp@v...
writes:
> Hello All,
> program code.
> Thanks
> Bob
relay coil. If the signal, I wonder if you really need to use a relay. The
current draw sounds too low for a relay coil.
I'd suggest that you start with a smaller number of relays in order to keep
things simple, controlling one relay with each Basic Stamp output Pin.
Depending on the relay you will need either a transistor or a driver IC such
as ULN2003/ULN2803 between the stamp pin and relay. The transistor circuit
also needs a diode to protect the driver from reverse-EMF from the relay
coil. This diode is built into most driver ICs. When you are ready to step
up to 20 relays, you can either use a multiplexer chip or upgrade to a
BS2P24 or BS2P40 Basic Stamp to get the required pins.
You will get a more specific answer if you describe more of your
application, including what you are trying to accomplish and the part
numbers of any specific components you have or are considering. As an
engineer, you know that the details are what really matter.
Good luck with your project!
-- Al Margolis, founder
www.hobbyengineering.com
The WEB's newest source for robotics supplies and information
From: bobsail_2002 <robertp@v...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FGrnUV9vu2PlEXxR1Bhwq5w-WMXk3eThWPsxxQ6vsDSaJC2SZsqaXChVzSjJz_eLe4PzArp72A]robertp@v...[/url
Sent: Thursday, February 06, 2003 6:15 AM
Subject: [noparse][[/noparse]basicstamps] Newbie Programming question
Hello All,
program code.
Bob
Should be easy beans, even I could do it ;-)
What are you driving with your relays? Driving relays with a Stamp is easy.
If the relay draws more than the Stamp pin can handle, which most
conventional relays do, you will need to operate the relay with a
transistor, or more conviently a device like the ULN2003 Darlignton array. A
diode is required across the coil of the relay to protect the Stamp form the
back EMF genrated when the realy opens/closes.
As you say a "very low micro-amps", perhaps you are using SS relays. If this
is the case, no "silicon steroids" are required for the Stamp to run it, and
no diode is required.
Hope this helps,
Jonathan
www.madlabs.info
> Hello All,
> program code.
> Thanks
> Bob
external one?
Sent: Thursday, February 06, 2003 6:48 AM
Subject: RE: [noparse][[/noparse]basicstamps] Newbie Programming question
> Is "12v / low micro amps" the spec for the signal you are switching or the
The
keep
such
circuit
step
> From: bobsail_2002 <robertp@v...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ErueWxM5EFjAIccfyGU0SCtSAliLnfL--RGpeCGX-ULqrnM1NA5px76LxWSX9zh8vMXe5Fw]robertp@v...[/url
> Hello All,
> program code.
> Thanks
> Bob
built-in with the ULN2003/2803 IC design.
-- Al
From: Pat M [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Zb3SrQIeugPH1Y6SndCpi2jmPZekhfOIwoh0gVmdqyPPMcjzslAuq00EcEiYy0X_S7W62ksp]pmeloy@s...[/url
Sent: Thursday, February 06, 2003 2:49 PM
Subject: Re: [noparse][[/noparse]basicstamps] Newbie Programming question
The ULN2003/2803 already has diodes built in does it not? No need for an
external one?
The
keep
such
circuit
step
> From: bobsail_2002 <robertp@v...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JHk6q8_Z3cyU2YW_fd1WfGX27ywsCl6uc-EjxpteJtPs65S-xf9k_VBV6A0D9l5i77nGUpNGInX7pA]robertp@v...[/url
> Hello All,
> program code.
> Thanks
> Bob
