Dual serial interfaces with Stamp?
I'm a semi-newbie when it comes to interfacing the Stamp and have a
project I am trying to get off the ground.
I am trying to interface both a serial GPS and a Quadravox voice chip
with a BS2p24. Since both communicate via serial and there is only
one comm port on the stamp, what can I do? Do I need another Stamp?
If I can't make it work with one stamp, two might be possible, but
then, I'd have to link the two stamps separately with I/O pins (I
guess?!?).
Help me Obi Wan KenStampcommunity! You're my only hope! Just
kidding, but seriously, I'd really appreciate any advice from the
more experienced posters here. Thanks!
guess?!?).
PBASIC commands and a transceiver chip like the MAX232 to adjust the signal
levels. The "gotcha" is that it is fairly easy to overrun input on the
basic stamp, but that's probably not an issue with this application. The
stamp can definitely handle the GPS and I would anticipate that you will be
mainly outputting to the Quadravox.
If you haven't already seen it, the Parallax site has a very complete sample
GPS application.
-- Al Margolis, founder
www.hobbyengineering.com
The WEB's newest source for robotics supplies and information
From: i1patrick <i1patrick@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=c7sGAK0Ph_7tC0uVimUx1TktmkjjRPCqZ_ZPaOmcixVAoovMn75-EcILIhG4pVVcohPUPmR_HFzz]i1patrick@y...[/url
Sent: Wednesday, February 05, 2003 7:03 PM
Subject: [noparse][[/noparse]basicstamps] Dual serial interfaces with Stamp?
guess?!?).
Its just that the one port is set up for programming and debug use.
> guess?!?).
I am a few weeks ahead of you on the dual serial port thing.
Using the max232 chips works well. Al Williams has a very nice
connector and board interface with the max 232 to speed up the
process greatly.
http://www.al-williams.com/rs1.htm
Thats the good news, I have found the tough part is the max speed the
stamp can input directly. Depending on the commands I have found that
2400 is marginal ans 1200 bps is reliable.
9600 out of the stamp works well with the max232.
The path I am presently going down is using the Max3100 or 3110 uart
buffer. the limitation there is the buffer is only 8 byes deep. For
me I need to test the max 3110 to see if I can dump the buffer fast
enough to grab the next couple of 8 byte groups.
Other great articles talking about the delay times between the ser in
and out comands are:
http://www.emesystems.com/BS2rs232.htm
http://www.phanderson.com/stamp/tutorial_10.html
If you get to the point of needing a max 3100/3110
This is a great reference.
http://www.wd5gnr.com/suart.htm
Brent
--- In basicstamps@yahoogroups.com, Rodent <daweasel@s...> wrote:
> Any Stamp pin can be a serial port -- look at the SERIN and SEROUT
commands.
a
chip
only
Stamp?
> > guess?!?).
anything else with a long string of data), you may want to take advantage of
the BS2p and BS2pe feature that allows a serial stream to be buffered into
the scratchpad RAM. We've done a lot of experimenting with GPS and have
information posted on our web site.
The advantage is that you can capture the whole string and then parse it
after, not having to use serial modifiers (SKIP) to grab data from your
string. In my GPS program for the BS2p, here's the line that captures the
GPS input:
SERIN GPSpin, N4800, 3000, No_GPS_Data, [noparse][[/noparse]WAIT("GPRMC,"), SPSTR 65]
This line will capture 65 bytes of GPS data after the GPRMC header. Once
it's in the scratchpad RAM, it's easier to parse out. Code that we've posted
has routines for parsing data that is in a specific location and there is a
routine that will parse from a specific field in the data (it counts commas
to find the field).
-- Jon Williams
-- Parallax
In a message dated 2/6/2003 8:18:24 AM Central Standard Time,
broyles@i... writes:
> Rodent,
> process greatly.
> Brent
> commands.
> a
> chip
> only
> Stamp?
> >>guess?!?).
To be conscious that you are ignorant is a great step to knowledge.
-- Benjamin Disraeli
> Rodent,
> process greatly.
> Brent
> commands.
> a
> chip
> only
> Stamp?
> > > guess?!?).
