Using Allegro UCN 5833 32-bit driver w/BS2
Does anyone have a code snippet to drive this relay driver IC from
ALLEGRO? I'll be happy to pay/share/swap for some help!
Sincerely,
Wayne w/ VoX Automation,LLC
Sincerely,
>Sincerely,
Hi Wayne,
It's a piece of cake. Shift out the data and then pulse the strobe line.
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
> showdat:
> shiftout Sdata,Sclk,msbfirst,[noparse][[/noparse]X\16] ' send light pattern to UCN5833
> high strobe ' activate it
> low strobe
Wayne,
The above uses only 16 of the outputs.. If you need all 32 outputs...
You can get 64 outputs (or more!), by stringing the "data out" pin
from one '5833 to the "data in" pin of another, and by connecting
together all the clock and strobe lines, then.
-- best regards
Tracy Allen
mailto:tracy@e...
