Display problems
I'am using the BS-2p40 together with a BPI-216 LCD-display. When is
start running the code (see bellow). I can see sometimes a test -
message. Only after 1 second, the display shows only some weird
characters. I've checked the dip-switches on the back, and the seemed
in the good position. I've also tested the same application with
another display, so I dont think that's the problem. Is there maybe
something wrong with my code ?
Hans
'{$STAMP BS2p}
N9600 con $4054
I con 254
CLR con 1
pause 1000
serout 0,n9600,[noparse][[/noparse]I,CLR]
'the display is connected to P0 of the stamp
pause 1
serout 0,n9600,[noparse][[/noparse]"message"]
Hans
'{$STAMP BS2p}
N9600 con $4054
I con 254
CLR con 1
pause 1000
pause 1
herrhanz@y... writes:
> N9600 con $4054
> I con 254
> CLR con 1
> pause 1000
> pause 1
Your code is wrong. Write:
N9600 con 16468 (or the HEX number)For Hans.
I con 254
clr con 1
L1 con 128
L2 con 192
serout 0, N9600, [noparse][[/noparse]I, clr]
serout 0, N9600, [noparse][[/noparse]L1, "Hello"]
serout 0, N9600, [noparse][[/noparse]L2, "Goodbye"]
The test message appears when Vdd is applied to the display serial pin at
startup.
Sid
You are ignoring Line 2 - L2 con 192. The test message will come up if Vcc
is supplied at start up.
Sid
> sometimes a test -
> some weird
Hello Hans,
I don't know if this applies to your setup (Not
familiar with that particular display)...But a few of
the serial displays I have used display a revision
message, or something else during initialization. If
you're using the PIC-N-LCD it displays a revision
message as well...Hope this helps. By the way, if
that is the case, you should still see it when you
power up the LCD by itself.
Knight Designs
324 West Main Street
Montour Falls, NY 14865
(607) 535-6777
http://www.knightdesigns.com
__________________________________________________
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
