Stamp and variables
Archiver
If a stamp looses power while running do the variables get lost? How
would one avoid this?
mains power is lost) or you can save important variables to EEPROM with WRITE
(you can retrieve them with READ).
Note: It is rarely necessary for a program to have to save ALL variables.
-- Jon Williams
-- Parallax
In a message dated 2/2/2003 7:07:48 PM Central Standard Time,
iphillips@s... writes:
You should write data that you wish to retain during power out
periods to the eeprom rather than standard RAM variables. Data
in the RAM area will be lost during power outages.
Our government it seems has got a new plan...
Seize and search the private records of every man.
No warrants, no judges, no due process required,
With "Homeland Security" the 4th Amendment's retired.
"Total Information Awareness" the project is called,
Oh would our forefathers be aghast and appalled!
http://geocities.com/totalinformationawareness/
out the chip?
On Sun, 2 Feb 2003, jonwms@a... wrote:
> Yes. You can prevent power-loss with battery supply (that would kick in when
> -- Jon Williams
> -- Parallax
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
be clever in your design and not waste time resaving variables that haven't
changed.
-- Jon Williams
-- Parallax
In a message dated 2/3/2003 4:03:26 PM Central Standard Time,
lamont@a... writes:
> Is it accurate to say that you can't use write too often without wearing
> out the chip?
byte location for the BS2, less for BS2p. If you write once a
second, you'll wear it out in 115 days. If you write 10 times a
second, you'll wear it out in 11.5 days. You should keep this in
mind when deciding what data is critical, and how often you want to
write it.
I want my hardware to be good for 5 years, so this can be an issue.
And that little 2k or 4k eeprom looks hard to replace.
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> You'll wear out yourself before you wear out the chip. That said,
you should
haven't
> changed.
> -- Jon Williams
> -- Parallax
> lamont@a... writes:
wearing
> > out the chip?
