Can''t get op-amp (LM358) to work.
Subhrajit,
I bet you have it wired wrong if both sides don't work. Those chips are
pretty tough and hard to blow. It could be bad, but I suspect operator
error. That's what it always is with me!
Jonathan
www.madlabs.info
Sent: Friday, January 31, 2003 7:51 PM
Subject: [noparse][[/noparse]basicstamps] Can't get op-amp (LM358) to work.
> Hello,
> I am new to this embedded control stuff, and I am working on my own.
> And I have this problem.... I am working with the Industrial control
> book, and I am trying to implement the 1st ckt in chapter 2.
> The LM358 has it's input tied to a phototransistor whose voltage is
> switching between 4.77 and 4.13 V (measured using multimeter). The
> reference voltage is around 4.52 V. The output of the op-amp remains
> unchanged at around 3.7 V. I tried both the op-amps in the LM358.
> No luck.
> Is the chip bad ? Is there something I should try before getting a
> new chip ?
> Thanks a lot.
> Subhrajit
Jonathan
www.madlabs.info
> Hello,
> No luck.
> new chip ?
> Thanks a lot.
> Subhrajit
