Nixies and Courage
Hi All,
So, I got my Nixie drivers figured out, and got a Nixie all hooked up. The
thing is, I'm trying to build up the courage to hook it up to the Stamp.
Why am I nervous? Because the Stamp will be connected to a SN74141N that is
connected to the Nixies which run on 150VDC! Everyone's schematic that I
have seen does this with no optoisolators. Many of them out there. But it
still makes me nervous, don't want to kiss off a B2SX. Any thoughts?
Jonathan
www.madlabs.info
Jonathan
www.madlabs.info
connects the
+150 VDC to the anode of the your nixies and then the nixies numbers elements
will go to
the nixie driver (7445) the logic connections of the nixie drivers go to stamp.
Because
of the large resistance, the stamp cannot see any appreciable current from the
150VDC. if
you are really worried, 10 volt zeners from logic connections on the stamp and
ground
would guarantee it never sees higher than +10 VDC.
Leroy
Sent: Friday, January 31, 2003 2:48 PM
Subject: [noparse][[/noparse]basicstamps] Nixies and Courage
: Hi All,
: So, I got my Nixie drivers figured out, and got a Nixie all hooked up. The
: thing is, I'm trying to build up the courage to hook it up to the Stamp.
: Why am I nervous? Because the Stamp will be connected to a SN74141N that is
: connected to the Nixies which run on 150VDC! Everyone's schematic that I
: have seen does this with no optoisolators. Many of them out there. But it
: still makes me nervous, don't want to kiss off a B2SX. Any thoughts?
: Thanks,
: Jonathan
: www.madlabs.info
: To UNSUBSCRIBE, just send mail to:
: basicstamps-unsubscribe@yahoogroups.com
: from the same email address that you subscribed. Text in the Subject and Body
of the
message will be ignored.
: Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Put a logic gate between the stamp and the 74141. i.e. An and gate with both
inputs tied together. That way if
things go wrong you smoke a cheap ic instead of the stamp.
Fred
Jonathan Peakall wrote:
> Hi All,
> Thanks,
> Jonathan
> www.madlabs.info
Well, of course I went ahead and hooked it up. Works great, and the Stamp
seems fine. I might put some clamp diodes on as you suggest, just to be
sure.
Thanks for the input.
Jonathan
www.madlabs.info
Sent: Friday, January 31, 2003 1:22 PM
Subject: Re: [noparse][[/noparse]basicstamps] Nixies and Courage
> Actually the grounds should all be tied together and then a large resistor
connects the
elements will go to
stamp. Because
the 150VDC. if
and ground
> Leroy
> From: "Jonathan Peakall" <jpeakall@m...>
> : Hi All,
The
is
it
> : Thanks,
> : Jonathan
> : www.madlabs.info
and Body of the
