Closed loop SERVO control
Hello,
I am triing to write the code for a closed loop-feed back program that reads an
input from a sensor and compensates the neutral servo position so that the servo
moves incrementally until the sensor has a zero reading. My approach so far has
been to use LOOKDOWN tables. My sensor readings are registered as signed decimal
SDEC. One direction would be + and the other - . I am using hobby servos to
control the platform. Does any one have any similar code that I could use a
base.
thx
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now
base.
thx
Do you Yahoo!?
I am trying to writ similar code.
Can you e-mail me what you have already, Mybe we could put our heads
together to crack this problem.
I am Very interested in what we can achieve together !
Snippet of what I have written below:
Sweepright:
Debug cr,"Servo moving right ?",cr
for position= curpos to 214 step 1 'sweep right
increments of 0.36 deg
Pause 250 ' Sweep slowly at speed 1/4 sec
serout signal,n96n,[noparse][[/noparse]sync,servo,position] 'send the
signal
next
Debug " Servo now at Right LOCK" ,cr
pause time
for loop =0 to 5
Debug"Right LED light on for ",DEC loop," second ?"
Debug cr
for loop2 =0 to 1000 'light LED for 5 seconds
low LED1 'Turn on right LED
next
next
high LED1 'Turn off right LED
Pause 250 ' Wait 1/4 second
'debug cls
RETURN
Chris-H
--- In basicstamps@yahoogroups.com, marcos <mmaarrccooss@y...> wrote:
> Hello,
that reads an input from a sensor and compensates the neutral servo
position so that the servo moves incrementally until the sensor has a
zero reading. My approach so far has been to use LOOKDOWN tables. My
sensor readings are registered as signed decimal SDEC. One direction
would be + and the other - . I am using hobby servos to control the
platform. Does any one have any similar code that I could use a base.
> thx
> Do you Yahoo!?
