555 Switching Compared to Stamp — Parallax Forums
edited 2003-01-31 00:53 in General Discussion
I've been researching this ignition coil setup, and found a circuit
where a 555 timer continuously fires an ignition coil using square
waves, switching the current with a large NPN power transistor. My
question is, if the 555 can do it, can the stamp also this this
safely? Or am I better off just going with the MOSFET like some have
suggested?
Bill
    edited 2003-01-29 17:40
    If you're just wanting to fire the ignition coil, there's no point in using
    the Stamp -- use the 555. You could, if you need some logic involved in the
    project, use the Stamp to control/gate the 555.
    -- Jon Williams
    -- Parallax
    In a message dated 1/29/2003 11:10:48 AM Central Standard Time,
    billak@f... writes:
    > suggested?
    > Thanks,
    > Bill
    edited 2003-01-29 19:56
    yes the stamp can do it also.
    but why would you want to?
    do you need to control it for some purpose?
    norm
    >From: "billakay <billak@f...>" <billak@f...>
    >Reply-To: basicstamps@yahoogroups.com
    >Subject: [noparse][[/noparse]basicstamps] 555 Switching Compared to Stamp
    >Date: Wed, 29 Jan 2003 17:09:19 -0000
    >suggested?
    >Thanks,
    >Bill
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    _________________________________________________________________
    Protect your PC - get McAfee.com VirusScan Online
    http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
    edited 2003-01-30 00:36
    Yes, I'm attempting to build a small engine control system, and I
    only need to fire it at a certain time in the cycle. I suppose I can
    also do as someone else suggested, and just use the stamp to turn on
    and off the 555. I guess I'll just see what works. I'm just trying
    not to blow up my next stamp once I get a new one.
    Bill
    --- In basicstamps@yahoogroups.com, "norman doty" <normdoty@h...>
    > norm
    circuit
    have
    > >suggested?
    > >Thanks,
    > >Bill
    Subject and
    edited 2003-01-30 04:11
    In a message dated 1/29/2003 4:37:36 PM Pacific Standard Time,
    billak@f... writes:
    > Thanks
    > Bill
    If you are not going to change the ignition timing (always fire at the same
    point before TDC) I would not recommend the stamp. It is easy to trigger the
    555 based on possible a sensor you will put on the crank shaft.
    If you want details on that aspect, write back to this forum.....
    edited 2003-01-30 16:56
    I do intend to vary the ignition timing based on RPM. I have already
    done a great deal of math, taking into account RPM, engine stroke,
    and a few other factors, and it does seem to be possible for this
    project to work. (There should be enough time for the stamp to keep
    up with the engine and do all of the calculations).
    Perhaps the best option would be to have the stamp simply turn on
    the 555 with a simple transistor, long enough to have it do say 5 or
    10 pulses through the coil, then turn it off. Then the biggest load
    on the stamp would be switching the transistor to give the 555
    power. Does this make sense?
    Bill
    > billak@f... writes:
    I
    can
    turn on
    trying
    > > Thanks
    > > Bill
    the same
    trigger the
    edited 2003-01-30 20:14
    In a message dated 1/30/2003 8:58:28 AM Pacific Standard Time,
    billak@f... writes:
    > Thanks,
    > Bill
    Make perfect sense. I am pretty sure a transistor is not needed to interface
    the stamp to the 555.
    Connect 10k ohms from pin 4 of the 555 to Vcc.
    Connect 0.01 uF cap from pin 4 of the 555 to a stamp output pin.
    Make the stamp pin high.
    When you want to "fire" the 555, make the stamp pin low then high. No delay
    is needed.
    example
    high 6
    low 6 '555 is "fired"
    high 6
    That's it!!!!!!!!!!!!!!!!!!!
    No transistor needed.
    edited 2003-01-30 21:59
    Sounds good to me! So just leave the resistors and everything else
    on the 555 the same as they are in the circuit I am copying, correct?
    Bill
    > billak@f... writes:
    on
    5 or
    load
    > > Thanks,
    > > Bill
    interface
    No delay
    > is needed.
    > example
    > high 6
    > high 6
    In a message dated 1/30/2003 2:00:36 PM Pacific Standard Time,
    billak@f... writes:
    > Bill
    Yes, the circuit I described related to pin 4 it to "fire" the 555.
