Reading switches
This is probably a newbie question but I'm not sure how to read
multiple switches and use the info for a particular application. I am
building a motor control with fwd,rev,go,stop and limit switch. I
understand the loop technique of debouncing-
SwIn VAR InA ' Five inputs, pins 0 - 4
switches VAR Word ' Debounced inputs
GetSwitches
switches = %11111 ' enable all five inputs
FOR x = 1 TO 10
swtches = swtches & ~SwIn ' test inputs
PAUSE 5 ' delay between tests
NEXT
Return
-what I'm stumped by is how to use the info of the switches(ie. look
for just the "Stop" and/or "Limit" switch and use it to stop the
motor). Do you specify a particular bit in the variable "switches"?
Is there a better way to do this? I am using the PAK-V(pre MOSFET H-
bridge) to run the motor to ramp up to speed on a "Start" and visa-
versa on a "Stop". Any help is appreciated. Ian
GetSwitches
FOR x = 1 TO 10
NEXT
Return
Well, there are many ways you might do this. One is you can use
individual variables for each input:
Fwdbutton var in0
Revbutton var in1
If Fwdbutton=0 then go_forward
As you point out, you'll need to debounce.
You can also use the BUTTON command in a loop to provide some
debouncing, delay, and repeat functions.
If you wanted to keep reading them together, you could extract the
information you want with a bitmask:
Fwdbtn con %1
Revbtn con %10
Switches=~SwIn
If Switches & Fwdbtn then go_forward
Hope that gives you some ideas....
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: iphillipsca <iphillips@s...>
> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=e6fvZrPLlH9d6ZnIUpMo2tyepQV6rmRHnFK5AqxThtDXeMBZfyokJSMz00XiQ-lJu32Uz4yuFusMV2yo]iphillips@s...[/url
> Sent: Tuesday, January 28, 2003 2:52 PM
> Subject: [noparse][[/noparse]basicstamps] Reading switches
> GetSwitches
> FOR x = 1 TO 10
> NEXT
> Return
> visa- versa on a "Stop". Any help is appreciated. Ian
> from the same email address that you subscribed. Text in the
Fwd con %1
Rev con %10
Jog con %100
Limitswitch con %1000
Stopswitch con %10000
'code
If Limit = %10000 then stop
If Stopswitch = %1000 then stop
-will this still work when one of the other switches are pressed? For
example a reading when Fwd and the Limit are switched- %1001. Thanks,
Ian
From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7Yl2QFDSsxaTNW7N5Y9OkW1XQ1DEb3dba7Wxw6MlT2pHvBVTXHetQxu6O-HH7-LCXVMtZZiOU-w3]alw@a...[/url
Sent: January 28, 2003 4:03 PM
Subject: RE: [noparse][[/noparse]basicstamps] Reading switches
Hi Ian,
Fwdbutton var in0
Revbutton var in1
Fwdbtn con %1
Revbtn con %10
Switches=~SwIn
Al Williams
AWC
> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aRvWFaYspzXxugIM2gUMYmnkfur53X7eL2D31143N3J9TT7frk0L76MAbLbGrW3_8vTv90MbjVpekEgz5s8]iphillips@s...[/url
> GetSwitches
> FOR x = 1 TO 10
> NEXT
> Return
Sent: January 29, 2003 10:24 AM
Thanks Al. One question though, if for instance I look for a "Limit" by
Fwd con %1
Rev con %10
Jog con %100
'code
If Limit = %1000 then stop
If Stopswitch = %10000 then stop
Ian
From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9iOICNbT2-kK5_SUbAhRuxUi4QYZ6Y6osfSnGpEUDSrTEJrN0yX94oRQ51-fJ8aGvbk06q_H9vC80R2VcQ]alw@a...[/url
Hi Ian,
Fwdbutton var in0
Revbutton var in1
Fwdbtn con %1
Revbtn con %10
Switches=~SwIn
Al Williams
AWC
> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NWa8g-ho7ESsAJEXmP563hqcTl2zX6IhjGoXMQ2va64Ph-OhGx_u4nXF9i-tGjD26i4X2qbZOpw5iQRyB1yI_A]iphillips@s...[/url
> GetSwitches
> FOR x = 1 TO 10
> NEXT
> Return
no. That's why you use the &. Let's say that Limit and Fwd are set at
the same time (%1001).
%1001 = %1000 FALSE (0)
%1001 & %1000 TRUE (because %1000 is not zero)
In3 TRUE (1)
So if you use in0, in1, in2, etc. that sidesteps the whole problem. If
you still want to read a snapshot, use the & operator to mask off the
bits you want to test.
Hope that helps.
Al Williams
AWC
* Limit monitor 8 channels at once
http://www.al-williams.com/awce/pak10.htm
> From: Ian Phillips [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ipsaLGo7LXCprc8oqNCvAV-80SIqPr69BfkvZZRD8qXSxryShoan3qaV8nnnt-NbKfVoY1nqa31eOoQV]iphillips@s...[/url
> Sent: Wednesday, January 29, 2003 9:24 AM
> "Limit" by
> Fwd con %1
> Rev con %10
> Jog con %100
> 'code
> pressed? For example a reading when Fwd and the Limit are
> switched- %1001. Thanks, Ian
> From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KytA3tPhrCdzrGHk8Fua63JBIozYxpw9w6JWqdnoBNxnHZYxO_GNsyXEK9iKpIcDBThNlVF5a9Ci474-Rg]alw@a...[/url
> Hi Ian,
> use individual variables for each input:
> Fwdbutton var in0
> Revbutton var in1
> extract the information you want with a bitmask:
> Fwdbtn con %1
> Revbtn con %10
> Switches=~SwIn
> Al Williams
> AWC
> * Easy RS-232 Prototyping http://www.al-williams.com/awce/rs1.htm
> application. I am
> > GetSwitches
> > FOR x = 1 TO 10
> > NEXT
> > Return
> the Subject
for the the bits within a variable. That is handy. Once the whole
byte is debounced, the order of your if-then statements will
determine the priority.
'{$PBASIC 2.5}
switches var byte ' to read all the switches
stopit var switches.bit4 ' individual bits as part of whole
limit var switches.bit3
jog var switches.bit2
rev var switches.bit1
fwd var switches.bit0
main:
do
switches=inH ' read 5 switches (inA only reads 4)
' more debouncing here
' then tasks...
if stopit then dostopit ' if bit is = 1
if limit then dolimit ' arranged by priority
if ' and so on...
loop
dostopit:
goto main ' I'm not sure if Pbasic 2.5 allows a "loop" here.
dolimit:
goto main
end
BTW, a lot of debouncing can be accomplished with an RCdiode circuit
on the pin input, if you don't want to do it in software.
-- Tracy
>Fwd con %1
>Rev con %10
>Jog con %100
>'code
>Ian
>From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5CaAZs1iBxRj0vmxNBWwJNo2tWtbLwuNinASVFaoE3klC5Mj68hkKyEveZrZXHi77N4bMBMzxqz-EvlPaBQ]alw@a...[/url
>Hi Ian,
>Fwdbutton var in0
>Revbutton var in1
>Fwdbtn con %1
>Revbtn con %10
>Switches=~SwIn
>Al Williams
>AWC
> > [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_Pzs8fqr1k97WMW6k84RvBoPUcuk1pMJAgVidUo4NbR1w3hO1luZzEmPfb27I9zQgnQsbhl1Rq3QJFol]iphillips@s...[/url
> > GetSwitches
> > FOR x = 1 TO 10
> > NEXT
> > Return
Ian
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Az6C82tnV8GMXERUdIrWQJs4xZi5ByoySrOQsnPoof4sEe5Cte3SKPiHRSiyY0Tve1gKEHv21x3uN_Jyk3w]tracy@e...[/url
Sent: January 29, 2003 11:41 AM
Another take.. Pbasic (all versions) allows you to make alias names
'{$PBASIC 2.5}
main:
do
' then tasks...
if ' and so on...
loop
dostopit:
dolimit:
goto main
end
-- Tracy
>Fwd con %1
>Rev con %10
>Jog con %100
>'code
>Ian
>From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gH11jLB_kON7Idyw26Sj3-KiKX1VNJLgRD_hhPeObY4y3oX9SD_zlOGFgMKcnmrI1g5esNtZh3nAN6C55A]alw@a...[/url
>Hi Ian,
>Fwdbutton var in0
>Revbutton var in1
>Fwdbtn con %1
>Revbtn con %10
>Switches=~SwIn
>Al Williams
>AWC
> > [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IbeMPXicysdOMZ1-4qEoklInklN7Obgtfv4f_AxwMAadPlTAxo7iT-9alLHFzgMZIoKcrZlPgvWHx0JsilSTxw]iphillips@s...[/url
am
> > GetSwitches
> > FOR x = 1 TO 10
> > NEXT
> > Return
Stopbtn var in4
Fwdbtn var in0
Etc.
Which was what I led off with. The only reason I can see to go with the
& scheme is if you wanted to look for chords. So you could say:
If buttons & (fwdbtn | revbtn) then
To detect if the forward and reverse button were pushed at once.
Al Williams
AWC
> From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4wGU3c8cKxf_YTJWpxPhv27VwjOn-Dc_JQOzT7nxeKZgWcvOdM-4QhPf25cDhNTNfWPabbn7yevbE2Y]tracy@e...[/url
> Sent: Wednesday, January 29, 2003 10:41 AM
> '{$PBASIC 2.5}
> main:
> do
> ' then tasks...
> if ' and so on...
> loop
> dostopit:
> dolimit:
> goto main
> end
> -- Tracy
> "Limit" by
> >Fwd con %1
> >Rev con %10
> >Jog con %100
> >'code
> pressed? For
> %1001. Thanks,
> >Ian
> >From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VJiXBEVINvx8nuUyt7DPgcPT8_9JZvJRVWw31Y7v4i4_Wzll15gyd__b9XGjjADtDnP1XBtT_HrvxVI]alw@a...[/url
> >Hi Ian,
> >Fwdbutton var in0
> >Revbutton var in1
> >Fwdbtn con %1
> >Revbtn con %10
> >Switches=~SwIn
> >Al Williams
> >AWC
> > > [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EOkYA1_-lm4Yq4HU4j6ed8RSp20wyj8GiHetEqTuIW6zop2iPOS2W42c62882M_R8Soq4-n3JFmPujoBwfc]iphillips@s...[/url
> application. I
> > > am building a motor control with fwd,rev,go,stop and
> limit switch. I
> > > GetSwitches
> > > FOR x = 1 TO 10
> > > NEXT
> > > Return
> switches(ie. look
> "switches"?
> PAK-V(pre MOSFET H-
>Ian
These circuits give about 4 milliseconds of debounce. When the
switch closes or when the voltage goes low, the capacitor discharges
rapidly. When the switch opens, the capacitor recharges slowly. So
if the switch bounces for a millisecond, closing and opening rapidly,
the Stamp does not see it.
The resistor in series from the input to the capacitor slows down the
response to rapid spikes. When the switch closes, it has to stay
closed for at least a fraction of a millisecond before the capacitor
discharges enough to register as low at the stamp input. The noise
might come from the switch mounted a long way from the stamp in an
area where there is a pop noise produced by compressors etc.
Adjust the resistors and capacitor to get the required amount of debounce.
In software debouncing, the stamp looks to be sure that the input is
stable for 2 or more successive readings.
The hardware debouncer is really important if you are using a command
like COUNT or PULSIN, which will happily register every bit of bounce
and noise.
Vdd stamp
| 20k pullup
o---/\/\--o
/\/\--- P0 Stamp
| 2k | 1k protection
o |
switch / ===== 0.22uf
/ o |
o
Vss common
20k
switched '---/\/\--- Vdd
voltage 1N4148 |
input o-/\/\---|<---o-o----/\/\--- P0 Stamp
e.g. 2k | 1k protection
0-5 |
===== 0.22uf
o
o
Vss common
