LM34 temperature sensor
Can this sensor be used without an ADC using an RCTIME command
somehow? If not, do you recommend an ADC to use?
Thank you for any help.
Scott
Scott
I imagine you could use the LM34 with RCTIME. I never have but why not? The
output is a reliable 10mV a degree. How accurate do you need to be? I have
used the LM34 with a LTC1298, worked fine.
Jonathan
www.madlabs.info
Sent: Monday, January 27, 2003 7:09 PM
Subject: [noparse][[/noparse]basicstamps] LM34 temperature sensor
> Scott
>Scott
Hi Scott,
The LM34 is not well suited for use with the RCtime command. The
RCtime command works better with a current source temperature sensor
like the LM334 or the AD592, or with a thermistor.
Analog to digital converters come in many flavors. A good starter
for one channel with scale and offset adjustments is the ADC0831. App
notes are available from Parallax.
-- Tracy
probably go that route.
Scott
Tracy Allen <tracy@e...> wrote:>Can this sensor be used without an
>Scott
Hi Scott,
-- Tracy
from the same email address that you subscribed. Text in the Subject and Body of
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now
