Stamp crapped out? — Parallax Forums
Stamp crapped out?
edited 2003-01-26 23:29 in General Discussion
Hey guys, I got that injector driver circuit working last night, I
was playing with it all last evening, I started messing with it
tonight, and I could hear the injector clicking for a couple
seconds, like it was working correctly, then it stopped. Now the
program recognizes the stamp as connected, but can't download any
programs to it.
What could have happened? I didn't do anything wrong I don't think,
I was just messing with a circuit I had working just fine last night.
Do they have a warranty on these things?
Bill
    edited 2003-01-26 02:05
    In a message dated 1/25/2003 4:54:24 PM Pacific Standard Time,
    billak@f... writes:
    > programs to it.
    > Bill
    Warranty on electronics? I think not......
    Did you have any kind of diode connected across your injector (cathode to +12
    side) to catch inductive spikes when the injector turns off?
    edited 2003-01-26 03:23
    No I didn't have any diode like that...could something have hurt the
    stamp even through the transistor?
    I guess I'll have to order another one, live and learn I guess...
    Bill
    > billak@f... writes:
    I
    any
    > > programs to it.
    think,
    night.
    > > Bill
    (cathode to +12
    edited 2003-01-26 03:34
    Yes, of course, we have a warranty -- but chances are you killed the Stamp,
    it didn't just "Smile out." We've been building them for a long time and we
    test everything that goes out the door. That said, we're not perfect. Call
    our Tech Support group at 916-624-8333 and they'll help you out.
    If you're driving some king of inductive load (coil), you'll want to put a
    fly-back suppression diode in the circuit, or better yet, buffer the Stamp so
    that it's not directly subjected to it.
    -- Jon Williams
    -- Parallax
    In a message dated 1/25/2003 6:54:21 PM Central Standard Time,
    billak@f... writes:
    > programs to it.
    > Bill
    edited 2003-01-26 04:30
    Automotive injector driver circuits do not use a spike suppression diode
    connected across the injector coil, as is often done with relay coils. If
    you watch an injector waveform with a scope, you will see that the spike is
    allowed to go fairly high -- 60 to 80 volts is common. A zener is often
    included in the injector driver to clip the spikes at that level.
    If you connect a diode across the injector winding, you will find that the
    injector stays open MUCH longer after the driver turns off. Some years ago
    I had a "discussion" about this with an acquaintance who had written an
    injector theory article which was published in one of the automotive trade
    magazines. This spike and injector closing stuff was erroneously explained,
    and I ended up cooking up a little experiment to show what happens...
    I programmed a PIC (Stamp would have been fine too) to switch a MOSFET which
    drove an injector for a specific number of 2mS pulses. Using fuel (er... I
    mean non-flammable test fluid) at a constant pressure, I was able to measure
    the total injected quantity in a large graduated cylinder with repeatability
    better than 1%. The MOSFET was rated for 100 volts or more so it handled
    the raw injector spikes just fine. Then I installed a spike suppression
    diode across the injector and ran the test again. MUCH more fuel was
    collected.... and a correction was eventually published.
    So, if you want tight control of your injector, you have to do what the
    automotive industry does - let the spike go fairly high, and use a driver
    transistor that can handle it.
    FYI, unless Parallax has changed their policy "cancelled" Stamps can be
    exchanged for a replacement at about 1/2 the cost of a new one.
    Randy
    www.glitchbuster.com
    edited 2003-01-26 04:39
    In a message dated 1/25/2003 8:28:33 PM Pacific Standard Time,
    randyjones@w... writes:
    > explained,
    > which
    > measure
    > repeatability
    Good information.....I often wondered how that situation was handled. ie, a
    mosfet that can handle the inductive spike....
    You're refering to the flyback spikes? What type of MOSFET were you
    using to drive that injector?
    Bill
    suppression diode
    coils. If
    the spike is
    is often
    find that the
    Some years ago
    written an
    automotive trade
    erroneously
    > > explained,
    happens...
    MOSFET
    > > which
    fuel (er... I
    able to
    > > measure
    > > repeatability
    it handled
    suppression
    fuel was
    what the
    a driver
    handled. ie, a
