Feeding the PAK-VIIIa from a different power source?
I've been trying to cobble together a robotic arm. Using my bs2,
I've been able to move servos, but I'm concerned that the number of
servos I intend to run will draw too much current and blow my stamp.
I read this group avidly, and Al Williams' PAK-VIIIa seemes like the
perfect thing to run multiple servos and free up my stamp to do other
things.
I'm very new to all this, so I'm sure that there's a simple answer to
my question: How do I use a different power source to power my
servos while using the PAK-VIIIa? I'd email Al directly, but I know
he posts here, and this chip does seem like something other stampers
would enjoy seeing info about.
Using only stamp power, I have gotten the PAK to blink an led at
different rates, so I know it works.
Let me go into more detail. My setup is pretty simple. I have a bs2
w/ board of education. I'm powering that with a 9v battery. I have
an adjustable power supply that I purchased from Radio Shack. When I
set that to 4.5v, it meters closer to 5. I tried putting the +/-
from that to my servo, while attaching the pulse line from the PAK
powered by the stamp .. but the servo reacted sluggishly (not like
powering it directly by the stamp), so I'm sure something's wrong
with that. I tried powering the pak from the power supply and having
the stamp only connected to the data lines, but that doesn't seem to
work.
Any suggestions for this poor novice?
things.
work.
Are the two power supplies grounds tied together?
Jonathan
www.madlabs.info
Sent: Saturday, January 25, 2003 8:08 AM
Subject: [noparse][[/noparse]basicstamps] Feeding the PAK-VIIIa from a different power source?
> things.
> work.
the stamps ground? If there's a potential differnce between grounds,
could that be a bad thing? Also, one of the reasons I'm so
interested in using different power sources is, from what I've read
posted in this group, running servos and motors creates a lot of
noise on the line. Wouldn't tying the grounds together allow noise
to cross to the other electronics I'm trying to isolate (for now,
just the bs2 in this case)?
By the way Jonathan, great site you have there. I was just surfing
it on Friday. I went and bought some of the magnets you mention at
Forcefield.
Josh
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
<jpeakall@m...> wrote:
> Hi Josh,
> Jonathan
> www.madlabs.info
> From: <robots@t...>
source?
of
stamp.
the
other
> > things.
answer to
know
stampers
bs2
have
When I
having
to
> > work.
Subject and
I'm no expert, just an experimenter. But the potential difference shouldn't
be a problem, I have done a dual power supply many times with my Stamp, as
often what I want to run is well beyond the Stamp's current or voltage
capability. And I have run into problems as you describe from a loose ground
wire. As far as noise, well, if the grounds have to be connected, and the
connected devices make noise, then you have to deal with
isolating/eliminating the noise.
Try hooking up the PAK to blink the LEDs like you did off the Stamp's
supply, but use both power supplies with the common ground and see what
happens. Then if noise creates problems later, you will know that it
fundamentally works.
Glad you liked the website, motivates me to catch up and post a bunch of
stuff that has been pending!
Jonathan
www.madlabs.info
Sent: Saturday, January 25, 2003 8:10 PM
Subject: [noparse][[/noparse]basicstamps] Re: Feeding the PAK-VIIIa from a different power
source?
> No. So, I should just run a wire from the power supply's ground to
> Forcefield.
> Josh
> > Hi Josh,
> > Jonathan
> > www.madlabs.info
> > From: <robots@t...>
> source?
> of
> stamp.
> the
> other
> > > things.
> answer to
> know
> stampers
> bs2
> have
> When I
> having
> to
> > > work.
> Subject and
I'm not sure that I understand why it worked though. Anyone know of
a good reference explaining this that I can go buy?
Josh
> Josh,
shouldn't
Stamp, as
voltage
loose ground
and the
Stamp's
what
bunch of
> Jonathan
> www.madlabs.info
> From: <robots@t...>
power
> source?
to
grounds,
read
noise
surfing
at
> > Forcefield.
> > Josh
> > > Hi Josh,
> > > Jonathan
> > > www.madlabs.info
> > > From: <robots@t...>
power
> > source?
bs2,
number
> > of
> > stamp.
like
> > the
do
> > other
> > > > things.
> > answer to
my
I
> > know
> > stampers
at
have a
> > bs2
I
> > have
> > When I
the PAK
like
wrong
> > having
seem
> > to
> > > > work.
> > Subject and
Subject and
Remember that a circuit has to be complete for it to work. In order for the
Stamp to send a signal to the PAK, it has to have a complete circuit from
positive to negative. So basically, you were sending a signal from the Stamp
that had no place to go. Tying the grounds together made a complete circuit.
Draw it out and follow the flow, that often helps me.
Why did it work at all? Well, I'm not qualified to explain that, but it is
because of the internal circuitry of the Stamp and the PAK. Maybe someone
who knows more about hardware can jump in and explain this all better.
Anyway, at least it all works so you can have fun :-)
Jonathan
www.madlabs.info
Sent: Sunday, January 26, 2003 11:14 AM
source?
> Connecting the grounds worked. Thanks. [noparse]:)[/noparse]
> Josh
nice).
As an analogy, think of a pitcher and a catcher standing on separate
platforms that move up and down. The goal is to throw the ball between
platforms. The problem is the catcher can only catch the ball when it is
in "the strike zone" -- say from neckline to waistline. The pitcher is
good at throwing, so on the ground, they'd hit every time. But the
pitcher is blindfolded, so all he can do is throw straight ahead.
Now, as the platforms move, the pitcher winds up and throws. Most of the
time, the catcher will be above or below him. So the ball just whizzes
past and nothing happens. Every once in a while the platforms are lined
up close enough to correct that the catcher gets the ball, but not
often.
The platforms in this example are the ground potentials. Say the Stamp's
ground looks like -4V compared to the PAK's. Then when the Stamp puts
out 5V, the PAK would see 1V, which is not enough. When you tie the
grounds together you are forcing the platforms to synchronize.
Ground loops occur when you have different potentials on grounds that
are tied together. That can happen because we think wires are perfect
conductors but they are not. More importantly, they conduct differently
at different frequencies (which is very important for noise
suppression). So if a long ground wire has a resistance of .1 ohm, there
will be a definite difference between ground at one end and ground at
the other end which causes current to flow in the ground. This leads to
all sorts of problems and is something you want to avoid.
One strategy is to try to run grounds in a star pattern, so that the
losses can't build up. There are other ways to approach it, but this is
mostly a problem where grounding is poor (small wire, bad connections)
or in systems with long wires. Google on ground loops for more (Google
is a verb, right?).
Al Williams
AWC
* Special sale almost over...
http://www.al-williams.com/awce
> From: Josh Holcomb <robots@t...>
> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8KyIrAQNA46fyBsclaOLr4RO6KTixkwR4JyC7XSx2fhpnkjNZMIuYNdk0rARjZQnDUGpNkeAD5XKGSy7F93j_yPm]robots@t...[/url
> Sent: Sunday, January 26, 2003 1:14 PM
> Josh
> > Josh,
> shouldn't
> Stamp, as
> voltage
> loose ground
> and the
> Stamp's
> what
> know that it
> bunch of
> > Jonathan
> > www.madlabs.info
> > From: <robots@t...>
> power
> > source?
> to
> grounds,
> read
> noise
> surfing
> at
> > > Forcefield.
> > > Josh
> > > > Hi Josh,
> > > > Jonathan
> > > > www.madlabs.info
> > > > From: <robots@t...>
> power
> > > source?
> bs2,
> number
> > > of
> > > stamp.
> like
> > > the
> do
> > > other
> > > > > things.
> > > answer to
> my
> I
> > > know
> > > stampers
> at
> have a
> > > bs2
> I
> > > have
> > > When I
> the PAK
> like
> wrong
> > > having
> seem
> > > to
> > > > > work.
> > > Subject and
> Subject and
