Quickly switchable switch — Parallax Forums
edited 2003-01-25 23:04 in General Discussion
Hiya, I'm working on the hardware for my small engine controller,
and I'm trying to find something to drive my 12V lines.
I have NPN switching transistors, and when I use it, in the ON
position it works great, but when it's off, it still leaves a
circuit on, but with more resistance. Am I just hooking this up
wrong? Or do these things not actually open the circuit fully?
Im still waiting for my solid state relays to get here, but I've
been thinking, they have a 1ms turn on time, and I think I need to
do better to work with this project.
Bill
    edited 2003-01-25 03:18
    In a message dated 1/24/2003 6:32:18 PM Pacific Standard Time,
    billak@f... writes:
    > Thanks
    > Bill
    The NPN should turn off completely!!!!! How low is the voltage to your NPN
    base input when it should be off?
    Also, it is wise to connect a resistor from the base terminal to ground if
    you want the transistor to turn off as quick as possible. There are other
    factors to make it turn off quickly but this is quick and easy without much
    calculations.......The lower the value the quicker turn off time will be.
    There is some capcitance associated with the base, the resistor from base to
    ground gives a disharge path for the base capacitance
    edited 2003-01-25 14:08
    Well I've hooked up the emitter to ground, the base to pin 8 through
    a resistor (10k I think). and the collector to the - of the 12V
    thing I'm running.
    I have it running as of last night, I don't know what I was doing
    wrong before. It's switching my injector on and off quite nicely.
    I'll try the small resistor from base to ground.
    Do you have any idea what the turn on time is like for these things?
    Bill
    > billak@f... writes:
    controller,
    to
    > > Thanks
    > > Bill
    your NPN
    ground if
    are other
    without much
    will be.
    from base to
    edited 2003-01-25 14:16
    Now I need a way to fire my ignition coil. It seems that simply
    using an NPN and turning the voltage on and off quickly just isn't
    enough to make a spark. What would be a good circuit to maybe keep a
    big cap charged, and when the stamp says so, discharge it through
    the coil? Or won't this help any?
    Bill
    --- In basicstamps@yahoogroups.com, "billakay <billak@f...>"
    through
    > thing I'm running.
    things?
    > Thanks
    > Bill
    > > billak@f... writes:
    > controller,
    up
    I've
    need
    > to
    > > > Thanks
    > > > Bill
    to
    > your NPN
    > ground if
    > are other
    > without much
    > will be.
    > from base to
    edited 2003-01-25 15:55
    ON TO THE IGNITION COIL>......This is alot more critical and difficult to do
    without an expensive current probe.....but generally this is what you want...
    The voltage you produce from the ignition coil to fire your spark plug is
    dependant upon (all other factors being equal) is how QUICKLY you can turn
    off the current in the coil.
    Vout = L delta i / delta t L = inductance, i = current and t is time. So
    with a certain current in the coil, the smaller delta t, the larger the
    voltage produced.
    You will want to use a mosfet transistor for this. probably a "logic" level
    device.
    Go to <A HREF="www.glitchbuster.com">www.glitchbuster.com</A> This guy also
    replies to posts in this forum and
    can probably help you select the mosfet you want.
    For your injector circuit- a mosfet is also desireable, but since you already
    have a PNP working, tune it a little.....
    The turn on time will vary depending on many factors. You will need an
    o-scope to know for sure. However, to achieve the fastest possible turn on
    and turn off time follow these steps...
    First some theory: The more curent you use to "fire" the transistor, the
    faster it will turn on. HOWEVER, the more current the transitor base is
    using to stay on, the slower it will turn off. The idea is to turn it on
    with the mimimum amount of current needed to keep it on, so there is less
    current to "get rid of" when the transistor gets turned off.
    FOR FAST TURN ON TIME.....there are two things to do
    1 Determine the minimum amount of base current (largest possible base
    resistor) that will still cause the transistor to turn on fully to open your
    injector.
    2 Then once you know this value seperate the resistor into two values with an
    approximate ratio of 75/25.
    example......if you determine the largest value base resistor that will work
    is 1000 ohms, get 750 ohms and 250 ohms (although those values are not
    standard, just come close to the 75/25 ratio I mentioned, or even 80/20).
    3 Connect the two resistors in series going to the base of your transitor.
    Connect a tantulum capacitor (~1uf) across the larger base resistor. The plus
    end of the cap towards the stamp end.(stamp pin >>>larger reisistor cap combo>
    >>>>smaller resistor>>>>>transisor base)
    4 AN IMPORTANT CONSIDERATION - verify that the smaller resistor value is not
    so small that the initial current will be too much for the stamp to handle.
    The initial current is approximately equal to.........(5-0.7) / smaller
    resitor value. Thats 5 volts from stamp minus the base emitter voltage drop
    divided by the smaller resitor ---Simple ohms law...
    Theory.......The faster you can get current into the base, the faster the
    transistor will turn on. The capacitor will "temporarily bypass the larger
    base resistor. So when you first command the transistor on, the effective
    base resistance is very small yielding lots of base current and fast turn on
    time. After a very short time, the cap is charged and then the "larger"
    resistor is passing current and the base of the transistor is using the
    minimun current to stay on.
    This will be a balancing act, if the cap is too big, the turn off time will
    be slowed down.
    For the quicker turn off time, connect a small value resistor from the base
    to ground, approximately 1 to 5k ohms. This gives a path to discharge the
    the base current once you command the transitor off.
    Read the transistor type off the package, go to google and type in
    "<Transistor type> datasheet". Works just about every time for me. Though
    ignore anything with "chipdocs" in the address. Its a pay thing and I guess
    they pay the search engines big bucks because they're always on top.
    Sent: Saturday, January 25, 2003 6:08 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Quickly switchable switch
    > thing I'm running.
    > Thanks
    > Bill
    > > billak@f... writes:
    > controller,
    > to
    > > > Thanks
    > > > Bill
    > your NPN
    > ground if
    > are other
    > without much
    > will be.
    > from base to
