Large Voltage Amplification for arbitrary signal generator
I'm in the process of using my Basic Stamp to build an arbitrary signal
generator. I'm going to use it to simulate signals that would be found in a
car. (I'm building automotive test equipment). I've gotten my BS to control
RAM and a DAC through a small CPLD. So I can generate very nice arbitrary
waveforms with the DAC at many frequencies, but my output voltage is limited
to +-5V.
My question to all you super-smart electronics people (I'm just a software
person myself) is this: how can I amplify those +-5V signals to get to
+-100V? The current requirements for the amplifier are very, very, very
small. (Like < 1ma would work just fine - It's only driving a 10MOhm input)
In fact, I couldn't even find equipment that I could buy that would do this!
Are the 'voltage amplifier' modules that anybody sells? It does not have to
be very precise (+-1% of output is more than enough) but it does have to be
fairly fast (I need to be able to reproduce signals that go from 0V to 100V
in about 10us).
Any ideas? Any circuits out there that I can use for ideas?
*Brian
to +-5V.
in about 10us).
*Brian
multiplier networks that are used in television flyback high voltage
circuits. These can generate upwards of 40,000 volts. But, I would think
you could use a similar type of circuit for your application, they do not
offer a lot of current but that seems to be OK for your application. You
might want to give the NTE site a look and see if they have any on there. <A
HREF="http://www.nteinc.com/">
NTE Electronics, Inc. Web Site, Welcome</A>
I hope this will help.
Randy Abernathy
4626 Old Stilesboro Road
Acworth, GA 30101
Phone / Fax: 770-974-5295
E-mail: cnc002@a...
We service, install and repair industrial woodworking machinery
Specializing in SCM / SCMI CNC Panel Saws and Routers
You could use a backlight inverter for your high voltage source. I
believe they output a couple hundred volts at 400Hz frequency. Some
filtering and regulation with a HV Zener and you could easily
generate your high voltage.
For high voltage switches and mux's go to www.supertex.com
http://www.supertex.com/products/selector_guides/100
Some pretty cool stuff there. 200V, 2A, 8 channel analog mux
controlled with 5V logic. They have a micro BGA package if board
space is a consideration. I have interfaced one of these with a
stamp. Code similar to driving a 74HC595. Totally cool.
Jason
--- In basicstamps@yahoogroups.com, Brian Schmalz <brian.s@l...>
signal
found in a
control
arbitrary
is limited
> to +-5V.
software
to
very
10MOhm input)
do this!
have to
have to be
to 100V
> in about 10us).
> *Brian
>in about 10us).
Hi Brian,
There's a clever, relatively cheap circuit in "Art of Electronics",
in connection with linear drive to a piezo actuator (rubber mirror
for a telescope.) It uses a couple of 1 kilovolt, 3 amp mosfets in a
feedback loop with a generic op amp. Gain of 100 volts per volt.
Or, there are high voltage op amps available. The Burr-Brown (now
Texas Instruments) 3584 will provide about 15 milliamps at +/- 150
volts and 50mhz GBW. But they cost around $100 each.
-- Tracy
