Controlling outside load
Archiver
Hi, I'm sort of a newbie at Basic Stamps, I got mine a few years ago
and never did anything with it.
I'm using a Basic Stamp II to build a small engine controller. What
is a common way to control outside loads, such as a fuel injector
which runs on 12V DC? I also need to be able to pulse 12V DC through
a step up coil to make a spark across a spark plug. Currently I'm
planning to use small solid state relays, and pulse them on and off.
I would use a separate 12 volt supply, and simply use the stamp to
switch them.
Is there a better, more civilized way to do this? Would some sort of
digital "driver" be better? I'm not sure how these "drivers" work.
Also, I need a way to detect crankshaft position exactly. I was
thinking of small relay coils mounted beside the shaft, with a small
magnet stuck to the shaft, so when it passes, it induces current in
the coil and tells the stamp to trigger the spark or injection at
the right time.
I am sure there is a better way to do this as well...
I would appreciate any advice I can get on this,
Bill
switch them.
the right time.
Bill
SSR are pretty expensive, and you could use a much less expensive transistor
or mofset or something along those lines.
To detect crank shaft position, how about a tiny NIB magnet and a Hall
sensor.
Jonathan
www.madlabs.info
Sent: Wednesday, January 22, 2003 7:34 AM
Subject: [noparse][[/noparse]basicstamps] Controlling outside load
> switch them.
> the right time.
> Thanks
> Bill
the company that makes them.
Would a MOSFET or transistor react faster? I think the reaction time
on these relays is like 1 ms.
About the Hall sensor, now that I think about it, I think Chrysler
used them to tell when their 2.2 and 2.5 liter "K" car type and
minivan engines were turning. They put it in the distributor I think.
Where do you guys buy your electronic components like this? Radio
Shack doesn't have Smile anymore.
Bill
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
<jpeakall@m...> wrote:
> Bill,
transistor
Hall
> sensor.
> Jonathan
> www.madlabs.info
> From: <billak@f...>
ago
What
through
off.
to
> > switch them.
sort of
work.
small
in
> > the right time.
> > Thanks
> > Bill
Subject and
billak@f... writes:
> switch them.
> the right time.
> Thanks
How many cylinders?....With the correct interface hardware (will get to that
later) the stamp can drive your loads, injectors, read your inputs (CKP
sensor) etc.
However, the BS2 may not be "fast" enough to run the engine, especially at
higher RPM.
Also, the stamp basically can do only one thing at a time. What I mean is it
will be a challenge to continuously read the CKP sensor, cylinder #1 sensor,
then perform "interrupts" to pulse the ignition coil, injectors and any other
solenoids etc.
The BS2 SX will probably be fast enough but you will still have the challenge
of the Stamp doing one thing at a time.
If you still want to pursue your project, write back. The hardware interface
to convert CKP into TTL (a signal the stamp can interpret), and the hardware
to interface your injectors, and ignition coil to the stamp is not too
difficult.......
Ken
billak@f... writes:
> Thanks,
> Bill
<A HREF="www.digikey.com">www.digikey.com</A>
<A HREF="www.allied.com">www.allied.com</A>
<A HREF="www.mouser.com">www.mouser.com</A>
I figured since I'm only concerned with one cylinder, I should be
able to pull it off, as long as my external components react fast
enough. I have managed to make a spark happen, and signal my
injector, but because the SSR i was using had a 35 ohm drop on the
12 volts to the coil and injector it was a very weak spark and the
injector hardly just clicked. I have a set of free SSRs on the way
with 0.7-1 ohm resistance.
What do you have in mind for interfacing it? Have you done something
like this before? I have been thinking about it for a while and I
think it is possible enough to pursue. I will obviously need two
crankshaft position sensors, one to signal ignition time and one to
signal injection time. They will be at maximum advance, and the
stamp will have to be timing it.
Bill
--- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> In a message dated 1/22/2003 7:36:39 AM Pacific Standard Time,
> billak@f... writes:
ago
What
injector
through
I'm
off.
to
> > switch them.
sort of
work.
small
in
at
> > the right time.
> > Thanks
get to that
(CKP
> sensor) etc.
especially at
> higher RPM.
mean is it
#1 sensor,
and any other
> solenoids etc.
the challenge
interface
the hardware
too
> difficult.......
> Ken
Give us some deatails on the motor, operating RPM range and so on.
Jonathan
Sent: Wednesday, January 22, 2003 8:34 AM
Subject: [noparse][[/noparse]basicstamps] Re: Controlling outside load
> Well it's only a one cylinder engine. I thought about the speed, but
> Thanks,
> Bill
> > billak@f... writes:
> ago
> What
> injector
> through
> I'm
> off.
> to
> > > switch them.
> sort of
> work.
> small
> in
> at
> > > the right time.
> > > Thanks
> get to that
> (CKP
> > sensor) etc.
> especially at
> > higher RPM.
> mean is it
> #1 sensor,
> and any other
> > solenoids etc.
> the challenge
> interface
> the hardware
> too
> > difficult.......
> > Ken
stock is 3600 RPM. If you run it faster than this stock it will most
certainly throw the connecting rod through the side of the block.
One I get this running, if possible I would like to make it turn
faster. (This can be accomplished safely by installing a high
strength racing connecting rod). But for now I'd like to have it
able to turn 3600 RPM. Idle is from 1000-1500 usually. Common
clutches engage at 2000 RPM.
The reason I think it should be feasable is bacause since it is only
one cylinder, nothing will have to be happening simultaneous,
everything will be sequential. So if my stamp and my hardware
interfaces can react fast enough it will work.
Also, like most cars today it will not be a problem that injection
and ignition will also occur on the opposite stroke that it needs
to. In electronically controlled automobiles, this is known
as "waste spark" and "waste injection". For example, ignition can
occur on both combustion and exhaust stroke. The fuel is not really
wasted though, it carries over into the next compression and
combustion cycle. Many four cylinder cars pair up spark plugs and
injectors for this reason, even though only one cylinder fires at a
time.
Bill
> Bill,
> Jonathan
> From: <billak@f...>
but
the
the
way
something
to
> > Thanks,
> > Bill
> > > billak@f... writes:
years
> > ago
controller.
> > What
> > injector
> > through
> > I'm
and
> > off.
stamp
> > to
> > > > switch them.
> > sort of
> > work.
was
a
> > small
current
> > in
injection
> > at
> > > > the right time.
> > > > Thanks
(will
> > get to that
inputs
> > (CKP
> > > sensor) etc.
> > especially at
> > > higher RPM.
What I
> > mean is it
cylinder
> > #1 sensor,
> > and any other
> > > solenoids etc.
> > the challenge
hardware
> > interface
> > the hardware
not
> > too
> > > difficult.......
> > > Ken
Subject and
billak@f... writes:
> Thanks,
I just moved into a new office and can't find my documentation. Once settled
in I can give you some advice on driving the injector using a MOSFET and same
for the ignition coil, or are you using a magneto?
> Well the motor is a one cylinder four stroke engine. Redline RPM at
> time.
with these motors. I have a vintage Fox minibike that I ride around
in the summer [noparse]:)[/noparse] It's a Tecumseh 3 horsepower flathead motor, but if
I get this working, I might switch over to a bigger and/or more
efficient engine like a overhead valve or overhead cam model.
Bill
--- In basicstamps@yahoogroups.com, Rodent <daweasel@s...> wrote:
> So are you doing the junior dragster thing?
at
most
only
injection
really
at a
> > time.
http://www.newark.com
http://www.mouser.com/
http://www.herbach.com/
Sent: Wednesday, January 22, 2003 8:11 AM
> Well I'm getting free "samples" of the SSR I was going to use from
> Thanks,
> Bill
> > Bill,
> transistor
> Hall
> > sensor.
> > Jonathan
> > www.madlabs.info
> > From: <billak@f...>
> ago
> What
> through
> off.
> to
> > > switch them.
> sort of
> work.
> small
> in
> > > the right time.
> > > Thanks
> > > Bill
> Subject and
