Out of Memory!
How can I increase the amount of EEPROM on my BS2. I am current out
of room in my program. Is there a different stamp that will give me
room for program space? how much would give me over the BS2?
Al
Al
eight, 2k blocks. There is an article posted on our web site on a strategy
for managing a program spread across two or more blocks.
-- Jon Williams
-- Parallax
In a message dated 1/21/2003 7:45:43 AM Central Standard Time,
brownstamp@y... writes:
8 memory banks to 2k EEPROM each.
The BS2e is the cheapest solution if you just need more space.
The BS2sx and BS2p are also faster and you may have to adjust timing
constants in your program - this is not neccessary with the BS2e.
The BS2pe is a low power consuption version of the BS2p (slower but
still faster than the BS2).
There is a method to call subroutines across memory banks and passing
parameters. See "Cross bank calls" at
http://www.emesystems.com/BS2SX.htm for details.
Regards
Adrian
I highly recommend you spring for the BS2p or the BS2pe if you want
to make the best use of multiple program banks. Those Stamps have
the STORE command that gives them the unique capability to READ and
WRITE data across the banks. That data can be setup parameters,
logged data, LCD displays or command prompts, script files, or even
programs transferred from bank to bank (as in from a modem or radio
link). To repeat--get the BS2p or pe!!
I have more information about the BS2pe posted at this URL:
http://www.emesystems.com/bs2pe.htm
-- best regards
Tracy Allen
mailto:tracy@e...
>>Al
>You can use any of the BS2e, BS2sx, BS2p or BS2pe. They all have
>Regards
>Adrian
I don't want to be cantankerous but I have a question as to why the
BS2e, BS2sx, BS2p and the BS2pe can allocation 16k of program/data
space but only in 2k memory blocks? Wouldn't it be more prudent to
allocate all 16k at once?
Just curious.
-Dustin
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> You can use a BS2e, BS2sx, BS2p or BS2pe and get 16K of program
space as
strategy
> -- Jon Williams
> -- Parallax
out
me
keep code compatible between them, we had to maintain this limit. The
next-generation BASIC Stamp will break this barrier.
-- Jon Williams
-- Parallax
In a message dated 1/21/2003 12:08:41 PM Central Standard Time,
stamp@d... writes:
> Hey,
> Just curious.
> -Dustin
> The BS2-family interpreter architecture is limited to 2k blocks.
In order to
The
> -- Jon Williams
> -- Parallax
> stamp@d... writes:
> > Hey,
the
program/data
to
> > Just curious.
> > -Dustin
Sent: Tuesday, January 21, 2003 10:30 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Out of Memory!
> The BS2-family interpreter architecture is limited to 2k blocks. In order
to
> -- Jon Williams
> -- Parallax
