There is no magic number. You need to know the size of the wire, voltage
drop, ampacity of the wire, etc,etc.
20 GA copper may be only 20 feet, and a 4/0 superconductor may be 1million
miles.
What kind of length are you looking for. Another length problem is noise on
the conductor.
Sorry this isn't a good answer, but the question is like asking how much
sunlight does it take to boil water?
Alan Bradford,
Plasma Technologies
Probably 100' or more for a very low current signal. I would
definately clamp the I/O pin to +5 and GND with 1N4148 diodes and add
a 100 ohm series resistor to dampen out and ringing on the line.
Basically a long wire acts like a LC tank circuit so you definately
could generate a voltage spike large enough to smoke your I/O pin.
Jason
--- In basicstamps@yahoogroups.com, "iphillipsca <iphillips@s...>"
<iphillips@s...> wrote:
> Does anyone know what the max length of wire would be that you
could
> use for a switch or a pot to the stamp?
> Ian
miles.
the conductor.
Alan Bradford,
Plasma Technologies
Jason
could
> Ian
