Interfacing a Stamp with AC devices (not relays) — Parallax Forums
edited 2003-01-23 00:26 in General Discussion
Hi All,
I want my Stamp to know when an independently operating AC device is
energized. In the past, I have done some hokey stuff like Hall sensors, but
for this project I want a "grown-up" solution. Ideas that have occured to me
are:
Torrodial xfrmr, rectifier, Stamp
Diode (1/2 wave rec.), voltage divider, Stamp
Diode (1/2 wave rec.), zener, Stamp
Various combinations of the above.
How do the big kids do this? I'd like a simple and cheap solutions, but is
there a nice IC or other device that does this?
Jonathan
    edited 2003-01-20 00:16
    5v dc power supply? (wall-wart style)
    is simple and safe (UL approved even)
    Sent: Sunday, January 19, 2003 7:10 PM
    Subject: [noparse][[/noparse]basicstamps] Interfacing a Stamp with AC devices (not relays)
    > Hi All,
    but
    me
    > are:
    > Thanks,
    > Jonathan
    edited 2003-01-20 00:38
    There are a number of ways to do this
    1 step-down transformer you could check voltage with this
    2 current transformer and you could check the current used
    3 opto isolator just read the state
    4 Hall sensor Guess you could look for movement as well
    5 I think with a diode and large resistors you can hook up
    to a 100, 200 volt line direct per the pic book
    Microchip not the best Idea.
    6 some motor contactor's or start switches have extra
    contacts use them
    7 someone else can fill this in
    Sent: January 19, 2003 4:10 PM
    (not relays)
    : Hi All,
    : I want my Stamp to know when an independently operating AC
    device is
    : energized. In the past, I have done some hokey stuff like
    Hall sensors, but
    : for this project I want a "grown-up" solution. Ideas that
    have occured to me
    : are:
    : Torrodial xfrmr, rectifier, Stamp
    : Diode (1/2 wave rec.), voltage divider, Stamp
    : Diode (1/2 wave rec.), zener, Stamp
    : Various combinations of the above.
    : How do the big kids do this? I'd like a simple and cheap
    solutions, but is
    : there a nice IC or other device that does this?
    : Thanks,
    : Jonathan
    : To UNSUBSCRIBE, just send mail to:
    : basicstamps-unsubscribe@yahoogroups.com
    : from the same email address that you subscribed. Text in
    the Subject and Body of the message will be ignored.
    : Your use of Yahoo! Groups is subject to
    edited 2003-01-20 00:44
    I used a relay - HA1-115V. Its 115V on coil and contacts but I just ran 5V
    though the contacts - that should extend their life just a weeee bit over
    the 115V rating. There are probably smaller relays or even optocouplers that
    can do the same thing - the HA1 was what was available in town (that I could
    find).
    Sent: Sunday, January 19, 2003 4:10 PM
    > Hi All,
    but
    me
    > are:
    > Thanks,
    > Jonathan
    edited 2003-01-20 01:30
    Larry,
    Is there such a thing as an AC optoisolator?
    Jonathan
    Sent: Sunday, January 19, 2003 4:38 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Interfacing a Stamp with AC devices (not relays)
    > contacts use them
    > From: "Jonathan Peakall" <jpeakall@m...>
    > (not relays)
    > : Hi All,
    > device is
    > Hall sensors, but
    > have occured to me
    > : are:
    > solutions, but is
    > : Thanks,
    > : Jonathan
    edited 2003-01-20 06:54
    Check out a Crydom MIAC5...senses 90-140VAC and gives
    you a isolated TTL output. Clean and cheap. I have
    used them on quite a few projects with total success.
    Lew M
    --- Jonathan Peakall <jpeakall@m...> wrote:
    > Hi All,
    > are:
    > Thanks,
    > Jonathan
    __________________________________________________
    Do you Yahoo!?
    Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
    http://mailplus.yahoo.com
    edited 2003-01-20 14:14
    The easiest and safest way is to use a Solid State Input Module. Opto-22
    makes them. The generic number is IAC-5. They look like the Solid State Relay
    Modules but are Input Modules. They look for 90-140 VAC in and output a 5
    volt signal.
    The Standard Type has a Screw through them to attach to the PC Board.
    The Mini type do not require a threaded connector on the PC Board. I use this
    type in my Industrial Control Projects.
    <A HREF="www.digikey.com">www.digikey.com</A>
    IAC-5 Modules Grayhill Part # 70M-IAC5 Digikey Part # GH7026-ND
    These modules are UL approved for Electrical Isolation.
    Using a 115 VAC Power relay with 5 volts switched through the contacts will
    work, but over time the contacts will glaze over. The 5 Volt signal does not
    allow enough current to flow too keep the contacts clean. If you want to use
    a relay then find one with a very low contact rating.
    Hope this helps,
    Alan Bradford
    Plasma Technologies
    edited 2003-01-20 15:59
    Here is a data sheet for a chip in the jameco catalog that
    will sense from 5 v to 240 v AC or DC
    http://www.fairchildsemi.com/ds/HC/HCPL-3700.pdf
    Sent: January 19, 2003 10:54 PM
    : Check out a Crydom MIAC5...senses 90-140VAC and gives
    : you a isolated TTL output. Clean and cheap. I have
    : used them on quite a few projects with total success.
    : Lew M
    : --- Jonathan Peakall <jpeakall@m...> wrote:
    : > Hi All,
    : > I want my Stamp to know when an independently
    : > operating AC device is
    : > energized. In the past, I have done some hokey stuff
    : > like Hall sensors, but
    : > for this project I want a "grown-up" solution. Ideas
    : > that have occured to me
    : > are:
    : > Torrodial xfrmr, rectifier, Stamp
    : > Diode (1/2 wave rec.), voltage divider, Stamp
    : > Diode (1/2 wave rec.), zener, Stamp
    : > Various combinations of the above.
    : > How do the big kids do this? I'd like a simple and
    : > cheap solutions, but is
    : > there a nice IC or other device that does this?
    : > Thanks,
    : > Jonathan
    : __________________________________________________
    : Do you Yahoo!?
    : Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
    : http://mailplus.yahoo.com
    edited 2003-01-20 16:24
    Lew and Allan,
    Thanks, those were the type of unit I was looking for. Awful expensive
    though. I wonder why they cost so much. I may have to use a kludge, these
    units would double the project cost. Or maybe I'll dig deep. In either case,
    thanks for the info!
    Jonathan
    www.madlabs.info
    Sent: Monday, January 20, 2003 6:14 AM
    Relay
    > volt signal.
    this
    will
    not
    use
    > Hope this helps,
    > Alan Bradford
    > Plasma Technologies
    edited 2003-01-20 16:36
    Larry,
    Perfect, and at a good price! Thanks for the information!
    Jonathan
    www.madlabs.info
    Sent: Monday, January 20, 2003 7:59 AM
    > From: "Lew Muller" <lewmu@y...>
    > : Lew M
    > : > Hi All,
    > : > are:
    > : > Thanks,
    > : > Jonathan
    > : Do you Yahoo!?
    edited 2003-01-20 16:46
    Larry,
    Looking at the data sheet for the HCPL-3700, it says:
    8. In applications where dV cm /dt may exceed 50,000 V/µs (Such as static
    discharge), a series resistor, R CC , should be included to
    protect the detector chip from destructive surge currents. The recommended
    value for R CC is 240 $ per volt of allowable drop in
    V CC (between pin 8 and V CC ) with a minimum value of 240 $.
    Now, if I am reading this right, I can use the minimum resistor value of
    240Ohms, correct?
    Thanks again,
    Jonathan
    www.madlabs.info
    > : Lew M
    > : > Hi All,
    > : > are:
    > : > Thanks,
    > : > Jonathan
    > : Do you Yahoo!?
    edited 2003-01-20 17:22
    The biggest reason for the cost is the Lawyers that were on the design team.
    When working with AC line powered circuits you need to look very closely at
    isolation, for personal safety and circuit safety.
    When building an Operators control station, there can be no 120 VAC on any of
    the Switches, Controls or Lamps. If your 120 VAC sensing circuit is not
    properly isolated, then even if you have 5VDC switches, you can have a
    serious voltage hazard to personnel.
    Using a UL Approved device saves lots of headaches in the design stage.
    Remember, $10 for an Isolated Input Device is much cheaper than a Good Boston
    Injury Lawyer.
    Alan Bradford
    Plasma Technologies
    edited 2003-01-20 18:34
    use Opto22 G4 modules. The AC input modules are here:
    http://www.opto22.com/Datasheets/0251_G4_Digital_AC_Inputs.pdf
    > Larry,
    > Jonathan
    > From: "Larry Gaminde" <lgaminde@t...>
    > with this
    > current used
    > movement as well
    > can hook up
    > book
    > extra
    > > contacts use them
    > devices
    > > (not relays)
    > > : Hi All,
    > operating AC
    > > device is
    > stuff like
    > > Hall sensors, but
    > Ideas that
    > > have occured to me
    > > : are:
    > and cheap
    > > solutions, but is
    > > : Thanks,
    > > : Jonathan
    > Text in
    > ignored.
    > Text in the Subject and Body of the message will be
    > ignored.
    Do you Yahoo!?
    edited 2003-01-20 22:04
    Pricey due to the UL listing and that its for industrial control.
    (try Allen Bradley prices. They are thieves with theeir hand out for
    *EVERYTHING*)
    How about a rectifier and then a Zener? A bit cheaper.
    --- In basicstamps@yahoogroups.com, "Jonathan Peakall"
    > Lew and Allan,
    expensive
    these
    either case,
    edited 2003-01-20 23:08
    Hmmm... I'm confused. According to this reasoning my house is
    apparently a very unsafe place as I've got 120 VAC on switches
    and lamps all over the place... all with the blessings of the
    NEC btw. So what's so different about an operator's console??
    Michael Burr
    edited 2003-01-20 23:33
    No.
    Your house is safe because the National Electrical Council, the main code
    enforcement in the US has different standards for residential wiring. Your
    house, does not see the use as an industrial application. Translation:
    Different set of Lawyers wrote the rules.
    OSHA, in the US, doesn't have jurisdiction in your house so they make the
    industrial people pay for this little transgression. Translation: Different
    Government agencies don't have to play by the same rules, even though
    electricity is the same throughout the universe.
    Hmmm... I'm confused.· According to this reasoning my house is
    NEC btw.· So what's so different about an operator's console??
    Michael Burr
    team.
    of
    edited 2003-01-21 00:06
    > No.
    Alan, I don't mean to be argumentative here, but it was you (in
    your original post) who preceeded your statement that there can
    be no 120 VAC on switches or lamps in operator's consoles with
    the following statement:
    "When working with AC line powered circuits you need to look
    very closely at isolation, for personal safety and circuit safety."
    You seem to have implied there that it _IS_ a safety concern...
    so I asked what's the difference between that and a house. Now,
    you seem to be implying that it is not really a safety concern
    and the requirements are due to "Lawyer's who wrote the rules"
    (although I doubt lawyers actually wrote the rules... perhaps
    you mean 'bureaucrat'). So I remain confussed as to what point
    you were trying to make. Do you consider the practice dangerous
    or merely not in compliance with the rules?
    Michael Burr
    edited 2003-01-21 00:11
    I'll bet what he is trying to say is there are enough people
    on the list who blow things up with 5 volts so to give
    anyone advice about 120 plus voltage is really stupid, All I
    can say is it will smoke faster with higher voltage so go
    for it. ( you may be it)
    Sent: January 20, 2003 4:06 PM
    : plasmastamp@a... wrote:
    : > No.
    : > Your house is safe because the National Electrical
    : > enforcement in the US has different standards for
    : > house, does not see the use as an industrial
    : > Different set of Lawyers wrote the rules.
    : Alan, I don't mean to be argumentative here, but it was
    you (in
    : your original post) who preceeded your statement that
    there can
    : be no 120 VAC on switches or lamps in operator's consoles
    with
    : the following statement:
    : "When working with AC line powered circuits you need to
    look
    : very closely at isolation, for personal safety and circuit
    safety."
    : You seem to have implied there that it _IS_ a safety
    concern...
    : so I asked what's the difference between that and a house.
    Now,
    : you seem to be implying that it is not really a safety
    concern
    : and the requirements are due to "Lawyer's who wrote the
    rules"
    : (although I doubt lawyers actually wrote the rules...
    perhaps
    : you mean 'bureaucrat'). So I remain confussed as to what
    point
    : you were trying to make. Do you consider the practice
    dangerous
    : or merely not in compliance with the rules?
    : Michael Burr
    edited 2003-01-21 05:08
    Let's take a simple 120VAC lamp for example. You know. of course, that the plug
    that goes
    to the outlet has two spades, one of which is normally hot (120VAC) with respect
    to earth
    ground and the other isn't? This plug will usually enter into an outlet in one
    direction
    only? The small blade is the hot one, connects to the black wire inside the
    outlet, the
    large one is called neutral, connected to the white wire inside the outlet.
    Inside the
    lamp where these two wires connect to a light bulb is important. We normally
    connect the
    neutral wire to the outside screw base of the bulb connection. Switch this, so
    that the
    hot wire is connected here, and what happens? Some poor unsuspecting soul is
    changing a
    light bulb standing on a damp concrete floor with bare or wet feet feet. Soon
    as the bulb
    is unscrewed from the socket they touch the screw base of the bulb where it
    connects to
    the lamp holder and then find out what happens after this life time, as they are
    electrocuted. This is not to say that one cannot connect 120VAC devices to
    common
    connections, it is just to say if you do, make sure you know the details.
    Usually someone
    with no experience, doesn't know enough to ask the proper questions to avoid a
    very costly
    mistake.
    Hope this helps,
    Leroy
    Sent: Monday, January 20, 2003 7:11 PM
    : I'll bet what he is trying to say is there are enough people
    : on the list who blow things up with 5 volts so to give
    : anyone advice about 120 plus voltage is really stupid, All I
    : can say is it will smoke faster with higher voltage so go
    : for it. ( you may be it)
    : From: "Michael Burr" <mburr@b...>
    : To: <basicstamps@yahoogroups.com>
    : Sent: January 20, 2003 4:06 PM
    : Subject: Re: [noparse][[/noparse]basicstamps] Interfacing a Stamp with AC
    : devices (not relays)
    : : plasmastamp@a... wrote:
    : : > No.
    : : > Your house is safe because the National Electrical
    : Council, the main code
    : : > enforcement in the US has different standards for
    : residential wiring. Your
    : : > house, does not see the use as an industrial
    : application. Translation:
    : : > Different set of Lawyers wrote the rules.
    : : Alan, I don't mean to be argumentative here, but it was
    : you (in
    : : your original post) who preceeded your statement that
    : there can
    : : be no 120 VAC on switches or lamps in operator's consoles
    : with
    : : the following statement:
    : : "When working with AC line powered circuits you need to
    : look
    : : very closely at isolation, for personal safety and circuit
    : safety."
    : : You seem to have implied there that it _IS_ a safety
    : concern...
    : : so I asked what's the difference between that and a house.
    : Now,
    : : you seem to be implying that it is not really a safety
    : concern
    : : and the requirements are due to "Lawyer's who wrote the
    : rules"
    : : (although I doubt lawyers actually wrote the rules...
    : perhaps
    : : you mean 'bureaucrat'). So I remain confussed as to what
    : point
    : : you were trying to make. Do you consider the practice
    : dangerous
    : : or merely not in compliance with the rules?
    : : Michael Burr
    : : To UNSUBSCRIBE, just send mail to:
    : : basicstamps-unsubscribe@yahoogroups.com
    : : from the same email address that you subscribed. Text in
    : the Subject and Body of the message will be ignored.
    : : Your use of Yahoo! Groups is subject to
    : http://docs.yahoo.com/info/terms/
    : from the same email address that you subscribed. Text in the Subject and Body
    of the
    : Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2003-01-21 11:22
    The answer is Yes to the regulations. O do not know the source of the
    regulations prohibiting 120 VAC on Operators controls, but all my customers
    ask for that to satisfy OSHA Inspectors.
    Industrial equipment is used harder than home equipment. It is your home and
    you take better care of your own stuff. Industrial equipment is used by many
    conscientious workers, but there are some out there that done care. I have
    worked on systems where operators have been pushing buttons with the chipping
    hammer, that they already have in their hands. The hammer is used to clean
    metals just cut.
    Like the woman who sued McDonalds over a Hot Cup Of Coffee, lawsuits, workers
    Comp, and OSHA visits, have made the workplace regulations different than at
    home.
    I hope this clears things up. It was what I was thinking, I just didn't write
    it good enough.
    Alan Bradford
    Plasma Technologies
    edited 2003-01-21 19:50
    You've obviously never owned rental properties :^) You've still
    got your idiots and your jerks that just don't give a damn
    because it's not their property... I'm lucky one house didn't
    burn down! And of course you've also got infants and children
    in the home which you don't have in the workplace environment.
    So while I understand your point, I still don't understand the
    need for such a distinctly different standard in general...
    unless the console is in a very damp environment perhaps.
    edited 2003-01-21 20:01
    Yeah, I understand residential wiring - did most of my own home,
    but I don't see what this has to do with the large descrepancy
    between 120 VAC wiring in the home vs an operator's console.
    IMHO, it's more likely for a homeowner to replace a switch than
    a console operator will tear into his console... he's just there
    to operate it and in an industrial enviroment there are almost
    always electricians on staff to 'fix' things.... and they ought
    to be safer around 120 VAC than the average homeowner. So why
    do they need a more conservative standard than a homeowner?? I
    just don't get it...
    plug that goes
    respect to earth
    one direction
    outlet, the
    Inside the
    connect the
    so that the
    changing a
    as the bulb
    connects to
    are
    common
    Usually someone
    very costly
    > mistake.
    > Hope this helps,
    > Leroy
    > : : > No.
    > : you (in
    > : there can
    > : with
    > : look
    > : safety."
    > : concern...
    > : Now,
    > : concern
    > : rules"
    > : perhaps
    > : point
    > : dangerous
    > : : Michael Burr
    Body of the
    Our government it seems has got a new plan...
    Seize and search the private records of every man.
    No warrants, no judges, no due process required,
    With "Homeland Security" the 4th Amendment's retired.
    "Total Information Awareness" the project is called,
    Oh would our forefathers be aghast and appalled!
    http://geocities.com/totalinformationawareness/
    edited 2003-01-21 20:11
    Really I think by using low voltage you get around UL type
    listings and such. Many console's are 120 volt. I personally
    built control's for hospital equipment used in Surgery and
    Central Supply area's and they were 120, 240 volt systems,
    but I was remanufacturing so FDA had no control over this.
    If I were to take a unit from one hospital then
    remanufacture it and sell it to another hospital then the
    FDA would require UL and a number of other tests and
    certifications. In other words its a way around getting UL
    and other type listings and going through testing
    procedures.
    Sent: January 21, 2003 12:01 PM
    : Yeah, I understand residential wiring - did most of my own
    home,
    : but I don't see what this has to do with the large
    descrepancy
    : between 120 VAC wiring in the home vs an operator's
    console.
    : IMHO, it's more likely for a homeowner to replace a switch
    than
    : a console operator will tear into his console... he's just
    there
    : to operate it and in an industrial enviroment there are
    almost
    : always electricians on staff to 'fix' things.... and they
    ought
    : to be safer around 120 VAC than the average homeowner. So
    why
    : do they need a more conservative standard than a
    homeowner?? I
    : just don't get it...
    : Leroy Hall wrote:
    : > Let's take a simple 120VAC lamp for example. You know.
    of course, that the plug that goes
    : > to the outlet has two spades, one of which is normally
    hot (120VAC) with respect to earth
    : > ground and the other isn't? This plug will usually
    enter into an outlet in one direction
    : > only? The small blade is the hot one, connects to the
    black wire inside the outlet, the
    : > large one is called neutral, connected to the white wire
    inside the outlet. Inside the
    : > lamp where these two wires connect to a light bulb is
    important. We normally connect the
    : > neutral wire to the outside screw base of the bulb
    connection. Switch this, so that the
    : > hot wire is connected here, and what happens? Some poor
    unsuspecting soul is changing a
    : > light bulb standing on a damp concrete floor with bare
    or wet feet feet. Soon as the bulb
    : > is unscrewed from the socket they touch the screw base
    of the bulb where it connects to
    : > the lamp holder and then find out what happens after
    : > electrocuted. This is not to say that one cannot
    connect 120VAC devices to common
    : > connections, it is just to say if you do, make sure you
    know the details. Usually someone
    : > with no experience, doesn't know enough to ask the
    proper questions to avoid a very costly
    : > mistake.
    : > Hope this helps,
    : > Leroy
    : > From: "Larry Gaminde" <lgaminde@t...>
    : > To: <basicstamps@yahoogroups.com>
    : > Sent: Monday, January 20, 2003 7:11 PM
    : > Subject: Re: [noparse][[/noparse]basicstamps] Interfacing a Stamp with AC
    : > : I'll bet what he is trying to say is there are enough
    people
    : > : on the list who blow things up with 5 volts so to give
    : > : anyone advice about 120 plus voltage is really stupid,
    All I
    : > : can say is it will smoke faster with higher voltage so
    go
    : > : for it. ( you may be it)
    : > : From: "Michael Burr" <mburr@b...>
    : > : To: <basicstamps@yahoogroups.com>
    : > : Sent: January 20, 2003 4:06 PM
    : > : Subject: Re: [noparse][[/noparse]basicstamps] Interfacing a Stamp with AC
    : > : devices (not relays)
    : > : : plasmastamp@a... wrote:
    : > : : > No.
    : > : : > Your house is safe because the National Electrical
    : > : Council, the main code
    : > : : > enforcement in the US has different standards for
    : > : residential wiring. Your
    : > : : > house, does not see the use as an industrial
    : > : application. Translation:
    : > : : > Different set of Lawyers wrote the rules.
    : > : : Alan, I don't mean to be argumentative here, but it
    was
    : > : you (in
    : > : : your original post) who preceeded your statement
    that
    : > : there can
    : > : : be no 120 VAC on switches or lamps in operator's
    consoles
    : > : with
    : > : : the following statement:
    : > : : "When working with AC line powered circuits you need
    to
    : > : look
    : > : : very closely at isolation, for personal safety and
    circuit
    : > : safety."
    : > : : You seem to have implied there that it _IS_ a safety
    : > : concern...
    : > : : so I asked what's the difference between that and a
    house.
    : > : Now,
    : > : : you seem to be implying that it is not really a
    safety
    : > : concern
    : > : : and the requirements are due to "Lawyer's who wrote
    the
    : > : rules"
    : > : : (although I doubt lawyers actually wrote the
    rules...
    : > : perhaps
    : > : : you mean 'bureaucrat'). So I remain confussed as to
    what
    : > : point
    : > : : you were trying to make. Do you consider the
    practice
    : > : dangerous
    : > : : or merely not in compliance with the rules?
    : > : : Michael Burr
    : > : : To UNSUBSCRIBE, just send mail to:
    : > : : basicstamps-unsubscribe@yahoogroups.com
    : > : : from the same email address that you subscribed.
    Text in
    : > : the Subject and Body of the message will be ignored.
    : > : : Your use of Yahoo! Groups is subject to
    : > : http://docs.yahoo.com/info/terms/
    : > : To UNSUBSCRIBE, just send mail to:
    : > : basicstamps-unsubscribe@yahoogroups.com
    : > : from the same email address that you subscribed. Text
    : > message will be ignored.
    : > : Your use of Yahoo! Groups is subject to
    : > To UNSUBSCRIBE, just send mail to:
    : > basicstamps-unsubscribe@yahoogroups.com
    : > from the same email address that you subscribed. Text
    in the Subject and Body of the message will be ignored.
    : > Your use of Yahoo! Groups is subject to
    : Our government it seems has got a new plan...
    : Seize and search the private records of every man.
    : No warrants, no judges, no due process required,
    : With "Homeland Security" the 4th Amendment's retired.
    : "Total Information Awareness" the project is called,
    : Oh would our forefathers be aghast and appalled!
    : http://geocities.com/totalinformationawareness/
    edited 2003-01-21 20:49
    That is correct to the rental properties.
    I do not understand the difference in the standards also.
    We just have to remember that when the Government is involved the only given
    is that we middle income people will pay. It wont make sense to us, but rest
    assured a Congressman (Who most likely started life as a Lawyer) is behind
    the regulations with PAC Lobbyist money involved.
    Alan Bradford
    Plasma Technologies.
    edited 2003-01-21 20:55
    You have never been around when an OSHA inspection was taking place. They
    can get real ridiculous. These are Government Desk Jockeys who come in and
    they have to find something wrong, or they are accused of not doing their
    job. Moving machinery has to have warning horns. In most factories there are
    so many warning horns going off that toy cant hear anything. Then OSHA makes
    you wear hearing protection from the noise. The rules don't have to make
    sense. They are Government issued.
    Alan Bradford
    In a message dated 1/21/03 3:03:36 PM Eastern Standard Time, mburr@b...
    writes:
    edited 2003-01-22 00:13
    There's nothing to "get" - Its government. While you can do wiring in your
    own home, you'd be breaking the law if you did wiring in your friend's home.
    If you aren't the owner then you need a ticket.
    To do anything in a commercial environment you need an electrical ticket of
    some sort. Annual permits issued to an electrician may allow
    non-electricians ( under ticket holder supervision) to do simple things like
    replace ballasts or put new plugs on extention cords. Thats about the only
    time a non-ticket holder is allowed to touch 110.
    OSHA doesn't have to pay compensation for you (or your friends) when the
    home-brew electrical circuit plays 4th of July - you do. At work, they do.
    Sent: Tuesday, January 21, 2003 12:01 PM
    edited 2003-01-22 02:34
    Another note about ANY residential wiring, your house or not.
    if it does not meet code and a fire starts, the insurance company can
    reject the claim.
    Be neat and put any stuff in a simple electrical box. get it from
    home depot or something and it will be UL listed, make sure the 110V
    wires are not touching raw metal edges, wire nuts, electrical tape
    that sort of thing.
    your 'control' wiring will be low voltage, like a thermostat and does
    not need to be 'up to code' as the low voltage stuff comes under the
    radar and probably will not have enough power to cause any problems.
    Dave
    in your
    friend's home.
    ticket of
    things like
    the only
    when the
    they do.
    relays)
    edited 2003-01-22 03:47
    Sigh.. I'm sure you're right and I'm guilty again of expecting
    the world to be logical - my wife just laughs at me and calls me
    "Spock" when I get this way... guess you all can do the same.
    Michael Burr
    edited 2003-01-22 03:50
    > reject the claim.
    > that sort of thing.
    All my work was approved by the state inspector - he liked it
    better than the work the "pro" did on site :^)
    Michael Burr
    edited 2003-01-22 17:45
    Actually, it not really a hard to understand the reason for the
    differences. You have an operator's control panel that can have
    anywhere between dozens to (sometimes) hundreds of wire connections
    using smaller much more compact switches that were designed to
    control electricity inderectly in a very close space. Whereas, the
    light switches and outlets in your house were designed to control
    that power directly and with fewer (supposedly) connections in
    properly sized space (set by NEC). If you look on lots of the larger
    industrial equipment, you'll find most of them have switches that
    resemble the switches in your home (though of higher grade) connected
    to them. So you have to ask yourself, would you rather be the
    operator sitting at a control panel pressing and flipping switches on
    a panel 2 ft. x 3 ft. or 5 ft. x 12 ft.
    Putting tiny switches that directly control 110/220 volts very
    close together is a major hazard to the guy that has to repair
    panel... not to mention trying to push that much power through a tiny
    switch , like what would show up on that panel, would likely cause
    the back of that panel to look like it should have been in the lab
    background of "Frankenstien".
    in your
    friend's home.
    ticket of
    things like
    the only
    when the
    they do.
    relays)
    <Sigh>
    *Many* industrial control panels use 110 Vac as their control power
    supply. I don't like it much - I'd rather use 24 Vdc (1st choice) or 24
    Vac (2nd choice) but all too often, I'm required to interface my control
    systems to 110 Vac controls.
    I'm talking about industrial systems here: big things like punch presses,
    parts washers, process ovens. Even systems controlled by PLCs are often
    110 Vac - especially if the PLC was added after the machinery was initially
    designed.
    I used to use the equivalent of solid state relays for most of my
    interfacing but now all my boards use little JS-1E relays from Aromat for
    outputs. Nice little relays: 8A or 10A ratings at 120 Vac, SPDT, cost less
    than a buck US in thousands. And it doesn't much matter what the control
    system is: AC, DC, 24V, 110V - it just works.
    So *please* don't go saying that 110 Vac is not used in operator's
    panels. It is - and it *can* kill you if you aren't paying attention.
    dwayne
    Dwayne Reid <dwayner@p...>
    Trinity Electronics Systems Ltd Edmonton, AB, CANADA
    (780) 489-3199 voice (780) 487-6397 fax
    Celebrating 18 years of Engineering Innovation (1984 - 2002)
    Do NOT send unsolicited commercial email to this email address.
    This message neither grants consent to receive unsolicited
    commercial email nor is intended to solicit commercial email.
