Cable and connector rating
Can I use XLR connectors and cables to run DC 13.8V at about 25A and
using AWG 16 for my next BS2 project? Is that safe and reliable? I
am turning large DC motors and lights (using solid state relays) and
need something that is polarity sensitive, easy to plug in and out,
reliable and safe.
many thanks
Al
reliable and safe.
many thanks
Al
Its really bad form to use an industry standard connector for something its
not intended for, especially if it involves power. This will eventually
cause someone to plug the cable in where it shouldn't go, potentially hosing
your stuff or someone else's. I can imagine someone assuming your cable is
for low-level audio and plugging it into a mixing board.
Case in point:
A thrifty (read cheapskate) friend decided the electrical extension cords he
already has would make a good, long speaker wire extension for his stereo.
He bought the appropriate connectors and put a female 2-prong outlet on the
stereo and a male 2-prong plug on the speakers. Works good and he is proud
of himself for not having to buy any wire.
Dad is sitting in his chair watching football one Sunday, and suddenly hears
a very brief, loud buzz in the basement. As he gets to the basement door, he
is met by a very wide-eyed 4-year-old with soiled pants. Seems his son had
seen dad plug enough stuff in the wall outlet and figured dad forgot to plug
the speaker.
> reliable and safe.
outlets as a standard modification to helicopters. We protect them with 35A
circuitbreakers, and use them for running fire buckets, or radio equipment.
Although the pins are nice and heavy, I wouldn't recommend much over 20A
continuous. (fire buckets draw intermittent current only). I have never seen
one fail in that application, they are a good reliable and inexpensive
connector and have become somewhat of an industry standard here for airborne
auxiliary power outlets.
AWG 16 wire is ok for 25 A if not run in a bundle, and your wire is good
quality, however over reasonable distance, expect to see some copper
losses!!
Dwain.
Sent: Monday, January 20, 2003 7:08 AM
Subject: [noparse][[/noparse]basicstamps] Cable and connector rating
> reliable and safe.
> many thanks
> Al
--- In basicstamps@yahoogroups.com, "Dwain J. Hill"
<dwainsworld@e...> wrote:
> In Australia, many operators use these connectors for auxiliary
power
with 35A
equipment.
over 20A
never seen
inexpensive
for airborne
is good
copper
> losses!!
> Regards,
> Dwain.
> From: <brownstamp@y...>
and
reliable? I
and
out,
> > reliable and safe.
> > many thanks
> > Al
Subject and
--- In basicstamps@yahoogroups.com, Rodent <daweasel@s...> wrote:
> "Can" implies ability. "Should" is the operative word.
something its
eventually
potentially hosing
cable is
> Case in point:
extension cords he
stereo.
outlet on the
is proud
suddenly hears
basement door, he
son had
forgot to plug
> the speaker.
and
reliable? I
and
out,
> > reliable and safe.
