Split serial-incomming data into two variables.
Hi
Try to split serial-incoming data into two variables, just like it's
explained on page 314 in the BS2-book.
The program is just modified to work against the debug window. (win-
version)
If I write e.g., "Pos: 12345678" the numbers should end up in two
variables, but if I get anything at all, it's the wrong numbers
(Don't know where they come from)
Can somebody give me some clue how split serial-incoming data into
two variables.
Or how to best evaluate incoming data, both strings and numbers.
I have tried the line: If ID = 12 then …… but what about strings?
Thanks.
Stein_Frostad at mailcity dot com
' *********** Serin comm into two variables (Page 314 in BS2-book)
YOffset var Word
XOffset var Word
Start:
Serin 16,16468,[noparse][[/noparse]Wait("Pos: "),dec Xoffset,dec yOffset]
Debug ? Yoffset
Debug ? XOffset
Goto Start
version)
two variables.
Thanks.
YOffset var Word
XOffset var Word
Start:
Debug ? Yoffset
Debug ? XOffset
Goto Start
seminar, so I can't confirm this will work for you. Give it a shot....
SERIN baud, pin, [noparse][[/noparse]WAIT ("Pos: "), DEC4 x, DEC4 y)]
This counts on your input data being eight digits wide, with four digits for
x and four digits for y.
-- Jon Williams
-- Parallax
In a message dated 1/19/2003 7:03:55 AM Central Standard Time,
Stein_Frostad@m... writes:
> Hi
> version)
> two variables.
The Stamp works perfectly with Access Database (Visual Basic) also.
Only drawback……this little BS2 program (under) is working greate on
9600 baud against the debug window, but when I start up the VB-
program, I can only use 2400 baud. Even 4800 baud is to fast.
Do you have a last minute sudjestion for this leap of differences?
yOffset var word
xOffset var word
BaudV con 16780 ` /16468 2400 baud/9600 baud.
Start:
Xoffset=0
Yoffset=0
Serin 16,BaudV,[noparse][[/noparse]Wait ("Pos: "),dec4 xOffset,dec4 yOffset]
Pause 10
Serout 16,baudV,[noparse][[/noparse]"From PC: X=",dec xOffset," Y=",dec yoffset]
'Debug ? yOffset ` Use only in 9600 baud
'Debug ? xOffset
Goto Start
Future stampers looking into communication between VB and BS2
remember:
-Stamp returns echo, What ever you send is returned (Can't be turned
off). Can be used as a check that the stamp is hocked up correctly.
-Stamp resets when you close/open the com port on the Computer. Put
in the line serout 16,16780,[noparse][[/noparse]" Stamp Reset "] on top of stamp
program. Then the VB-program detects this info, and you can program
it to do the right thing.
-It's hard to get the baud rate over 2400 between BS2 and VB. The
debug window work in 9600.
-Remember to turn off other serial com programs on your Pc.
Thanks.
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> I'm writing this as I'm trying to eat breakfast and head out the
door to a
shot....
digits for
> -- Jon Williams
> -- Parallax
> > Hi
it's
(win-
> > version)
two
into
> > two variables.
