Hacking calculators
I am very much a novice to all of this, but I have a question. Is it
possible to hack a cheap pocket calculator and reprogram it to
do something else?
I'm trying to make a calculator size device that, when you press a
button, will display a random number. I could make one with kits,
etc., at some expense, but I am wondering if a $5 calculator may
have some of the parts I already need.
Any thoughts on this would be appreciated.
do something else?
scoreboard, but if I could hook up a calculators to create counters
(home/visitor score and period) then that would help greatly. I'd want to
take another calculator and create a countdown timer with which I could set,
reset, start and stop the clock.
Jarrod.
Sent: Thursday, January 16, 2003 7:40 PM
Subject: [noparse][[/noparse]basicstamps] Hacking calculators
> do something else?
> do something else?
Why did you post to the Stamps group for this?? Go to Ebay and
buy yourself a cheap used Scientific Calc with a random number
feature. Then press the [noparse][[/noparse]RND] key when you recieve it...
presto! you now have a calculator sized device that will
produce random numbers when you press a key...
Michael Burr
chip where the program has been burned into the chip and the chip is
then covered with a poxy.
--- In basicstamps@yahoogroups.com, "westinn29 <westinn29@y...>"
it
> do something else?
surface mount and there is no provision made for programming the chips etc.
Reverse engineering these things would be 1000 times harder than just making
your own on perfboard.
Sent: Thursday, January 16, 2003 4:57 PM
Subject: Re: [noparse][[/noparse]basicstamps] Hacking calculators
> I too have been wondering about this. I would like to create a personal
set,
> Jarrod.
> From: <westinn29@y...>
> > do something else?
and
commercially viable product for role-playing gamers that is
cheap and has a number of buttons to produce random results
like different sides dice (4 sided, 6 sided, etc.).
--- In basicstamps@yahoogroups.com, Michael Burr
<mburr@b...> wrote:
it
to
> > do something else?
press a
kits,
may
and
number
> Michael Burr
to know as much as I can before I hire someone to do this).
Could the chip be removed and replaced with a custom
programmed chip, so that the other hardware of the calculator
(LCD, keypad, casing) could be used?
--- In basicstamps@yahoogroups.com, "dirt939 <stamp@d...>"
<stamp@d...> wrote:
> You cannot reprogram a calculator. Most calculators have a
single
chip is
<westinn29@y...>"
> it
to
> > do something else?
press a
kits,
may
This can all be easily done on an HP48-SX calculator which you
can buy used on Ebay for about $40... less than the cost of a stamp.
Our government it seems has got a new plan...
Seize and search the private records of every man.
No warrants, no judges, no due process required,
With "Homeland Security" the 4th Amendment's retired.
"Total Information Awareness" the project is called,
Oh would our forefathers be aghast and appalled!
http://geocities.com/totalinformationawareness/
from kits, for about $90. I'm trying to come up with an economical
way to produce a commercially viable product, however.
I am approaching engineering companies and getting quotes
from them, but I want to explore the idea of producing them on a
smaller scale as well.
Thanks for your advice!
--- In basicstamps@yahoogroups.com, Pat M <pmeloy@s...>
wrote:
> If you open up one of the pocket calculators you'll see
everything is
than just making
> From: "SportsAnnouncing.com" <dj@s...>
personal
counters
I'd want to
which I could
> set,
> > Jarrod.
Is it
it to
> > > do something else?
press a
with kits,
may
the Subject
> and
the Subject and
> Well, I guess I should give more detail. I want to make a
Well, once again, this is easily accomplished with an
inexpensive used HP48 available on Ebay for about $40. You
might be better off just writing software for the 48' and sell
it shareware as a product.
If you are determined to build hardware for this you'll probably
find this months Nut's N Volts' intresting - an article titled
"Build the High Roller Pic-Based Electronic Dice". An
interesting article... but it's still lost on me why anyone
would spend so much time and effort when the same functionality
can be accomplished with a few lines of code on an inexpensive
programmable calculator.
Michael Burr
second if you want to do some 'market research' buy a bunch of
different calculators and see how they are made. you may get lucky
and find one with a PIC that is exposed. ie: replacelable.
another possibility is that you can then find a manufacturer that
will sell you a wholesale lot for cheap without the pic,
in my opnion, the labor on re-working a unit is too high to be
considdered.
Dave
> Okay, this is probably a stupid question, but bear with me (I want
> single
> chip is
> <westinn29@y...>"
Is
> > it
> to
> > > do something else?
> press a
> kits,
> may
these are all one time programmable ones, using obscure or unknown
MCU's, thus you could never re-program them if you could.
You can use one of the programmable calculators and program them
to perform this function.
But you can save your self a lot of hassle:
http://www.hobbytron.net/vk3400.html this kit is pretty neat, works good
too.
http://www.hobbytron.net/gamesub.html
http://www.outpost.com/product/2578461/
http://www.velleman.be/kits/k3400.htm
Here is one that uses a PIC MCU
http://electronickits.com/kit/complete/game/ck903.htm
http://www.electronic-kits-and-projects.com/kit-files/3xxx/3069.pdf
http://www.gatewayelex.com/kits9.htm
https://www1117.verio-web.com/grayma/catalog/146.htm
http://www.alltronics.com/kits.htm
ad infintum....
Lots of hits via www.google.com using "electronic dice kit"
From: westinn29 <westinn29@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qEkxPqiLMzt1Jgi7gZ5w6xQeeoO-c1Gm8fROlBtLWASx25-NAJ2dkt2NruOXEvuQ4wqmbteiDbchr193Fg4]westinn29@y...[/url
Sent: Friday, January 17, 2003 2:57 PM
Subject: [noparse][[/noparse]basicstamps] Re: Hacking calculators
<mburr@b...> wrote:
it
to
> > do something else?
press a
kits,
may
and
number
> Michael Burr
and a case and buttons.
no doubt that you could not re-program them but you could replace
them if you find one that you could removed the chip.
Dave
--- In basicstamps@yahoogroups.com, "Earl Bollinger"
<earlwbollinger@a...> wrote:
> Calculators nowadays use the cheapest MCU they can get.
good
> too.
> ad infintum....
> From: westinn29 <westinn29@y...> [noparse][[/noparse]mailto:westinn29@y...]
> <mburr@b...> wrote:
Is
> it
> to
> > > do something else?
> press a
> kits,
> may
> and
> number
> > Michael Burr
Subject and
economically feasible for the marketplace as a whole.
in selling an electronic product, you will have to
worry about compliance certifications and the like for
this "new" product. it is much easier to start with a
clean design. as part of the business plan to develop
and manufacture the product, you will have to figure
on how to spread this cost over several production
builds.
just thought i'd throw my thoughts into the mix.
kevin
--- "westinn29 <westinn29@y...>"
> with me (I want
> this).
> calculator
> <stamp@d...>"
> calculators have a
> single
> chip and the
> chip is
> <westinn29@y...>"
> have a question. Is
> > it
> reprogram it
> to
> > > do something else?
> that, when you
> press a
> make one with
> kits,
> $5 calculator
> may
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
calculator can come after you legally if you market a hacked version,
and 2) UL will never approve it, which limits your market.
Dennis
From: kevin asato [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LbxFmu_p_4gXnrwwPbjfvhz_bsxlF0mLAq2ffPYW7On5EleNrAhzjdKAFtjXMpPWzvhb7GQ-BpCTzQ]kc6pob@y...[/url
Sent: Saturday, January 18, 2003 9:57 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Hacking calculators
while yes it can be done for your own use, it is not economically
feasible for the marketplace as a whole. in selling an electronic
product, you will have to worry about compliance certifications and the
like for this "new" product. it is much easier to start with a clean
design. as part of the business plan to develop and manufacture the
product, you will have to figure on how to spread this cost over several
production builds.
kevin
not have the same threshold as 110Volt.
there may be 'no controling legal authority'
another thing, is that you can find lots of houses that will
manufacture the whole thing for you. probably even a far east
company will do it.
but you need to look at the numbers. if the origional poster wanted
to hack calculators, then the limit was how many he could do. not
enought to be a blip on the radar. but enough to keep him busy.
Dave
> builds.
> kevin
> > with me (I want
> > this).
> > calculator
> > <stamp@d...>"
> > calculators have a
> > single
> > chip and the
> > chip is
> > <westinn29@y...>"
> > have a question. Is
> > > it
> > reprogram it
> > to
> > > > do something else?
> > that, when you
> > press a
> > make one with
> > kits,
> > $5 calculator
> > may
> > ignored.
> Do you Yahoo!?
> Yeah, I gathered from the Parallax site that I could
> make one
> an economical
> however.
> quotes
> producing them on a
Well:
Nobody mention the Popular Electronics (yes I'm
that old :-) article from quit a few years back.
It used your basic four function calculator. BUT,
it had to do constant math. I.E., after you entered
a formual (0 + 1) then hit the = sign the calculator
would display a cumulative sum =1,=2,=3,=4,=5,... .
The circuit used a simple combinational digital
logic to pre-load the calculator. So you wired up
some gates/transistors as switches to Press this key
sequence.
CE # clear calculator enters 0 in display
+ # start equation
1 # end start up
= # clock /event / timer circuit you decide
So for $2 worth of IC's and a $70 calculator (70's
prices
[noparse][[/noparse]now $.50 IC's and $5 calculator]) You could
have a counter/timer module.
The main idea is to wire transistors as switches
across the buttons, have some logic (IC's/Stamp) to
control these switches in an algorithmic way.
It's a do-able your science fair project.
Production I don't think so...
Use your creativity,
Dave La Rosa
Do you Yahoo!?
