BS1 ''Hardware Not Found'' - HELP
If its a Toshiba, I may know what to do. Let me know off list if you need
help.
Jonathan
Sent: Thursday, January 16, 2003 11:05 AM
Subject: [noparse][[/noparse]basicstamps] Re: BS1 'Hardware Not Found' - HELP
> --- In basicstamps@yahoogroups.com, "eggybaby84 <teggenberger@m...>"
> <teggenberger@m...> wrote:
> > Hi.
> > Can the Pbasic editor for DOS (for the Basic Stamp 1) be
> > run from Windows (2000?
> > When I try to run it I get a "Hardware Not Found" dialog box.
> > I'm using a cable from the Parallel port to an Activity Board
> > with a PS1. I have used these same components successfully before
> but
> > it's been a good 6-7 years ago. Just recently getting into it again.
> > Thanks alot for any help
> NEVERMIND: It's working. Found a post about running PBASIC from a
> laptop doesn't always work. Hooked it up to the trusty Desktop and
> it worked fine.
> Thanks anywa.
help.
Jonathan
> > Hi.
> but
> it worked fine.
> Thanks anywa.
