3 Motors simultaneous positioning with SX?
I would like to run 3 DC Motors in the same speed,
independent of the load. (max 3000 r/min)
AND to stop them after a given number of revolution
Forward and back
I would like to fix an encoder on each motor
Depending on the reading of the encoder, I thought,
to give each motor (with H-Bridge) a Low or a High
I would get an PWM depending on the reading of the encoder ?
Is the Stamp SX quick enough to read, calculate, and to change outputs
for the 3 motors??
I have no idea how to calculate the needed time?
I may could count the revolution of each motor, compare them and
switch the output of each motor on or off, depending of the
result of the calculation.
This needs a long time
I may could fix two encoder on each motor and check
If each motor runs synchronous on the same encoder,
or if one motor is already on the next encoder.
I have read Tracy Allen "Finite State Machines"
And a two-bit quadrature encoder could do it ??
Or is a grey code wheel to encode it, in an code, to use
for the PWM of each motor ?
An acceleration of the motor speed would be not bad
but not urged necessary.
Also an safety switch,
and an referent switch to read would be not bad too.
Can the sx do it quick enough for the 3 motors?
Who has experience or samples or ideas what the best way is?
Tracy,
do You have a "math way" to read the encoder inputs
And control the motor outputs quickly ??
Advices are welcome
Thankfully Heinz
Forward and back
for the 3 motors??
Tracy,
Advices are welcome
Thankfully Heinz
ago on running motors while doing other things. There is a chip made
by national semiconductor (LMD18200 -- pull the datasheet from
digikey) that has a built in H-Bridge and is set by PWM. It looks
like you could feed back a tachometer to either the 18200 or the
BS2SX to set the speed. As for speed of the SX, at 3000 rpm, the
motor is spinning 50 times a second. You can run a lot of
instructions in 20 ms.
My problem is that I need to be able to finely adjust the position of
something controlled by a DC motor. So I need to send PWM to the
controler while watching for a switch to close. You can't do
anything else while running a PWM command.
I am curious about your application. If the motors need to go the
same speed, why not just use one motor and connect the loads
mechanicly? There may also be some kind of electrical trick you
could do with a phase locked loop, but I was never very good with
analog circuits.
Please tell me if you have any success.
-selket
--- In basicstamps@yahoogroups.com, "HSchwenk_GMX" <hschwenk@g...>
wrote:
> Hi,
> Forward and back
outputs
> for the 3 motors??
> Tracy,
> Advices are welcome
> Thankfully Heinz
your project has a few targets.
counting revolutions and stopping at an exact point is easy. a
reflective dot on a shaft and a counter will offer total number of
dots or shaft turns.
speed control of each motor at constant speed regardless of load is
much more complex.
how accurate do you need this to be? if you have some acceptable
range just the same dot, but counting speed would offer a simple rpm
monitoring loop. As a rule of thumb, you would want your sensor to
be 4 times more accurate than the thing you want to measure.
speed for the sensor is easy. 3,000 RPM, times 3 units, times 4 for
accuracy would offer 36,000 per minute or 600 hz.
the hard thing would be to figure program time. if you need very
exact speed control, you may need some sort of PID loop and that will
use lots of processing power. That may require one processor per
motor for speed control and one more for counting.
Dave
wrote:
> Hi,
> Forward and back
outputs
> for the 3 motors??
> Tracy,
> Advices are welcome
> Thankfully Heinz
In a big shelf I have to position
12 m and 6 m long wood
I need 3 motors to go up and down
and 3 motors to move in and out.
I thought to do it in two different processes.
For the 12 m wood I use motor1 motor2 and motor3
For the left 6m I use the motor1 +2
For the right 6m I use motor2+3
Yes I thought about mechanical solution
But it would be a big heavy complicated stuff
Including coupling--clutches
The 3 motor-solution is more flexible and easier to build
About PWM:
I did not think to use PWM-command,
I thought to make the motor pins high or low
between the reading of the encoder.
This would be like PW-control----?
I don't need a big accuracy in synchronism.
But I am not sure yet how to do.
Still I am not sure about the best solution---?
Selket thanks for replay Heinz
> analog circuits.
> -selket
> wrote:
> > Hi,
> > Forward and back
> outputs
> > for the 3 motors??
> > Tracy,
> > Advices are welcome
> > Thankfully Heinz
> much more complex.
The motors have gearbox and transport the long wood slowly.
So I need not an very exact speed control,
But the position in the shelf should be a bit more exactly
Thanks for replay Heinz
> Dave
> wrote:
> > Hi,
> > Forward and back
> outputs
> > for the 3 motors??
> > Tracy,
> > Advices are welcome
> > Thankfully Heinz
motors. Speed is controled by the sine wave freq of the AC. You can
usually find them in surplus houses with gear heads on them. Add a
triac and go. (now thats if single speed is OK)
wrote:
> > This is a lot like a problem I'm having. See my post from a few
days
made
position of
> About PWM:
> > analog circuits.
> > -selket
> > wrote:
> > > Hi,
> > > Forward and back
> > outputs
> > > for the 3 motors??
> > > Tracy,
> > > Advices are welcome
> > > Thankfully Heinz
Subject and
use it to control up to 8 motors simultaneously.
You control the PAK5 from your BAsic Stamp.
Works great too.
The Basicstamp controls the PAK5 which controls the motor controllers for
you. Then if you need positioan or RPM feedback use encoders and use a
http://www.al-williams.com/pak7.htm PAK7 pulse input coprocessor to get the
info back into the BasicStamp where you can deal with it.
From: anode505 <anode505@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6jnGGWFbsAMNGl5tmTsdZ-Z-EuQBkGNmUtuubI_jH3_BsT6rTcckxwXl8fzT9aslN9bAGzhDpXY]anode505@y...[/url
Sent: Friday, January 17, 2003 5:54 AM
Subject: [noparse][[/noparse]basicstamps] Re: 3 Motors simultaneous positioning with SX?
Same speed? Need to vary the speed? If not think about AC syncro
days
made
position of
> About PWM:
> > analog circuits.
> > -selket
> > wrote:
> > > Hi,
> > > Forward and back
> > outputs
> > > for the 3 motors??
> > > Tracy,
> > > Advices are welcome
> > > Thankfully Heinz
Subject and
encouder WITH a tyer"wheel" with any diameter rolling fool on the moving part(
determin the desplacement for 1 motor of 3 motors)up and down, and same for
others 3 motors in and out.
this way you calculat any distance( longeur) exactly with out garding the RPM
of motors,you have only used 2 encouders to control, and the h-bridge has
electrical break. i made that for a paking machine
LANA
wenk_GMX <hschwenk@g...> wrote:
> This is a lot like a problem I'm having. See my post from a few days
About PWM:
> analog circuits.
> -selket
> wrote:
> > Hi,
> > Forward and back
> outputs
> > for the 3 motors??
> > Tracy,
> > Advices are welcome
> > Thankfully Heinz
from the same email address that you subscribed. Text in the Subject and Body of
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now
