BS2 to run a 12 volt relay in my car
I want to use the BS2 to power my computer in the car, which is
powered off a 12 volt relay. The BS2 outputs 5 volts, how do i make
that 5 volt output to 12 volts? I have searched and read, but I
can't find out how to wire a transistor or whatever is needed.
Please help.
amrit
Please help.
amrit
You can find all that you need to know on this on the Parallax website. Look
for the Nuts and Volts article titled something like "Silicon Steriods for
your Stamp".
Jonathan
www.madlabs.info
Sent: Monday, January 13, 2003 5:30 PM
Subject: [noparse][[/noparse]basicstamps] BS2 to run a 12 volt relay in my car
> Please help.
> amrit
right?........... it seems like there is plenty of 12 volt power available.
Or am I missing something? Otherwise, Im sure that others here will tell
you that you need to build a power supply circuit, that has all the voltages
you are going to need.
Dave
davelewis@d... writes:
> the stamp will have to get its juice from the car's 12 volts somehow
> voltages
What you want to do is relatively easy, but cumbersome to explain in an
email. Email a fax# and I will fax you a schematic of how to power your stamp
from your vehicle 12 volt system and run the relay using your stamp......
Here's what I understand:
You put the 12 volt + to pin 24 and the ground into pin 23.
The output pin to run a relay goes to some sort of transistor that also
has a 5 and a 12 volt input. I just can't figure out how to to wire the
transistor w/ the 2 voltages and the relay.
Amrit
From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gpB1VmATI19oUQW--_iVJP0FZJyc2DmGO7xHd2rwaUG3K6AgNxDZ8W7v0efKlREr7ooU62yz3JTxX0A]smartdim@a...[/url
Sent: Tuesday, January 14, 2003 8:42 AM
Subject: Re: [noparse][[/noparse]basicstamps] BS2 to run a 12 volt relay in my car
In a message dated 1/13/2003 11:08:55 PM Pacific Standard Time,
available.
tell
> voltages
stamp
stamp......
To select a transistor with enough current carrying ability, you need to
know the rated resistance or current of your 12V relay coil. A popular and
inexpensive transistor is the PN2222, which will handle up to 500mA or so
continuously. Chances are that your relay coil will use less current than
that, but you should check.
Here are the connections:
Connect a 1k ohm resistor from the stamp pin to the base of the transistor.
Connect the emitter of the transistor to ground. Connect the collector of
the transistor to one side of the relay coil. Connect the other side of the
relay coil to the +12 volt vehicle system. When the stamp pin outputs a
"high" the relay will be energized.
A couple additional notes: 1) The 1k ohm resistor might need to be a
different value if your relay coil requires a large current. Actually, if
it needs more than 300 to 400mA, a "bigger" transistor would be better. 2)
Automotive electrical systems are full of nasty electrical spikes, etc. I'm
not too sure how the regulator in the standard BS2 handles all that stuff,
so you might want to consider a more robust 5V regulator/supply, and feed
it's output to the Stamp's 5V input pin directly.
Randy
www.glitchbuster.com
Sent: Tuesday, January 14, 2003 11:11 AM
Subject: RE: [noparse][[/noparse]basicstamps] BS2 to run a 12 volt relay in my car
> i don't really have a fax number...
> Amrit
> From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nGCbHToRsUxchB29SEvM5g8hmP6a0yX3KPjcUJW1xTiiPwqeyikZmaeyjiWYJLicVz4k9sTqiVFgvX8]smartdim@a...[/url
> available.
> tell
> > voltages
> stamp
> stamp......
amrit50@f... writes:
Ok, got it....Your +12 to pin 24 and ground to pin 23 is correct
Get yourself a 2N2222 transistor (or 2N3904) from radio shack or your local
electronics store. Make sure before you leave you know which lead is the
BASE, EMITTER and COLLECTOR....
1.Connect the EMITTER to ground
2.Connect a resistor (4.7k, thats 4,700 ohms) to your output pin of the
stamp. Connect the other end of the resistor to the base lead of the
transistor
Stamp pin XXXXXXXX Transistor base (XXXX = the resistor)
On your relay, you will need to know which two leads are the "coil".
3.Connect one end of the coil to your car +12 volts, connect the other lead
of the coil to the transistor collector.
4.Also get a diode (1N4001 will do) Connect the diode across the relay coil.
One end of the diode has a line on it. The end with the line goes to the side
of the coil that is connected to the +12 volts, and the other end of the
diode goes to the transistor collector.
Your program.....When the stamp output pin is high, the relay will be on.
Conversely, when the stamp output pin is low, the relay will be off.
Therefore, the transitor base has one connection, 4.7k ohms.
The transistor emitter has one connection, to ground.
The transistor collector has two connections. Those are: One end of the relay
coil, and the non-stripe side of the diode
Don't hesitate to write back if you don't undersand or need clarification.
Ken
randyjones@w... writes:
> Hi Amrit,
> the
> I'm
> Randy
And a diode across the relay coil, Anode to the transitor collector.....
Yes! I was planning to mention that when I began typing the message, but
forgot it along the way.
Thanks!
Randy
Amrit
From: Randy Jones [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ABCDi-7EKDfW_QBzNQQtG_6uBz-5NPjQKYe6ll8ZSXJRLSAYCqHEbEmGYtDDWQf9R3h5HFbskuJDFDcLvIQ9HZSC]randyjones@w...[/url
Sent: Tuesday, January 14, 2003 2:35 PM
Hi Amrit,
Randy
> Amrit
> From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=fBDRvrs2J5wDQuOAWLwXac4pohNCRdlH3cMTnX2tSa-YGoyeustBUd92F9yKay_RZ-snMdA59cS-TCg]smartdim@a...[/url
> available.
> tell
> > voltages
> stamp
> stamp......
ULN2803A IC. It contains an array of transistors that provide a nice
current gain large enough to drive most relays or lamps etc, and best of
all, it's damn simple to wire, requiring no extra components.
I will try to describe:-
A high input from the stamp to the ULN2803 will cause the corresponding
output pin on the ULN2803A to go low.
I you have one side of the relay coil connected to +12VDC (or any voltage up
to 50V for that matter), when you ground the other side, it will activate,
so if you now connect that to the output of the ULN2803, it will drive the
relay.
EASY - Eight terminations and you are done!!
Example
Basic Stamp ULN2803A RELAY
O/P 8
1
16
COIL
+12VDC
9
GROUND
A High on pin 8 of the stamp is input to pin 1 of the ULN2803. With pin 1 of
the ULN high, pin 16 is driven low, current flows through the coil, and the
relay activates.
You can drive quite some stuff with these little suckers by parallelling the
individual inputs/outputs for increased oomph. Here is a link to the data
sheet http://www.allegromicro.com/datafile/2801.pdf
I don't often reply to questions here because there are so many ppl here who
are infinitely more qualified to answer questions than me, however, I think
that this IC just makes it so damn easy, and nobody ever suggests it!!
(Having said that, It does appear in the Basic Stamp manual, a search on the
Parallax webpage might also be handy for you).
Dwain.
Sent: Wednesday, January 15, 2003 8:19 AM
> Thanks for all your help randy.
> Amrit
> From: Randy Jones [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LAzt8uvWTwG8i0EjgD2BeFGKybn-nGuyslqus_WpUUX7s19VfIH1Frg9royZ08ZTJ-nssOcAdWhQMElZDRiMR4te7sMg]randyjones@w...[/url
> Hi Amrit,
and
transistor.
the
2)
I'm
> Randy
> From: "Amrit " <amrit50@f...>
> > Amrit
> > From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VkqxCHhjAHDkMvd79LcOXl_e37glol7wnVtiuVbZTXwR87giRnPB3-qfwjbCqI0upOzIRE7lUXriGt8]smartdim@a...[/url
> > available.
> > tell
> > > voltages
> > stamp
> > stamp......
and
