Security System Dial-out
Was wondering if anyone has worked on a system to dial numbers in
case of a break-in.
Here are some ideas:
Have the system dial up to say four numbers
Needs to be able to handle people, answering machines, pagers and know when
to start a message transfer
Can recite a pre-recorded message (e.g. digital message chip) or a certain
coded message to pager
Need some way to allow changing of numbers without a lot of reprogramming
Regular phone lines can be cut by someone knowing you have a security system
dial-out. Was wondering if there were any ways to hook up a cellular system
to do the above as well.
Just mulling over design ideas at this time, so if anyone has done some
pre-work on this, there is no need to re-invent the wheel. As well with this
list there are always great ideas flowing and maybe there are some things to
add.
I am planning to use the stamp as the main controller monitoring zones and
controlling keypads, sirens, etc. The only part I need ideas on are the
dialing areas.
Thanks for the help.
case of a break-in.
add.
dialing areas.
recall, it has an audio input that you could -- once you've determined there
was an answer -- play a message through.
-- Jon Williams
-- Parallax
In a message dated 1/13/2003 3:57:15 PM Central Standard Time,
Leckieh@n... writes:
> Hi,
> case of a break-in.
> system
> this
> to
> add.
> dialing areas.
You can do the same with a Stamp and one BoE-Bot speech boards
http://www.parallax.com/detail.asp?product_id=27975 or one of the Quadravox
units.
> case of a break-in.
when
system
system
this
to
> add.
> dialing areas.
great voice recording chips by Winbond:
http://www.digikey.com/scripts/us/dksus.dll?Criteria?
Ref=17203&Cat=31327344
-Dustin
--- In basicstamps@yahoogroups.com, Harvey Leckie <Leckieh@n...>
wrote:
> Hi,
numbers in
> case of a break-in.
know when
certain
reprogramming
security system
cellular system
some
with this
things to
> add.
zones and
the
> dialing areas.
