Please help with frequency drift.
Hello,
I have made a little clock using the RTC DS1302, a 32KHz OSC and a Basic
Stamp 2 (as most of you have done). What I would like to do next is to take
the RTC and OSC put them in an oven/cooler and log the temperature
induced frequency drift in the RTC (or indirectly the OSC). A nice temp vs
frequency drift chart at the end of all this is my goal. I know the BS2 does
have some frequency, pulse and commands. Can this be done with the BS2?
Logging the data is not so much a problem but if the rest of this is possible,
how should I approach this problem? If this wouldn't work with the RTC can I
monitor the OSC by itself? I would greatly appreciate any advice you folks
might offer.
-Jon
might offer.
-Jon
see if it as an oscillator output. If it does, you can read that with PULSIN
(pulse width measurement) with a 2 us resolution (assuming BS2). Of course,
you'll want to keep your BS2 outside the oven/cooler. Be sure to use
shielded wire to carry your signals (and keep as short as possible).
-- Jon Williams
-- Parallax
In a message dated 1/13/2003 10:21:54 AM Central Standard Time,
vatguy20021@y... writes:
> Hello,
> take
> does
> possible,
> I
> might offer.
> -Jon
You might find Brian Mumford's Horology projects interesting:
http://www.bmumford.com/
For best results, you will need an accurate oscillator for
comparison. One way would be to keep your reference clock at a
controlled temperature, and room temperature might be okay because
most watch crystals are flat at room temperature and concave downward
(they slow down) at higher and at lower temperatures.
Better would be an accurate frequency source, like the DS32khz. It
is a temperature compensated highly accurate 32khz oscillator
available in a dip or bga package. Some people who are really into
this use the GPS signal or WWVB. If you connect your system to WWVB
via a modem, you will have the seconds mark signal to within a few
milliseconds.
Even so, if you are counting seconds, you may have to wait a while
for the clocks to drift enough for you to detect it and to
distinguish drift from wobble. Unfortunately, the DS1302 does not
have a higher frequency 32768hz output that would allow for faster
comparisons. It is not a great idea to tap into the clock X2 signal,
because doing so will add capacitance that will change the frequency
and temperature characteristics slightly. That is especially true of
the DS1302, which specs a 6pf crystal.
Watches and clocks are sometimes calibrated by sensing the acoustic
vibrations from the crystal. Be sure to read the Dallas application
note #58 on clock oscillators. Also fascinating info on Brian
Mumford's site.
The latest most accurate clock uses mercury vapor trapped in a
magnetic bottle to eliminate the quantum transition errors that occur
when atoms hit the wall of a physical container. I forget how
accurate the frequency is, but it is something like one second in a
million years. There is a blurb about it in the latest N&V issue,
the same one with Jon Williams' article about PBASIC 2.5.
-- best regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
>Hello,
>might offer.
>-Jon
