EE (newbie): needs stamp jumpstart (232 & 485 application) — Parallax Forums
edited 2003-01-13 23:48 in General Discussion
Hi all,
I was reading through some postings and this looks like a wonderfully
supportive community. I am hoping you all can jumpstart me on stamp! I
have a new project that is relatively simple, and I've been pointed to the
stamp as a solid way to prototype it without having to custom fabricate PCBs
or order a ton of development boards. I have an electrical engineering
background, have worked with Motorola DSPs and microprocessors, and am
comfortable programming down to assembler. I have some general questions on
how to get started. But first:
ANY USEFUL SAMPLE CODE OR SOFTWARE TOOLS THAT ARE HELPFUL (preferably with
multiple 232 comms and/or 4-wire 485 multi-drop) WOULD BE GREATLY
APPRECIATED!
Here is what I need to do...
Project:
-Connect ~20 "nodes" to a common rs-485 bus to then talk to a main PC
server.
-Each node needs to communicate with two external devices via rs-232 (an LCD
and a bar code reader). Each node also needs to light up a few LEDs and
take a few push-button inputs in a very asynchronous environment.
-The system cannot lose information or miss inputs (is stamp an interrupt
driven environment?)
Here are my main starter questions:
1) What should I order to get started here (preferrably to wire-wrap the
entire project together)? Should I order a bunch of the starter kits?
Should I just order a bunch of Stamp "chips" and get some empty perf. boards
from Radio Shack? Help with what to order (from the chips to the software
to the power supplies) is greatly appreciated!
2) What is the best software development tool to use to program both in
BASIC and assembler (is there a C development program available?)
-Cost is important, but not at the sake of sacrificing an elegant design.
Thanks so much for your help! Looking forward to following the projects on
the list and lending a hand when I can!
All Best,
John Lerch
jwlerch@a...
John W. Lerch
Proximities, LLC
501 Forrestal Rd., Suite 202
Princeton, NJ 08540
p: (609) 951-9595
c: (609) 468-4959
f: (646) 514-5877
e: jlerch@p...
www.proximities.com
    edited 2003-01-13 22:54
    John,
    The only editor you will need is downloadable from Parallax. There is a new
    version coming out to-morrow, so wait 'till then to d-load. There may be C
    tools out there, but I don't know of them. A serial (not null modem) cable
    is required for programming. Sample code is everywhere, the Parallax site
    has a ton, the 'net has plenty more. And you can always ask the kind folks
    on this list for specific code examples.
    I would start with a B2SX OEM module and some breadboards from Radio Crack.
    The OEM has a Vreg and a com port built in. I would also recommend a serial
    LCD for debugging and so on. There is a built in debug that shows results on
    the PC, but sometimes it is easier to have an LCD if the Stamp isn't hooked
    up to the PC.
    The Stamp does not have interrupts. As to your project, there are many here
    more qualified then I to comment, so I will leave that to them.
    Jonathan
    To: "Basic Stamps" <basicstamps@yahoogroups.com>
    Cc: "Joshua Girvin" <jgirvin@p...>; "Brian Tsang"
    <btsang@s...>
    Sent: Monday, January 13, 2003 7:54 AM
    Subject: [noparse][[/noparse]basicstamps] EE (newbie): needs stamp jumpstart (232 & 485
    application)
    > Hi all,
    PCBs
    on
    > APPRECIATED!
    > Project:
    > server.
    LCD
    boards
    on
    > All Best,
    > John Lerch
    > jwlerch@a...
    > John W. Lerch
    > Proximities, LLC
    > Princeton, NJ 08540
    > p: (609) 951-9595
    > c: (609) 468-4959
    > f: (646) 514-5877
    > e: jlerch@p...
    > www.proximities.com
    I would start by ordering the basic stamp starter kit. It's
    expensive but you only need to buy it once. It has one stamp, a
    small proto board, any easy to use serial interface, PBASIC language
    documentation, and PC software. Then you only have to buy stamps for
    future projects (or reuse them).
    On the parallax site they have columns called "Nuts and Volts" where
    they give sample circuits and code. Take a look at the ones on RS232
    (esp. the one about interfacing VB) and RS485.
    The Basic Stamp does not support interupts. As someone who learned
    microprocessors on the Z-80 this is a major point of frustration, but
    for most applications you can work around it by checking your inputs
    regularly and even some fancy circuitry tricks.
    As for your specific project, why do you need to talk to the barcode
    reader and the LCD with RS232? This is probably making things more
    complicated than they have to be. The book that comes with the
    starter kit explains LCD interfaces very well and BS2+ has exelent
    subroutines for this.
    I hope this helps.
    -selket
    --- In basicstamps@yahoogroups.com, "John W. Lerch" <jwlerch@a...>
    wrote:
    > Hi all,
    wonderfully
    stamp! I
    to the
    fabricate PCBs
    engineering
    am
    questions on
    (preferably with
    > APPRECIATED!
    > Project:
    PC
    > server.
    232 (an LCD
    LEDs and
    interrupt
    wrap the
    kits?
    perf. boards
    software
    both in
    design.
    projects on
    > All Best,
    > John Lerch
    > jwlerch@a...
    > John W. Lerch
    > Proximities, LLC
    > Princeton, NJ 08540
    > p: (609) 951-9595
    > c: (609) 468-4959
    > f: (646) 514-5877
    > e: jlerch@p...
    > www.proximities.com
