Sonar Question
I've been asked to build a traffic light controller for a teacher's home
(it's not a real traffic light, but must act like one). He'd like the
traffic light to operate once a car pulls up into his drive way. The
lights are 120 Vac, so I plan to use the Opto 22 as the relay for the
BS2 and to bash a 12V lighting system for power. However, first I
need to detect the presence of a car. I was thinking about using
the same sonar used in robots. Has anyone tried one of them
outside in the real world's noise? I'm concerned about false
detections.
Paul
detections.
Paul
>detections.
>Thanks,
>Paul
Paul -
Personally I'd look more into break-the-beam type detectors. SONAR may be
subject to all sorts of false triggering. The other thought is use a pressure
sensor and an "inflated" hose like they have at gasoline filling stations to
trigger the alarm bell.
Hope that gives you some alternate ideas.
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
This web site carries some vehicle detection sensors that could be
interfaced to a Stamp.
http://www.homecontrols.com/dept_subcategory.html?subdept=SS03
Rich
From: verhap@o... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UlkRDQ-6cJLG80Lu4qUJS52AiX9DHm8VBmJPIODYrKZhAUpY3P5zzvq4ptXkFRbD1FgYW8jTPoNQ7W98_iDZbQ]verhap@o...[/url
Sent: Monday, January 13, 2003 8:21 AM
Subject: [noparse][[/noparse]basicstamps] Sonar Question
detections.
Paul
verhap@o... writes:
> detections.
> Thanks,
> Paul
You may want to "hack" a motion sensor that you can get at home depot for
about $20. Disable the ambient light sensor (black tape).
remember the details but it was a pretty simple thing.
The other possibility is a pressure activated switch and inflated tube. You
could use a garden hose with water in it, cap one end and stick some sort of
rubber membrane over the other. Car hits the hose and the rubber baloons
out, pushing a microswitch. Run a wire from the stamp pin to the switch then
from the switch to ground and pull it high. Make the switch, the input goes
low and your stamp does its thing.
Sent: Monday, January 13, 2003 6:20 AM
> detections.
> Thanks,
> Paul
Would that detect a car? The sensors detect IR from human
bodies as the radiation moves across two crystals. I'm not certain
they could detect cars (by the way, that was my first idea).
Paul
A commerically available solution is preferred, since it's designed
and tested to operate in the real world. Does anyone know of a
commerically available pressure sensor of this design?
Paul
verhap@o... writes:
The motion sensor I have mounted on my garage comes on every time I pull into
my driveway (at night) so guess it will detect a vehicle.
The garden hose/membrane idea I read on an earlier posting is a cleaver and
inexpensive pressure switch....
smartdim@a... writes:
> n a message dated 1/13/2003 7:05:06 AM Pacific Standard Time,
> verhap@o... writes:
> into
Try these
<A
HREF="www.clearstreamco.com/cscstore/autoalert.htm">www.clearstreamco.com/cscsto\
re/autoalert.htm</A>
www.compuwash.com/tunp_tape_switch.htm
www.monkeysocks.com/Qstore/p000433.htm
www.tapeswitch.com
analog output(0-5VDC) ... the rang doesn't have to be far just
something with close proximity (a few meters).
Eric
Look for the SonaSwitch. They have two analog versions with 8 or 10-bit
A/D output.
-Bruce
tech@r...
http://www.rentron.com
Sent: Monday, January 13, 2003 9:30 AM
> Speaking of sonar ... does anyone know a sonar range finder with an
> Eric
receiver that signals an auto with a loud two-tone bong. The motion
sensor is quite sensitive, and has a underhanging lip to prevent pets
from setting it off. I found it at Fry's Electronics, but it is widely
available.
Dennis
From: verhap@o... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SRetUuHVfrMVDbTeEgVW-lD_I2odmNjQhpqNmotpg3uKGxphDjJysijVm_3nVivEM8xl7fwRqJZimAhYswoXU019PQ]verhap@o...[/url
Sent: Monday, January 13, 2003 7:02 AM
Subject: Re: [noparse][[/noparse]basicstamps] Sonar Question
> for
Paul
Connect it to a piece of hose plugged at the other end -- when a tire goes
over the hose, it raises the pressure and closes the switch.
> Real traffic lights use a wire loop to detect large metal objects. Dont
You
of
then
goes
>>for
I have tried this before and found that it will detect slow
moving vehicles from almost head-on fairly well (probably
detects radiator heat). However faster moving vehicles and
those approaching from right angles are not detected very well
at all. There is also a significant time lag (maybe 1 sec.)
before detection in my experinces. If your interested in
hacking a commercial PIR sensor do a google search on "game cam"
and you'll find several very good hacks described.
Michael Burr
Our government it seems has got a new plan...
Seize and search the private records of every man.
No warrants, no judges, no due process required,
With "Homeland Security" the 4th Amendment's retired.
"Total Information Awareness" the project is called,
Oh would our forefathers be aghast and appalled!
http://geocities.com/totalinformationawareness/
Cypress PSoC contest. A PSoC is a programable System on a Chip. It's a MCU
that can be configured with AD, Amplifiers, PWM, all sorts of hardware, with
just the 28 pin chip.
The 1st place winner is a Sonar Ranging system that uses just the PSoC chip,
a sonar transmitter and reciever and a couple of resistors. The chip is
available from Digikey and is like $8. The programmer is about $30. The
software is free from Cypress.
I've worked with the PSoC and it's pretty simple (although I haven't
mastered the analouge parts yet).
Check it out!
chris in napa
chris in napa
Sent: Monday, January 13, 2003 8:30 AM
> Eric
From: verhap@o... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FfCFWVL0E9NwCMEm_EasKxqdK0V4k4_Bx0JQLs6VJ99lbHsd5c53HlrEm8i1WMav8Sc5nOher_vfuVRmUqihSQ]verhap@o...[/url
Sent: Monday, January 13, 2003 10:04 AM
You
of
then
goes
Paul
already designed to do this type of detection with out cutting driveway the
system is call Drive-Alert Driveway Alarm System DA500. Also sold by ADI
company. The sensor can be installed in the ground beside the driveway. I
have purchased this system and installed it is very reliable.
John
>From: <verhap@o...>
>Reply-To: basicstamps@yahoogroups.com
>Date: Mon, 13 Jan 2003 07:20:56 -700
>detections.
>Thanks,
>Paul
_________________________________________________________________
MSN 8 with e-mail virus protection service: 2 months FREE*
http://join.msn.com/?page=features/virus
http://www.savontv.com/google/driveway-patrol.html. I have 2 of these,
and can use either 2 sensors with one receiver, or one or both sensors
with both receivers in different locations. The 2-tone bongs of the
receivers are slightly different, which is also useful for
discrimination of sensor location.
Dennis
From: John Potts [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5PjaXMZSzC5_qipCdydLupVkDQmgkLTTXVsiSTJdNzw6OOMcOrRmOFUegWyFvDlCoJLH6uAJopjq]jp4980@h...[/url
Sent: Tuesday, January 14, 2003 6:26 AM
Hi Paul you might try looking at Mier Products Inc. they have a system
the
I
John
>From: <verhap@o...>
>home (it's not a real traffic light, but must act like one). He'd like
>the traffic light to operate once a car pulls up into his drive way.
>The lights are 120 Vac, so I plan to use the Opto 22 as the relay for
>the BS2 and to bash a 12V lighting system for power. However, first I
>need to detect the presence of a car. I was thinking about using the
>same sonar used in robots. Has anyone tried one of them outside in the
>real world's noise? I'm concerned about false detections.
>Thanks,
>Paul
>and
