PBASIC 2.5 Public Beta -- Friday (17 JAN 2003)
It is our intention to release the first public beta of the BASIC Stamp
Compiler 2.0 that features PBASIC 2.5 this Friday, January 17, 2003. You
will be able to download the compiler and essential support information from
our web site: <A HREF="www.parallax.com">www.parallax.com</A>.
New language features:
* {$PBASIC 2.x} directive
* PIN type definition (simplifies use of IO pins)
* IF...THEN...ELSE
* DO...LOOP
* SELECT...CASE
* EXIT (terminates FOR...NEXT and DO...LOOP)
* ON...GOSUB
* ON...GOTO
* [noparse][[/noparse]optional] Word modifier available for READ and WRITE
* Line continuation to next line (break at comma)
* Conditional compilation support
Note that the compiler is backward-compatible with PBASIC 2.0 code syntax.
If the
{$PBASIC 2.5} directive is not present, your programs will compile as with
the current (1.33) compiler.
Again, this is a public beta program. The compiler will come will essential
support information, but not the full help file. If you're not an
experienced PBASIC programmer you may want to wait for the full release and
the complete support package.
-- Jon Williams
* IF...THEN...ELSE
* DO...LOOP
* SELECT...CASE
* ON...GOSUB
* ON...GOTO
If the
-- Jon Williams
Do you have any idea when the complete PBASIC 2.5 will be ready go
(post beta)?
Stamp
2003. You
information from
> * IF...THEN...ELSE
> * DO...LOOP
> * SELECT...CASE
> * ON...GOSUB
> * ON...GOTO
syntax.
> If the
as with
essential
release and
> -- Jon Williams
... but a customer or two may prove otherwise.
-- Jon Williams
-- Parallax
In a message dated 1/13/2003 6:24:57 PM Central Standard Time,
romes1@j... writes:
> Jon,
> (post beta)?
