Conversion Confusion! — Parallax Forums
edited 2003-01-14 00:46 in General Discussion
I am now deep into serial communication formatter issues and I am
lost as usual! here is my question
I have a variable value I receive from one serial device that I want
to convert into hex and then send it to another device. Here is how
I want it to work:
inData var byte
outData var byte
SerIn deviceIn,baude,[noparse][[/noparse]dec2 dataIN] 'incoming value ranges up to 99
dataOut = the hex value of dataIn ' not sure how to do that
serOut deviceOut,baud,[noparse][[/noparse]dataOut] ' the reciever expect string
like "2F" which works fine from Hyperterminal
I would like to know :
1- how to convert a variable from decimal to HEX?
2- which modifier to use (Hex or Dec) when sending a dataOut which
is in hex now?
Hope to hear from you.
Al
    edited 2003-01-12 22:28
    The BASIC Stamp "knows" three numeric systems: decimal (default), hexadecimal
    (indicated by leading $) and binary (indicated by leading %). When doing
    conversions from and to serial streams, the following formatters are used:
    DEC, HEX and BIN.
    1) You can't change the internal representation of a variable, just how it
    gets presented to the world.
    2) Use the HEX modifier (some version of it) to send a variable to a serial
    data stream in the hexadecimal format. For example:
    SEROUT pin, baud, [noparse][[/noparse]HEX2 someVar]
    BTW ... this stuff is pretty thoroughly covered in our manual that can be
    downloaded free of charge.
    -- Jon Williams
    -- Parallax
    In a message dated 1/12/2003 4:07:22 PM Central Standard Time,
    brownstamp@y... writes:
    > I want it to work:
    > inData var byte
    > outData var byte
    > is in hex now?
    edited 2003-01-13 00:12
    I too am still in the conversion confusion stage John!
    In a previous thread with Tracy (By the way thanks for the help Tracy, your
    BCD explanation was stunning), she explained that when talking to the
    DS1302, it uses BCD, using the $ modifier.
    eg. hours =$15 (3 PM)
    I have come up with a somewhat cumbersome code solution converting decimal
    to bcd, but just don't know how to do it properly (my solution is somewhat
    lengthy)
    Problem goes something like this (shortened):-
    ' get decimal time data from another stamp
    serin [noparse][[/noparse]hours]
    serin [noparse][[/noparse]days]
    serin [noparse][[/noparse]minutes]
    '*****convert variables containing decimal to bcd here**
    'set the ds1302
    shiftout [noparse][[/noparse]hours]
    shiftout [noparse][[/noparse]days]
    shiftout [noparse][[/noparse]minutes]
    Can you help me at all please?
    Dwain.
    Sent: Monday, January 13, 2003 9:28 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Conversion Confusion!
    hexadecimal
    > DEC, HEX and BIN.
    serial
    > -- Jon Williams
    > -- Parallax
    > > I want it to work:
    > > inData var byte
    > > outData var byte
    > > is in hex now?
    edited 2003-01-13 00:19
    In a message dated 01/12/2003 19:14:15 Eastern Standard Time,
    dwainsworld@e... writes:
    Tracy is a he. Boy, wait until the Women's Network hears about this!!!
    Sid
    edited 2003-01-13 00:50
    hours = hours/10 * 16 + (hours//10)
    days = days/10*16+(days//10)
    minutes = minutes/10*16+(minutes//10)
    ' example: hours = 23 in decimal
    ' 23/10 = 2 integer arithmetic, drop the remainder
    ' 23/10*16 = 32 or in hex, $20
    ' 23//10=3 is the remainder that was dropped, ones digit
    ' 23/10*16+(23//10) = 35 in decimal, but $23 in BCD!!!
    ' that is what you need to set the clock to "23"
    >'set the ds1302
    Sid, my wife's name is Teri, so we are always confused around here,
    but the Women's Network has nothing to do with it!
    -- regards,
    Tracy Allen .
    mailto:tracy@e...
    http://www.emesystems.com
    edited 2003-01-13 01:42
    Its those long eyelashes that confuses them I think.
    Bwahaha
    Sent: Sunday, January 12, 2003 4:50 PM
    > >'set the ds1302
    > -- regards,
    > Tracy Allen .
    > mailto:tracy@e...
    edited 2003-01-13 01:44
    You mean Dr. Thomas Tracy Allen, the woman in the red life jacket and
    full beard is actually a guy ?
    http://www.emesys.com/EMEmore.htm
    Tracy, your
    the
    this!!!
    > Sid
    edited 2003-01-13 01:56
    Dwain:
    Sure, I'm happy to help ... and I still think that spending some time with
    the manual will do you some good.
    Okay, you present a different request than last time. There is a difference
    between straight decimal format and BCD (binary coded decimal). BCD numbers
    (one byte) contain the tens digit (0 - 9) in their high nibble, the ones
    digit in the low-nibble.
    Assuming you can get your decimal numbers, you can convert to BCD like this:
    bcdHours = (hours / 10 << 4) + (hours // 10)
    Of course, you can use the same variable, but you'll have to keep track of
    what format it currently holds.
    Try this to see what I mean:
    hours = 13
    DEBUG DEC2 hours, CR
    hours = (hours / 10 << 4) + (hours // 10)
    DEBUG HEX2 hours, CR
    Your output will be:
    13
    19
    13
    I'll leave it to you to figure out why. It will be a good learning tool.
    The hex indicator ($) or modifier (HEX) works becase hex numbers are similar
    to BCD in that each nibble is used to hold one digit -- the difference being
    that valid HEX digits are 0 - 9, A - F.
    -- Jon Williams
    -- Parallax
    In a message dated 1/12/2003 6:13:56 PM Central Standard Time,
    > lengthy)
    > 'set the ds1302
    > Regards,
    > Dwain.
    edited 2003-01-13 02:29
    LOL@ME
    Sent: Monday, January 13, 2003 11:19 AM
    your
    > Sid
    edited 2003-01-13 02:32
    BTW Sorry Dr Allen!!!!!
    Sent: Monday, January 13, 2003 12:44 PM
    Subject: [noparse][[/noparse]basicstamps] Re: Conversion Confusion!
    > Tracy, your
    > the
    > this!!!
    > > Sid
    edited 2003-01-13 02:36
    And thanks for the answers guys, I will go off and consult manual on this
    as well. I know that I ask a lot of dumb questions, but maths just aint my
    forte im afraid. (Beer is!!)
    Dwain.
    Sent: Monday, January 13, 2003 12:56 PM
    > Dwain:
    difference
    numbers
    this:
    > hours = 13
    > 13
    > 19
    > 13
    similar
    being
    > -- Jon Williams
    > -- Parallax
    your
    decimal
    somewhat
    > > lengthy)
    > > 'set the ds1302
    > > Regards,
    > > Dwain.
    edited 2003-01-13 04:03
    Jon - could you clear up a potential area of confusion, please? My
    understanding is that a BCD number contains only 1 digit in the byte (in
    the low nibble). The upper nibble is clear. Packed BCD places 2 BCD
    digits in the byte (1 digit in each nibble).
    What you have described above is packed BCD.
    Is this a Stamps thing?
    dwayne
    Dwayne Reid <dwayner@p...>
    Trinity Electronics Systems Ltd Edmonton, AB, CANADA
    (780) 489-3199 voice (780) 487-6397 fax
    Celebrating 18 years of Engineering Innovation (1984 - 2002)
    Do NOT send unsolicited commercial email to this email address.
    This message neither grants consent to receive unsolicited
    commercial email nor is intended to solicit commercial email.
    edited 2003-01-13 04:56
    HI DWAYNE!!
    NOW THE NAMEOLOGY IS REALLY GETTING HARD!!
    Sent: Monday, January 13, 2003 3:03 PM
    difference
    numbers
    > dwayne
    edited 2003-01-13 13:09
    Maybe it's just my ignorance -- I've never heard or used the term "packed
    BCD." So I did a bit of research on the Net and found that the accepted
    definition of BCD as "represents each of the digits of an unsigned decimal as
    the 4-bit binary equivalents" and Packed BCD as "packs two decimal digits
    into a single byte."
    I've been speaking very generically (a decimal digit held in a nibble) and
    your questions always involved bytes and two-digit values. Perhaps it's me
    that is confused, but the technical information I gave you was sound.
    -- Jon Williams
    -- Parallax
    In a message dated 1/12/2003 10:41:32 PM Central Standard Time,
    dwayner@p... writes:
    > dwayne
    edited 2003-01-13 13:33
    Al the information that is posted here is great help.
    For me, the learning process has involved something like this:-
    1 See Basic Stamp in Catalogue, maybe I should get one, but it's a bit
    expensive in AUS$, and besides that does it really do what it looks like it
    does?
    2 Got One a year later with a project in mind, still not sure it can do it
    3 Skim read manual in a few days, remembering some basic from Commodore64
    basic and Z80 days when computers were interesting but lacked purpose
    besides an interesting chess game
    4 Mess with BS2 until I can get a fuel computer for my boat to roughly
    work, I need more program space.
    5 Drink Beer (home brew of course)
    6 Have ideas for a thousand projects that need micro controlling that just
    haven't been done before, or have already been done but are still wayyyyy to
    expensive and can be done cheaper.
    7 Make some of those idea work
    8 Learn how to do stuff to make other ideas work as the need arises.
    This group is just damn great for item No. 8. I can often read the manual
    and not glean what I want, but the odd question here gets explained in a way
    that I can understand.
    Keep up the good work.
    regards,
    Dwain
    Sent: Tuesday, January 14, 2003 12:09 AM
    as
    me
    > -- Jon Williams
    > -- Parallax
    > > dwayne
    edited 2003-01-13 13:41
    Keep in mind that we have lots of other free documentation available for
    download. If you've got a slow internet connection ... well, what a great
    excuse to pop open another beer!
    Try these links:
    <A
    HREF="http://www.parallax.com/html_pages/resources/nvcolumns/Nuts_Volts_Download\
    s.asp
    http://www.parallax.com/html_pages/resources/nvcolumns/Nuts_Volts_Downloads.asp
    </A>
    <A
    HREF="http://www.parallax.com/html_pages/edu/curriculum/sic_curriculum.asp">http\
    ://www.parallax.com/html_pages/edu/curriculum/sic_curriculum.asp</A>
    <A
    HREF="http://www.parallax.com/html_pages/robotics/books/robo_books.asp">http://w\
    </A>
    -- Jon Williams
    -- Parallax
    In a message dated 1/13/2003 7:35:15 AM Central Standard Time,
    > way
    edited 2003-01-13 22:14
    I think the packed decimal comes from the old IBM 360/370 mainframe
    assembly. I vaguely remember having a hard time grasping the concept.
    as
    me
    IBM's packed decimal was a piece of cake to read in a dump -
    each 4-bit nibble represents 1 decimal digit (0-9) with a sign
    indicator in the last nibble of either 0xF for possitive or 0xC
    for negative, all right justified with a leading 0x0 nibble if
    required to pad out to a full byte.
    Now, IBM's own floating point format (before IEEE 754).... THAT
    was confussion!
