Stuck!
I need a way of sending text commands to an RS232 device (a dimmer
controller)based on certain conditions of a DVD player which
provides me with frame information. All the interfacing is worked
out but what I need is a way of storing the string commands in
variables. That will minimize the code I have to write. But as you
know I can only store one asci letter in a byte. I would love to be
able to put all my string commands in a list and then do lookup of
the item that I want based on the info I receive from the DVD and
then send that item to the dimmer.
If the above is vague I can explain further...
Al Najjar
Al Najjar
STFR=10 'start frame
DVD:
serout DVDTX,BAUD,1,[noparse][[/noparse]"FR",dec STFR,"SE",cr]
serin DVDRX,BAUD,6000,UHOH2,[noparse][[/noparse]wait("R")]
serout DVDTX,BAUD,1,[noparse][[/noparse]"PL",cr]
pause 3000
ENDFR=1000 'end frame
chk1: 'plays to frame 1000 then does something
TKO=0 ' set timeout lockup counter back to 0
serout DVDTX,BAUD,1,[noparse][[/noparse]"?F",cr]
serin DVDRX,BAUD,6000,UHOH3,[noparse][[/noparse]dec CURFR,wait(cr)]
'DEBUG "CURRENT FRAME = ", dec CURFR, CR
if CURFR=>ENDFR then DIM1
goto chk1
DIM1:
serout dimtx, baud2,1,[noparse][[/noparse]"WHATEVER1",CR]
serin dimrx, baud2, 6000, UHOH4,[noparse][[/noparse]wait("R")]
ENDFR=2000
chk2:
serout DVDTX,BAUD,[noparse][[/noparse]"?F",cr]
if CURFR=>ENDFR then DIM2
goto chk1
DIM2:
serout dimtx, baud2,[noparse][[/noparse]"WHATEVER2",CR]
etc.
I could probably help you with some stamp code to control the pioneer
DVD-V7400 if you like.
-Marie
need:
Msg1 DATA "This is message 1", 0 ' zero-terminated strings
Msg2 DATA "This is message 2", 0
Main:
' some code -- determine which message to send; put value in msgNum
LOOKUP msgNum, [noparse][[/noparse]Msg1, Msg2], eeAddr ' get pointer to string
GOSUB Send_String
' clean-up code after sending message
GOTO Main
Send_String:
READ eeAddr, char
IF (char = 0) THEN Send_String_Exit
SEROUT sPin, sBaud, [noparse][[/noparse]char]
eeAddr = eeAddr + 1
GOTO Send_String
Send_String_Exit:
RETURN
Send_String_25: ' for PBASIC 2.5
DO
READ eeAddr, char
IF (char = 0) THEN EXIT
eeAddr = eeAddr + 1
LOOP
RETURN
-- Jon Williams
-- Parallax
In a message dated 1/9/2003 4:13:07 PM Central Standard Time,
brownstamp@y... writes:
> Al Najjar
This is helpful. The problem is not the Pioneer 7400 but
manipulating large amount of text for serial com. The Stamp is not
well equiped for that.
many thanks,
Al
--- In basicstamps@yahoogroups.com, "hazemarie <hazemarie@y...>"
<hazemarie@y...> wrote:
> Why not use branching or subroutines?
> DVD:
> pause 3000
> goto chk1
> DIM1:
> ENDFR=2000
> chk2:
> goto chk1
> DIM2:
> etc.
pioneer
> -Marie
to EEPROM? I have about 90 text messages.
Al
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> Here's an efficient way to implement a list of strings and send
them as you
> need:
terminated strings
> Main:
msgNum
to string
> GOSUB Send_String
> GOTO Main
> Send_String:
> READ eeAddr, char
> eeAddr = eeAddr + 1
> GOTO Send_String
> Send_String_Exit:
> RETURN
> DO
> READ eeAddr, char
> eeAddr = eeAddr + 1
> LOOP
> RETURN
> -- Jon Williams
> -- Parallax
dimmer
worked
you
to be
of
and
> > Al Najjar
tokens -- the compiler will tell you. You can monitor your EEPROM use with
the Memory Map button/menu selection.
DATA statements build from the bottom up (unless you specify a different
location) and program tokens build from the top down. When they meet in the
middle your memory is full.
-- Jon Williams
-- Parallax
In a message dated 1/9/2003 10:40:04 PM Central Standard Time,
> What is the limit on the number of these Data item that I can write
> Al
